FCP - for best results, use self-contained QT???
COW Forums : CoreMelt Plug-ins
Casey Petersen
on Nov 30, 2010 at 6:24:30 pm
I am using Lock and Load X for the first time, and they claim that you don't need to export your clip to a self-contained QT file, that it will simply analyze the clip you use instead of the whole clip, like SmoothCam.
With the video I have tested on, HDV1080i60, the results are SIGNIFICANTLY better if I use a self-contained QT versus applying it to the clip.
Am I doing something wrong?
Casey
Eberhard Ammelt
Re: FCP - for best results, use self-contained QT???
on Nov 30, 2010 at 6:51:29 pm
This is not regular behavior. Can you tell in which way the results are better?
Is there any difference regarding field order or clip width/height between your original and your re-imported clip?
Regards, Eberhard
Casey Petersen
on Nov 30, 2010 at 6:54:06 pm
Well, simply put, the clip doesn't look like it's been smoothed unless I do a SCQT, and then it looks as good as SmoothCam.
Casey
