Combining Movies and Stills in Multi Pop Forward plug-in
COW Forums : CoreMelt Plug-ins
Howard Leiner
on Nov 13, 2010 at 8:46:50 pm
I'm using the Multi Pop Forward effect and it will not mix my movies and my stills in the same effect. I am using a folder as my source. The folder contains approx 30 stills and 3 short videos (.mov files). If i set "Load" to "Movies" i see my 3 movies scroll past as expected. If i set Load to "Images" it also behaves as expected. But if i set Load to "All of the Above" i only see the pictures. No movies.
I'm using Final Cut Express 4.0.1. I just purchased the coremelt stuff a few days back so it's the latest version.
Help?!?
Thank you
Howard
Eberhard Ammelt
Re: Combining Movies and Stills in Multi Pop Forward plug-in
on Nov 15, 2010 at 6:59:37 pm
Can you please check the log file for related error messages after you've chosen the folder?
If there is no message, please press the Option button while you click on "Choose Folder". Then, some information about the current folder will be written to the log. Can you please send this.
Regards, Eberhard
