Lock & Load X
COW Forums : CoreMelt Plug-ins
Mauricio Arango
Lock & Load X
on Nov 10, 2010 at 3:30:53 pm
I just bought and installed the Lock & Load X plugin.
I'm testing on a short clip (less than 20 seconds) and the results are much worse than the original shaking of the footage. The rendered clip present a lot more movement and random variations in the zoom. Nothing smooth at all. After trying several parameter combinations I'm giving up and asking for advice.
I should mention that the original clip was shot at 1080, and I'm editing it on a timeline set at 720. Other than that the clip's speed is the same. Would this frame size difference be an issue?
Thanks so much,
M.
Mauricio Arango
Re: Lock & Load X
on Nov 10, 2010 at 3:38:41 pm
I should add I am editing on FCPS 3 and my footage is ProRes 422 proxy, It was shot originally on a 5D Mark II.
Thanks.
Yuri Radaev
Re: Lock & Load X
on Nov 10, 2010 at 4:12:25 pm
Try to clear IN-OUT points on timeline.
Eberhard Ammelt
Re: Lock & Load X
on Nov 10, 2010 at 7:13:32 pm
Hello,
resizing the clip should not be a problem.
In some cases FCP does not correctly recognize the clip's field order. In that case stabilization results can get bad.
Also, as Yuri mentioned, sequence in/out points can be a problem. Please clear in/out points until the clip is rendered.
Does the problem also occur with Lock & Load Frames ?
Regards, Eberhard
Mauricio Arango
Re: Lock & Load X
on Nov 10, 2010 at 7:53:10 pm
I didn't have any IN/OUT markers in my timeline.
I did tried the Load&Load frames and the results were much much better. So I guess I'm sticking to it by now.
Thank you anyways,
m
Neil Evans
Re: Lock & Load X
on Nov 10, 2010 at 10:01:23 pm
Mauricio,
Just wanted to let you know you're not alone – I've been unable to get any decent results with L&L X. It seems to make motion and jitter much worse, exactly as you describe. Frames seems to work okay though. It's still buggy, but much less so.
-Neil
