Lock&Load flickering after export to .mov
COW Forums : CoreMelt Plug-ins
Brian Miller
on Oct 7, 2010 at 4:55:48 am
I have used Lock&Load on several clips within FCE, but the clips flicker once I've exported to QT mov. Any ideas?
Eberhard Ammelt
Re: Lock&Load flickering after export to .mov
on Oct 7, 2010 at 7:23:19 am
Hello,
this might be an interlace issue. What is the field order of your source video and what is the field order in your sequence settings? Does FCP estimate the field order of your source clip correctly?
Regards, Eberhard
