99% error
COW Forums : CoreMelt Plug-ins
Barbara Stein
99% error
on Sep 14, 2010 at 6:02:34 pm
Since two days I have the problem that the tracking stops at 99% with L&L X and I´m not able to solve this problem alone.
In my earlier work I abandoned the option to use L&L, because it made FCP crash and I even coudn´t open the projectdata.I somehow solved the problem without using L&L at all! So now, in my new work I would like to use it - but as I wrote - unsuccesfully!
What is going on with the tracking stop at 99% with L&L X?
The following sentence is written: An error occured while reading clip properties.
Thank you for any ideas and help,
Barbara
Eberhard Ammelt
Re: 99% error
on Sep 14, 2010 at 7:33:58 pm
Hello Barbara,
could you please send me crash logs from the crashes with Lock & Load Frames?
Please send them to eberhard (at) coremelt.com
Lock & Load X requests information from FCP, for this purpose FCP converts the related sequence/project to xml. With complex projects this can be a complicated procedure where errors can occur like in your case. How big is your FCP project in file size?
Regards, Eberhard
