Constant Lock & Load crashes while tracking motion
COW Forums : CoreMelt Plug-ins
Neil Evans
on Dec 15, 2010 at 7:54:43 pm
Hello,
I am a paid user with the current version of L&L – running 10.6.5 and the latest FCP. I am consistently experiencing crashes and other errors with Lock & Load Frames. (I've been unable to ever get L&L X to successfully process a clip, so I've been focussing on Frames). At least 75% of the time when I attempt to Track Motion on a clip, I receive either the following error "Motion Tracking Error. Could not read frames. If Digital Cinema Desktop is enabled..." or FCP will simply crash. I do not have Digital Cinema Desktop enabled and never have. I do have a Matrox MXO2 mini, and I have tried tracking with that enabled and disabled – it doesn't seem to make a difference. Following other hints I've spotted in the forum, I have both the Canvas and Viewer windows at 100% and I make sure I don't have any in or out points set in the sequence.
When I attempt to track and get the error, I see hundreds of the following errors in the Console:
12/15/10 11:42:45 AM [0x0-0x8e08e].com.apple.FinalCutPro[926] Final Cut Pro(926,0xa02e4540) malloc: *** mmap(size=8310784) failed (error code=12)
12/15/10 11:42:45 AM [0x0-0x8e08e].com.apple.FinalCutPro[926] *** error: can't allocate region
12/15/10 11:42:45 AM [0x0-0x8e08e].com.apple.FinalCutPro[926] *** set a breakpoint in malloc_error_break to debug
Occasionally the stars align, and I can track a couple clips in a row, but as soon as I see that Desktop Cinema Preview error, I know I'm out of luck and must quit FCP, and usually restart the machine. I've also periodically had problems with renders from L&L where clips that do supposedly have tracking data will render as entirely blue.
Thank you,
Neil
Roger Bolton
Re: Constant Lock & Load crashes while tracking motion
on Dec 16, 2010 at 12:28:39 am
Hi Neil, we replied to your support email and we are looking into this, thanks for letting us know about the problem
CoreMelt V2 plugins
