Snow Leopard Updated Info
COW Forums : CoreMelt Plug-ins
Roger Bolton
on Sep 23, 2009 at 3:35:08 am
Painless Snow Leopard Upgrade for CoreMelt Users
Unfortunately some users have ran into problems using our plugins on Snow Leopard. To ensure that your upgrade goes as smoothly as possible we recommend the following procedure:
1. Install your Snow Leopard upgrade, we recommend a clean install if possible rather than overwriting Leopard.
2. After Snow Leopard is installed, make sure you have the latest versions of FCP and Motion by running software update.
3. Then please re-install our latest version of CoreMelt plugins to make sure you have our Snow Leopard compatible version (V2 2.2.2c). Latest versions are here:
http://www.coremelt.com/updates/
4. In some cases you may need to re-install your serial number, even if you installed over Leopard.
For more details please see this page on Snow Leopard on our website.
http://www.coremelt.com/support/v2/snow-leopard-compatibility.html
After Effects CS3/CS4 Users
Unfortunately there is a serious problem regarding using V2 plugins in AE CS3 / CS4. AE users should avoid updating to Snow Leopard at this time, Adobe and Apple are aware of this problem and it is a general problem for many plugin developers. More info:
http://blogs.adobe.com/keyframes/2009/08/after_effects_and_snow_leopard.htm...
Roger
CoreMelt
Mark Palmos
Re: Snow Leopard Updated Info
on Oct 31, 2009 at 1:11:00 pm
Hi guys,
I have coremelt motion and editors pack v1
I have also upgraded fxfactory to 2.1.1
but cannot see any coremelt plugins in motion or in fxfactory registered plugins section.
Ive tried reinstalling several times, to no avail.
I see support for version 2 of the plugins, but I have not seen anywhere that v1 is not supported... I very much hope it is!
Mark Palmos
UK.
Mark Palmos
on Oct 31, 2009 at 1:12:55 pm
What about v1 users?
The plugs are not showing at all.
Mark.
Roger Bolton
on Oct 31, 2009 at 1:39:11 pm
CoreMelt V1 (FxFactory version) should work in snow leopard as long as you have the latest version of FxFactory installed.
However there is a broader problem which can prevent any FxPlug plugins appearing for users upgrading to Snow Leopard.
we recommend you try installing this update:
http://www.apple.com/downloads/macosx/apple/application_updates/pluginmanag...
If that does not work you may need to reinstall FCP from the original disk and then run software update to update to the latest version, then run our installer again. It appears for a small number of users the upgrade to Snow Leopard corrupts library files that are needed to make third party plugins work.
Mark Palmos
on Oct 31, 2009 at 1:51:29 pm
Hi there,
Thanks for the quick response.
I tried the plugin updater but it did not work. I also tried to reinstall coremeltcomplete.
The thing is, yesterday I did a clean install of Snow leopard, and reinstalled fcp studio 3 from disks just hours before installing fxfactory and your coremelt plugins... so i had not upgraded my system or fcp!
boy, anyone who ever tells me that mac's are easier to upgrade than a pc needs to rethink... ive just upped to win7 on my wife's computer and had no probs at all. Snow leopard has caused sooo many of my apps to behave badly, crash etc... eventually did a clean install yesterday.
Do you still think its necessary to try install ALL of fcp again? That is such a pain! Cant i copy the plugins from one place to another to be "seen" by the system?
Thanks again,
Mark.
Roger Bolton
on Oct 31, 2009 at 1:57:13 pm
Ok, if you did a clean install then instead please try running disk utility and repairing permissions and then re-installing. You can also try installing as a different user account.
Mark Palmos
on Oct 31, 2009 at 3:05:03 pm
Hi Roger,
I did a repair, it said it completed successfully, but had this
SUID file "System/Library/CoreServices/RemoteManagement/ARDAgent.app/Contents/MacOS/ARDAgent" has been modified and will not be repaired.
in the report, I dont know if coreservices have anything to do with coremelt!
it did not work, so I created a new admin level user account and logged in to that, installed, and again, no joy... very frustrating given this is a completely fresh OSX install, all the latest FCP and OSX patches applied first, the latest FXFactory... odd.
any further tricks or suggestions very welcome!
tx
Mark.
Mark Palmos
on Oct 31, 2009 at 3:08:52 pm
I did a search for coremelt, and see Editing, Motion packs are in
library/application support/noise industries/
(I assume it is installing to the right location?)
tx
Mark.
Roger Bolton
on Oct 31, 2009 at 3:23:54 pm
sorry I realised I've forgotten a likely cause. In fxfactory 2.07 and later you need to check the box "show discontinued products" to see coremelt products for registration.
if this was the problen, I apologise for the confusion, this change was not made by us and is not under our control.
Mark Palmos
on Oct 31, 2009 at 4:38:01 pm
EXCELLENT!
yep
works fine now.
one dratted little check box!
oh well, live and learn,
Thanks very much for your persistence and help.
Mark.
Lawrence Gray
on Apr 1, 2010 at 9:45:46 am
I installed Snowleopard before I got CorelMelt and I find the plug ins crash FCP. I can't render a file where I've used the Cloning tool. I haven't tried others. I have the latest version of CorelMelt so what can I do?
Lawrence Gray
Eberhard Ammelt
on Apr 1, 2010 at 10:08:04 am
Hello, can you please send us your crash logs and a system profile?
Thanks, Eberhard
Lawrence Gray
on Apr 1, 2010 at 10:18:26 am
Here's the crash report I get when I try rendering the clip with the Cloning plug in.
I think this has all the information about the system etc.
Process: Final Cut Pro [687]
Path: /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
Identifier: com.apple.FinalCutPro
Version: 7.0.2 (7.0.2)
Build Info: FCPApp-955601010~8
Code Type: X86 (Native)
Parent Process: launchd [107]
PlugIn Path: /Library/Plug-Ins/FxPlug/VTwinFx.fxplug/Contents/MacOS/VTwinFx
PlugIn Identifier: com.pixlock.VTwinFx.FxPlug
PlugIn Version: ??? (2.2.9 (100))
Date/Time: 2010-04-01 18:12:52.855 +0800
OS Version: Mac OS X 10.6.3 (10D573)
Report Version: 6
Interval Since Last Report: 2444 sec
Crashes Since Last Report: 2
Per-App Interval Since Last Report: 2179 sec
Per-App Crashes Since Last Report: 2
Anonymous UUID: 7AAB885D-F6C4-4F14-B746-0B6285DCD9E6
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Thread 0 Crashed: Dispatch queue: com.apple.main-thread
0 com.apple.GeForceGLDriver 0x8f4a4592 glrCompCreateStream + 2048866
1 com.apple.GeForceGLDriver 0x8f1b5dcd glrCompExecuteKernel + 414509
2 com.apple.GeForceGLDriver 0x8f1fa18f gldUpdateDispatch + 1247
3 GLEngine 0x0bfe48f0 gleDoSelectiveDispatchNoErrorCore + 227
4 GLEngine 0x0bfe9ace gleCheckFramebufferStatus + 185
5 com.pixlock.VTwinFx.FxPlug 0x33ec6950 -[ComPixlockFxRenderer setupFBOsWithAccu:] + 859
6 com.pixlock.VTwinFx.FxPlug 0x33ec7475 -[ComPixlockFxRenderer beginRenderingWithShutterFrames:] + 59
7 com.pixlock.VTwinFx.FxPlug 0x33ebb8eb -[ComPixlockFxBaseEffect doRenderOutput:withInfo:] + 521
8 com.pixlock.VTwinFx.FxPlug 0x33eb7f0b -[ComPixlockFxFilterEffect renderOutput:withInput:withInfo:] + 590
9 ...uartzComposer.FxPlugWrapper 0x0d0c7335 0xd0c1000 + 25397
10 com.apple.QuartzComposer 0x911b0f02 -[QCPatch(Private) _renderAtTime:arguments:] + 111
11 com.apple.QuartzComposer 0x911b9ebc -[QCContext renderPatch:time:arguments:] + 809
12 com.apple.QuartzComposer 0x911b9b24 -[QCGraphicsContext renderPatch:time:arguments:] + 96
13 com.apple.QuartzComposer 0x911b8adb -[QCOpenGLContext renderPatch:time:arguments:] + 565
14 com.apple.QuartzComposer 0x911b889e -[QCPatch(Runtime) render:arguments:] + 92
15 com.apple.FinalCutPro 0x00519bb9 RenderQCPatch + 1671
16 com.apple.FinalCutPro 0x00516133 FCPQCMainEntry(long, long, KGDictInt*, void*) + 10083
17 com.apple.FinalCutPro 0x002e9f76 pKGRunTransition(KGDictInt*) + 2182
18 com.apple.FinalCutPro 0x0024fec5 GetFilterFrame(KGDictInt*, KGClipItemType, long, unsigned char, WhenRec*, double, BufferInfoRec*, KGCanvasRec*, KGRect*, renderStackInfo*, unsigned char*) + 3791
19 com.apple.FinalCutPro 0x002544bf GetMotionFrame(KGDictInt*, KGClipItemType, WhenRec*, double, BufferInfoRec*, KGCanvasRec*, KGRect*, renderStackInfo*, unsigned char*) + 11215
20 com.apple.FinalCutPro 0x00254f3d GetBlurFrame(KGDictInt*, KGClipItemType, WhenRec*, double, BufferInfoRec*, KGCanvasRec*, KGRect*, renderStackInfo*, unsigned char*) + 2627
21 com.apple.FinalCutPro 0x002564ad GetTrackItemFrame(KGDictInt*, TrackInfoRec*, BufferInfoRec*, KGCanvasRec*, KGRect*, renderStackInfo*) + 5473
22 com.apple.FinalCutPro 0x0024c65a CompositeLoop(KGDictInt*, WhenRec*, KGCanvasRec*, KGRect*, BufferInfoRec*, renderStackInfo*, unsigned char*, TrackItemAtTimeCache*) + 1704
23 com.apple.FinalCutPro 0x00257eb8 pKGGetClipVideoWithAlpha(double, long, KGCanvasRec*, KGRect*, long, KGDictInt*, AlphaType*, unsigned long long) + 5408
24 com.apple.FinalCutPro 0x00249c78 pKGGetClipVideo(double, long, KGCanvasRec*, KGRect*, long, KGDictInt*, unsigned long long) + 80
25 ...alCutPro.Plugins.QTM Reader 0x0ca60adf AudioExtractor::~AudioExtractor() + 28859
26 ...alCutPro.Plugins.QTM Reader 0x0ca68cc9 PluginMainEntry(long, long, KGDictInt*, void*) + 10675
27 com.apple.FinalCutPro 0x0046bd4c RenderToFile(KGFileRec*, unsigned char, KGDictInt*, double, double*, char*, unsigned long long, KGRenderBitFlags, unsigned long, LongGopConformParameters*) + 650
28 com.apple.FinalCutPro 0x0047c4ac RenderOneFile(KGDictInt*, double, double*, unsigned long*, long, long, KGDictInt*, KGItemSpec*, char*, unsigned long long, unsigned long, KGRenderCancelHandling, KGPlayerRec*, KGRenderBitFlags, unsigned char, KGFileSpec*, unsigned char*, unsigned char, LongGopConformParameters*, std_vector*) + 3792
29 com.apple.FinalCutPro 0x00492253 PlayerRenderHelp(KGPlayerRec*, double, double, char*, char*, unsigned long long, KGRenderCancelHandling, unsigned char*, unsigned char, KGRenderBitFlags) + 4353
30 com.apple.FinalCutPro 0x00495152 pKGPlayerRender(KGPlayerRec*, double, double, char*, unsigned long long, KGRenderCancelHandling, unsigned char*, KGRenderBitFlags) + 4670
31 com.apple.FinalCutPro 0x000aa094 pKGClipHandleDefaultMenu(KGDictInt*, long, unsigned char) + 6802
32 com.apple.FinalCutPro 0x001d7196 pKGClipDefaultMessage(long, long, KGDictInt*, KGDictInt*, long) + 872
33 ...Pro.Plugins.Timeline Editor 0x0caf4f70 TLTimeRemapGetChangeType(KGDictInt*, KGItemSpec*, double, KTPartKind, long) + 102226
34 com.apple.FinalCutPro 0x002b1951 pKGPanelMessage(long, long, KGDictInt*, KGViewRecord*) + 2103
35 com.apple.FinalCutPro 0x0025e6d4 ServicesPanelsMessageProc(long, long, KGDictInt*, KGPanelRecord*) + 120
36 com.apple.FinalCutPro 0x0025fb7e TimelineMessageProc(long, long, KGDictInt*, KGPanelRecord*) + 110
37 com.apple.FinalCutPro 0x002a75f1 pKGPanelWindowProc(long, long, KGDictInt*, void*) + 53
38 com.apple.FinalCutPro 0x002bd413 pKGSendWindowMessage(KGWindowRec*, long, long, KGDictInt*) + 91
39 com.apple.FinalCutPro 0x00150939 HandleMenuCommand(long, unsigned char, unsigned char, unsigned char, KGErrorCode (*)(long, long, KGDictInt*, void*), void*) + 417
40 com.apple.FinalCutPro 0x00150aaf HandleCommand(long, unsigned char, unsigned char, unsigned char) + 263
41 com.apple.FinalCutPro 0x004146ed CommandProcess(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 369
42 com.apple.HIToolbox 0x95daf0a9 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1567
43 com.apple.HIToolbox 0x95dae370 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
44 com.apple.HIToolbox 0x95dd0b55 SendEventToEventTarget + 52
45 com.apple.HIToolbox 0x95dfd147 SendHICommandEvent(unsigned long, HICommand const*, unsigned long, unsigned long, unsigned char, void const*, OpaqueEventTargetRef*, OpaqueEventTargetRef*, OpaqueEventRef**) + 448
46 com.apple.HIToolbox 0x95e21e40 SendMenuCommandWithContextAndModifiers + 66
47 com.apple.HIToolbox 0x95e21df5 SendMenuItemSelectedEvent + 121
48 com.apple.HIToolbox 0x95e21cfa FinishMenuSelection(SelectionData*, MenuResult*, MenuResult*) + 152
49 com.apple.HIToolbox 0x95df1436 MenuSelectCore(MenuData*, Point, double, unsigned long, OpaqueMenuRef**, unsigned short*) + 454
50 com.apple.HIToolbox 0x95fa399f MenuSelect + 190
51 com.apple.HIToolbox 0x95f5ca30 HIMenuBar::HandleMouseEvent(OpaqueEventRef*) + 92
52 com.apple.HIToolbox 0x95daf6a3 HIObject::EventHook(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 173
53 com.apple.HIToolbox 0x95daf0a9 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1567
54 com.apple.HIToolbox 0x95dae370 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
55 com.apple.HIToolbox 0x95dd0b55 SendEventToEventTarget + 52
56 com.apple.HIToolbox 0x95de26db ToolboxEventDispatcherHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 1417
57 com.apple.HIToolbox 0x95daf4fa DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 2672
58 com.apple.HIToolbox 0x95dae370 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
59 com.apple.HIToolbox 0x95dd0b55 SendEventToEventTarget + 52
60 com.apple.HIToolbox 0x95f59df7 ToolboxEventDispatcher + 86
61 com.apple.HIToolbox 0x95f59f2f RunApplicationEventLoop + 243
62 com.apple.FinalCutPro 0x0015396f KGMainEvent(void*) + 51
63 com.apple.FinalCutPro 0x002c10e8 main + 54
64 com.apple.FinalCutPro 0x00002d7b _start + 209
65 com.apple.FinalCutPro 0x00002ca9 start + 41
Thread 1: Dispatch queue: com.apple.libdispatch-manager
0 libSystem.B.dylib 0x951ebb42 kevent + 10
1 libSystem.B.dylib 0x951ec25c _dispatch_mgr_invoke + 215
2 libSystem.B.dylib 0x951eb719 _dispatch_queue_invoke + 163
3 libSystem.B.dylib 0x951eb4be _dispatch_worker_thread2 + 240
4 libSystem.B.dylib 0x951eaf41 _pthread_wqthread + 390
5 libSystem.B.dylib 0x951ead86 start_wqthread + 30
Thread 2:
0 libSystem.B.dylib 0x951e4286 select$DARWIN_EXTSN + 10
1 com.apple.CoreFoundation 0x9938882d __CFSocketManager + 1085
2 libSystem.B.dylib 0x951f2a19 _pthread_start + 345
3 libSystem.B.dylib 0x951f289e thread_start + 34
Thread 3:
0 libSystem.B.dylib 0x951c5342 semaphore_wait_signal_trap + 10
1 libSystem.B.dylib 0x951f2eb8 _pthread_cond_wait + 1089
2 libSystem.B.dylib 0x9523b42f pthread_cond_wait + 48
3 com.apple.FinalCutPro 0x0043e785 Synchronizable::Wait() + 53
4 com.apple.FinalCutPro 0x00428d6f DisplayQueue::Run() + 681
5 com.apple.FinalCutPro 0x0046a772 Thread::RunHelper(void*) + 20
6 libSystem.B.dylib 0x951f2a19 _pthread_start + 345
7 libSystem.B.dylib 0x951f289e thread_start + 34
Thread 4:
4 com.apple.FinalCutPro 0x004e594f WorkUnitPerformer::Run() + 55
Thread 5:
Thread 6:
Thread 7:
Thread 8:
Thread 9:
Thread 10:
Thread 11:
0 libSystem.B.dylib 0x951c52fa mach_msg_trap + 10
1 libSystem.B.dylib 0x951c5a67 mach_msg + 68
2 com.apple.CoreFoundation 0x9934900f __CFRunLoopRun + 2079
3 com.apple.CoreFoundation 0x993480f4 CFRunLoopRunSpecific + 452
4 com.apple.CoreFoundation 0x9934e034 CFRunLoopRun + 84
5 com.apple.DVCPROHDMuxer 0x0ebc398f AVS::DestroyAVCDeviceController(AVS::AVCDeviceController*) + 317
Thread 12:
4 com.apple.CoreFoundation 0x99347f21 CFRunLoopRunInMode + 97
5 ....CoreMediaIOServicesPrivate 0x0102aa37 MIO::DAL::RunLoop::OwnThread(void*) + 157
6 ....CoreMediaIOServicesPrivate 0x0102c8a8 CAPThread::Entry(CAPThread*) + 96
7 libSystem.B.dylib 0x951f2a19 _pthread_start + 345
8 libSystem.B.dylib 0x951f289e thread_start + 34
Thread 13:
5 com.apple.qmaster.do 0x3bf13460 swamp::CRAdReceiver2::ReceivingThread::runOnce() + 234
6 com.apple.AECore 0x40e1a022 aecore::CThread::runThread() + 34
7 com.apple.AECore 0x40e17fb9 threadProc(void*) + 17
8 libSystem.B.dylib 0x951f2a19 _pthread_start + 345
9 libSystem.B.dylib 0x951f289e thread_start + 34
Thread 14:
1 com.apple.AECore 0x40e1a067 aecore::CThread::runThread() + 103
2 com.apple.AECore 0x40e17fb9 threadProc(void*) + 17
3 libSystem.B.dylib 0x951f2a19 _pthread_start + 345
4 libSystem.B.dylib 0x951f289e thread_start + 34
Thread 15:
0 libSystem.B.dylib 0x951c535a semaphore_timedwait_signal_trap + 10
1 libSystem.B.dylib 0x951f2ea1 _pthread_cond_wait + 1066
2 libSystem.B.dylib 0x95221a28 pthread_cond_timedwait_relative_np + 47
3 ...ple.CoreServices.CarbonCore 0x91c3e465 TSWaitOnConditionTimedRelative + 242
4 ...ple.CoreServices.CarbonCore 0x91c3e1a3 TSWaitOnSemaphoreCommon + 511
5 ...ickTimeComponents.component 0x942bd91d ReadSchedulerThreadEntryPoint + 4698
Thread 16:
0 libSystem.B.dylib 0x951f3262 __semwait_signal + 10
1 libSystem.B.dylib 0x951f2f1e _pthread_cond_wait + 1191
2 libSystem.B.dylib 0x951f4bb8 pthread_cond_wait$UNIX2003 + 73
3 com.apple.ozone.framework 0x3d70a05b OZExecutionUnit::executeLoop() + 75
4 com.apple.ozone.framework 0x3d70a15e OZExecutionUnit::executeLoopWrapper(void*) + 94
5 com.apple.procore.framework 0x0d6280a8 PCThread::startup(void*) + 18
Thread 17:
Thread 18:
Thread 19:
Thread 20:
Thread 21:
Thread 22:
5 com.apple.Foundation 0x94ea3434 +[NSURLConnection(NSURLConnectionReallyInternal) _resourceLoadLoop:] + 329
6 com.apple.Foundation 0x94e6a8dc -[NSThread main] + 45
7 com.apple.Foundation 0x94e6a88c __NSThread__main__ + 1499
Thread 23:
3 ....Helium.HSmoothMotionRender 0x54a10f52 HSmoothMotionRenderFactory + 921506
4 ....Helium.HSmoothMotionRender 0x54930391 HSmoothMotionRenderFactory + 993
5 ....Helium.HSmoothMotionRender 0x5493041e HSmoothMotionRenderFactory + 1134
Thread 24:
3 com.apple.AppleProResCodec 0x0da6f40b IcpDecompressorComponentDispatch + 1771
4 libSystem.B.dylib 0x951f2a19 _pthread_start + 345
Thread 25:
Thread 26:
Thread 27:
Thread 28:
Thread 29:
Thread 30:
Thread 31:
Thread 32:
4 com.apple.FinalCutPro 0x000904f9 SyncMetaDataTask::GetNextEvent() + 81
5 com.apple.FinalCutPro 0x00091427 SyncMetaDataTask::Run() + 39
6 com.apple.FinalCutPro 0x0046a772 Thread::RunHelper(void*) + 20
Thread 33: JavaScriptCore: FastMalloc scavenger
3 com.apple.JavaScriptCore 0x9745f3e6 WTF::TCMalloc_PageHeap::scavengerThread() + 614
Thread 34:
0 libSystem.B.dylib 0x951eabd2 __workq_kernreturn + 10
1 libSystem.B.dylib 0x951eb168 _pthread_wqthread + 941
2 libSystem.B.dylib 0x951ead86 start_wqthread + 30
Thread 35:
1 libSystem.B.dylib 0x9521ee44 nanosleep$UNIX2003 + 188
2 libSystem.B.dylib 0x9521ed82 usleep$UNIX2003 + 61
3 com.apple.DesktopVideoOut 0x33d05903 DVOClockGetTime + 984
5 libSystem.B.dylib 0x951f289e thread_start + 34
Thread 36:
3 com.apple.AppleVADriver 0x5a70636c AVAGetRendererInfo + 7580
4 com.apple.AppleVADriver 0x5a70bc5f AVAGetRendererInfo + 30351
5 libSystem.B.dylib 0x951f2a19 _pthread_start + 345
6 libSystem.B.dylib 0x951f289e thread_start + 34
Thread 37:
Thread 38:
Thread 39:
Thread 40:
Thread 41:
Thread 42:
Thread 43:
Thread 44:
Thread 45:
Thread 46:
Thread 47:
Thread 48:
Thread 49:
Thread 50:
Thread 51:
Thread 52:
5 ...ple.CoreServices.CarbonCore 0x91c98a50 AIOFileThread(void*) + 1127
Thread 53:
5 ...ple.CoreServices.CarbonCore 0x91c623eb TimerThread + 97
Thread 54:
3 com.apple.AppleHDVCodec 0x0dfdb8f8 MPEG2CompressorComponentDispatch + 189144
4 ??? 0x0200078c 0 + 33556364
5 ??? 0xa0617d18 0 + 2690743576
6 ??? 0xa061d118 0 + 2690765080
7 ??? 0xa0bbb68c 0 + 2696656524
8 ??? 0xa0bbb68c 0 + 2696656524
9 ??? 0xa0bbb68c 0 + 2696656524
10 ??? 0xa0bbb68c 0 + 2696656524
11 ??? 0xa0bbb68c 0 + 2696656524
12 ??? 0xa0bbb68c 0 + 2696656524
13 ??? 0xa0bbb68c 0 + 2696656524
14 ??? 0xa0bbb68c 0 + 2696656524
15 ??? 0xa0bbb68c 0 + 2696656524
16 ??? 0xa0bbb68c 0 + 2696656524
17 ??? 0xa0bbb68c 0 + 2696656524
18 ??? 0xa0bbb68c 0 + 2696656524
19 ??? 0xa0bbb68c 0 + 2696656524
20 ??? 0xa0bbb68c 0 + 2696656524
21 ??? 0xa0bbb68c 0 + 2696656524
22 ??? 0xa0bbb68c 0 + 2696656524
23 ??? 0xa0bbb68c 0 + 2696656524
24 ??? 0xa0bbb68c 0 + 2696656524
25 ??? 0xa0bbb68c 0 + 2696656524
26 ??? 0xa0bbb68c 0 + 2696656524
27 ??? 0xa0bbb68c 0 + 2696656524
28 ??? 0xa0bbb68c 0 + 2696656524
29 ??? 0xa0bbb68c 0 + 2696656524
30 ??? 0xa0bbb68c 0 + 2696656524
31 ??? 0xa0bbb68c 0 + 2696656524
32 ??? 0xa0bbb68c 0 + 2696656524
33 ??? 0xa0bbb68c 0 + 2696656524
34 ??? 0xa0bbb68c 0 + 2696656524
35 ??? 0xa0bbb68c 0 + 2696656524
36 ??? 0xa0bbb68c 0 + 2696656524
37 ??? 0xa0bbb68c 0 + 2696656524
38 ??? 0xa0bbb68c 0 + 2696656524
39 ??? 0xa0bbb68c 0 + 2696656524
40 ??? 0xa0bbb68c 0 + 2696656524
41 ??? 0xa0bbb68c 0 + 2696656524
42 ??? 0xa0bbb68c 0 + 2696656524
43 ??? 0xa0bbb68c 0 + 2696656524
44 ??? 0xa0bbb68c 0 + 2696656524
45 ??? 0xa0bbb68c 0 + 2696656524
46 ??? 0xa0bbb68c 0 + 2696656524
47 ??? 0xa0bbb68c 0 + 2696656524
48 ??? 0xa0bbb68c 0 + 2696656524
49 ??? 0xa0bbb68c 0 + 2696656524
50 ??? 0xa0bbb68c 0 + 2696656524
51 ??? 0xa0bbb68c 0 + 2696656524
52 ??? 0xa0bbb68c 0 + 2696656524
53 ??? 0xa0bbb68c 0 + 2696656524
54 ??? 0xa0bbb68c 0 + 2696656524
55 ??? 0xa0bbb68c 0 + 2696656524
56 ??? 0xa0bbb68c 0 + 2696656524
57 ??? 0xa0bbb68c 0 + 2696656524
58 ??? 0xa0bbb68c 0 + 2696656524
59 ??? 0xa0bbb68c 0 + 2696656524
60 ??? 0xa0bbb68c 0 + 2696656524
61 ??? 0xa0bbb68c 0 + 2696656524
62 ??? 0xa0bbb68c 0 + 2696656524
63 ??? 0xa0bbb68c 0 + 2696656524
64 ??? 0xa0bbb68c 0 + 2696656524
65 ??? 0xa0bbb68c 0 + 2696656524
66 ??? 0xa0bbb68c 0 + 2696656524
67 ??? 0xa0bbb68c 0 + 2696656524
68 ??? 0xa0bbb68c 0 + 2696656524
69 ??? 0xa0bbb68c 0 + 2696656524
70 ??? 0xa0bbb68c 0 + 2696656524
71 ??? 0xa0bbb68c 0 + 2696656524
72 ??? 0xa0bbb68c 0 + 2696656524
73 ??? 0xa0bbb68c 0 + 2696656524
74 ??? 0xa0bbb68c 0 + 2696656524
75 ??? 0xa0bbb68c 0 + 2696656524
76 ??? 0xa0bbb68c 0 + 2696656524
77 ??? 0xa0bbb68c 0 + 2696656524
78 ??? 0xa0bbb68c 0 + 2696656524
79 ??? 0xa0bbb68c 0 + 2696656524
80 ??? 0xa0bbb68c 0 + 2696656524
81 ??? 0xa0bbb68c 0 + 2696656524
82 ??? 0xa0bbb68c 0 + 2696656524
83 ??? 0xa0bbb68c 0 + 2696656524
84 ??? 0xa0bbb68c 0 + 2696656524
85 ??? 0xa0bbb68c 0 + 2696656524
86 ??? 0xa0bbb68c 0 + 2696656524
87 ??? 0xa0bbb68c 0 + 2696656524
88 ??? 0xa0bbb68c 0 + 2696656524
89 ??? 0xa0bbb68c 0 + 2696656524
90 ??? 0xa0bbb68c 0 + 2696656524
91 ??? 0xa0bbb68c 0 + 2696656524
92 ??? 0xa0bbb68c 0 + 2696656524
93 ??? 0xa0bbb68c 0 + 2696656524
94 ??? 0xa0bbb68c 0 + 2696656524
95 ??? 0xa0bbb68c 0 + 2696656524
96 ??? 0xa0bbb68c 0 + 2696656524
97 ??? 0xa0bbb68c 0 + 2696656524
98 ??? 0xa0bbb68c 0 + 2696656524
99 ??? 0xa0bbb68c 0 + 2696656524
100 ??? 0xa0bbb68c 0 + 2696656524
101 ??? 0xa0bbb68c 0 + 2696656524
102 ??? 0xa0bbb68c 0 + 2696656524
103 ??? 0xa0bbb68c 0 + 2696656524
104 ??? 0xa0bbb68c 0 + 2696656524
105 ??? 0xa0bbb68c 0 + 2696656524
106 ??? 0xa0bbb68c 0 + 2696656524
107 ??? 0xa0bbb68c 0 + 2696656524
108 ??? 0xa0bbb68c 0 + 2696656524
109 ??? 0xa0bbb68c 0 + 2696656524
110 ??? 0xa0bbb68c 0 + 2696656524
111 ??? 0xa0bbb68c 0 + 2696656524
112 ??? 0xa0bbb68c 0 + 2696656524
113 ??? 0xa0bbb68c 0 + 2696656524
114 ??? 0xa0bbb68c 0 + 2696656524
115 ??? 0xa0bbb68c 0 + 2696656524
116 ??? 0xa0bbb68c 0 + 2696656524
117 ??? 0xa0bbb68c 0 + 2696656524
118 ??? 0xa0bbb68c 0 + 2696656524
119 ??? 0xa0bbb68c 0 + 2696656524
120 ??? 0xa0bbb68c 0 + 2696656524
121 ??? 0xa0bbb68c 0 + 2696656524
122 ??? 0xa0bbb68c 0 + 2696656524
123 ??? 0xa0bbb68c 0 + 2696656524
124 ??? 0xa0bbb68c 0 + 2696656524
125 ??? 0xa0bbb68c 0 + 2696656524
126 ??? 0xa0bbb68c 0 + 2696656524
127 ??? 0xa0bbb68c 0 + 2696656524
128 ??? 0xa0bbb68c 0 + 2696656524
129 ??? 0xa0bbb68c 0 + 2696656524
130 ??? 0xa0bbb68c 0 + 2696656524
131 ??? 0xa0bbb68c 0 + 2696656524
132 ??? 0xa0bbb68c 0 + 2696656524
133 ??? 0xa0bbb68c 0 + 2696656524
134 ??? 0xa0bbb68c 0 + 2696656524
135 ??? 0xa0bbb68c 0 + 2696656524
136 ??? 0xa0bbb68c 0 + 2696656524
137 ??? 0xa0bbb68c 0 + 2696656524
138 ??? 0xa0bbb68c 0 + 2696656524
139 ??? 0xa0bbb68c 0 + 2696656524
140 ??? 0xa0bbb68c 0 + 2696656524
141 ??? 0xa0bbb68c 0 + 2696656524
142 ??? 0xa0bbb68c 0 + 2696656524
143 ??? 0xa0bbb68c 0 + 2696656524
144 ??? 0xa0bbb68c 0 + 2696656524
145 ??? 0xa0bbb68c 0 + 2696656524
146 ??? 0xa0bbb68c 0 + 2696656524
147 ??? 0xa0bbb68c 0 + 2696656524
148 ??? 0xa0bbb68c 0 + 2696656524
149 ??? 0xa0bbb68c 0 + 2696656524
150 ??? 0xa0bbb68c 0 + 2696656524
151 ??? 0xa0bbb68c 0 + 2696656524
152 ??? 0xa0bbb68c 0 + 2696656524
153 ??? 0xa0bbb68c 0 + 2696656524
154 ??? 0xa0bbb68c 0 + 2696656524
155 ??? 0xa0bbb68c 0 + 2696656524
156 ??? 0xa0bbb68c 0 + 2696656524
157 ??? 0xa0bbb68c 0 + 2696656524
158 ??? 0xa0bbb68c 0 + 2696656524
159 ??? 0xa0bbb68c 0 + 2696656524
160 ??? 0xa0bbb68c 0 + 2696656524
161 ??? 0xa0bbb68c 0 + 2696656524
162 ??? 0xa0bbb68c 0 + 2696656524
163 ??? 0xa0bbb68c 0 + 2696656524
164 ??? 0xa0bbb68c 0 + 2696656524
165 ??? 0xa0bbb68c 0 + 2696656524
166 ??? 0xa0bbb68c 0 + 2696656524
167 ??? 0xa0bbb68c 0 + 2696656524
168 ??? 0xa0bbb68c 0 + 2696656524
169 ??? 0xa0bbb68c 0 + 2696656524
170 ??? 0xa0bbb68c 0 + 2696656524
171 ??? 0xa0bbb68c 0 + 2696656524
172 ??? 0xa0bbb68c 0 + 2696656524
173 ??? 0xa0bbb68c 0 + 2696656524
174 ??? 0xa0bbb68c 0 + 2696656524
175 ??? 0xa0bbb68c 0 + 2696656524
176 ??? 0xa0bbb68c 0 + 2696656524
177 ??? 0xa0bbb68c 0 + 2696656524
178 ??? 0xa0bbb68c 0 + 2696656524
179 ??? 0xa0bbb68c 0 + 2696656524
180 ??? 0xa0bbb68c 0 + 2696656524
181 ??? 0xa0bbb68c 0 + 2696656524
182 ??? 0xa0bbb68c 0 + 2696656524
183 ??? 0xa0bbb68c 0 + 2696656524
184 ??? 0xa0bbb68c 0 + 2696656524
185 ??? 0xa0bbb68c 0 + 2696656524
186 ??? 0xa0bbb68c 0 + 2696656524
187 ??? 0xa0bbb68c 0 + 2696656524
188 ??? 0xa0bbb68c 0 + 2696656524
189 ??? 0xa0bbb68c 0 + 2696656524
190 ??? 0xa0bbb68c 0 + 2696656524
191 ??? 0xa0bbb68c 0 + 2696656524
192 ??? 0xa0bbb68c 0 + 2696656524
193 ??? 0xa0bbb68c 0 + 2696656524
194 ??? 0xa0bbb68c 0 + 2696656524
195 ??? 0xa0bbb68c 0 + 2696656524
196 ??? 0xa0bbb68c 0 + 2696656524
197 ??? 0xa0bbb68c 0 + 2696656524
198 ??? 0xa0bbb68c 0 + 2696656524
199 ??? 0xa0bbb68c 0 + 2696656524
200 ??? 0xa0bbb68c 0 + 2696656524
201 ??? 0xa0bbb68c 0 + 2696656524
202 ??? 0xa0bbb68c 0 + 2696656524
203 ??? 0xa0bbb68c 0 + 2696656524
204 ??? 0xa0bbb68c 0 + 2696656524
205 ??? 0xa0bbb68c 0 + 2696656524
206 ??? 0xa0bbb68c 0 + 2696656524
207 ??? 0xa0bbb68c 0 + 2696656524
208 ??? 0xa0bbb68c 0 + 2696656524
209 ??? 0xa0bbb68c 0 + 2696656524
210 ??? 0xa0bbb68c 0 + 2696656524
211 ??? 0xa0bbb68c 0 + 2696656524
212 ??? 0xa0bbb68c 0 + 2696656524
213 ??? 0xa0bbb68c 0 + 2696656524
214 ??? 0xa0bbb68c 0 + 2696656524
215 ??? 0xa0bbb68c 0 + 2696656524
216 ??? 0xa0bbb68c 0 + 2696656524
217 ??? 0xa0bbb68c 0 + 2696656524
218 ??? 0xa0bbb68c 0 + 2696656524
219 ??? 0xa0bbb68c 0 + 2696656524
220 ??? 0xa0bbb68c 0 + 2696656524
221 ??? 0xa0bbb68c 0 + 2696656524
222 ??? 0xa0bbb68c 0 + 2696656524
223 ??? 0xa0bbb68c 0 + 2696656524
224 ??? 0xa0bbb68c 0 + 2696656524
225 ??? 0xa0bbb68c 0 + 2696656524
226 ??? 0xa0bbb68c 0 + 2696656524
227 ??? 0xa0bbb68c 0 + 2696656524
228 ??? 0xa0bbb68c 0 + 2696656524
229 ??? 0xa0bbb68c 0 + 2696656524
230 ??? 0xa0bbb68c 0 + 2696656524
231 ??? 0xa0bbb68c 0 + 2696656524
232 ??? 0xa0bbb68c 0 + 2696656524
233 ??? 0xa0bbb68c 0 + 2696656524
234 ??? 0xa0bbb68c 0 + 2696656524
235 ??? 0xa0bbb68c 0 + 2696656524
236 ??? 0xa0bbb68c 0 + 2696656524
237 ??? 0xa0bbb68c 0 + 2696656524
238 ??? 0xa0bbb68c 0 + 2696656524
239 ??? 0xa0bbb68c 0 + 2696656524
240 ??? 0xa0bbb68c 0 + 2696656524
241 ??? 0xa0bbb68c 0 + 2696656524
242 ??? 0xa0bbb68c 0 + 2696656524
243 ??? 0xa0bbb68c 0 + 2696656524
244 ??? 0xa0bbb68c 0 + 2696656524
245 ??? 0xa0bbb68c 0 + 2696656524
246 ??? 0xa0bbb68c 0 + 2696656524
247 ??? 0xa0bbb68c 0 + 2696656524
248 ??? 0xa0bbb68c 0 + 2696656524
249 ??? 0xa0bbb68c 0 + 2696656524
250 ??? 0xa0bbb68c 0 + 2696656524
251 ??? 0xa0bbb68c 0 + 2696656524
252 ??? 0xa0bbb68c 0 + 2696656524
253 ??? 0xa0bbb68c 0 + 2696656524
254 ??? 0xa0bbb68c 0 + 2696656524
255 ??? 0xa0bbb68c 0 + 2696656524
256 ??? 0xa0bbb68c 0 + 2696656524
257 ??? 0xa0bbb68c 0 + 2696656524
258 ??? 0xa0bbb68c 0 + 2696656524
259 ??? 0xa0bbb68c 0 + 2696656524
260 ??? 0xa0bbb68c 0 + 2696656524
261 ??? 0xa0bbb68c 0 + 2696656524
262 ??? 0xa0bbb68c 0 + 2696656524
263 ??? 0xa0bbb68c 0 + 2696656524
264 ??? 0xa0bbb68c 0 + 2696656524
265 ??? 0xa0bbb68c 0 + 2696656524
266 ??? 0xa0bbb68c 0 + 2696656524
267 ??? 0xa0bbb68c 0 + 2696656524
268 ??? 0xa0bbb68c 0 + 2696656524
269 ??? 0xa0bbb68c 0 + 2696656524
270 ??? 0xa0bbb68c 0 + 2696656524
271 ??? 0xa0bbb68c 0 + 2696656524
272 ??? 0xa0bbb68c 0 + 2696656524
273 ??? 0xa0bbb68c 0 + 2696656524
274 ??? 0xa0bbb68c 0 + 2696656524
275 ??? 0xa0bbb68c 0 + 2696656524
276 ??? 0xa0bbb68c 0 + 2696656524
277 ??? 0xa0bbb68c 0 + 2696656524
278 ??? 0xa0bbb68c 0 + 2696656524
279 ??? 0xa0bbb68c 0 + 2696656524
280 ??? 0xa0bbb68c 0 + 2696656524
281 ??? 0xa0bbb68c 0 + 2696656524
282 ??? 0xa0bbb68c 0 + 2696656524
283 ??? 0xa0bbb68c 0 + 2696656524
284 ??? 0xa0bbb68c 0 + 2696656524
285 ??? 0xa0bbb68c 0 + 2696656524
286 ??? 0xa0bbb68c 0 + 2696656524
287 ??? 0xa0bbb68c 0 + 2696656524
288 ??? 0xa0bbb68c 0 + 2696656524
289 ??? 0xa0bbb68c 0 + 2696656524
290 ??? 0xa0bbb68c 0 + 2696656524
291 ??? 0xa0bbb68c 0 + 2696656524
292 ??? 0xa0bbb68c 0 + 2696656524
293 ??? 0xa0bbb68c 0 + 2696656524
294 ??? 0xa0bbb68c 0 + 2696656524
295 ??? 0xa0bbb68c 0 + 2696656524
296 ??? 0xa0bbb68c 0 + 2696656524
297 ??? 0xa0bbb68c 0 + 2696656524
298 ??? 0xa0bbb68c 0 + 2696656524
299 ??? 0xa0bbb68c 0 + 2696656524
300 ??? 0xa0bbb68c 0 + 2696656524
301 ??? 0xa0bbb68c 0 + 2696656524
302 ??? 0xa0bbb68c 0 + 2696656524
303 ??? 0xa0bbb68c 0 + 2696656524
304 ??? 0xa0bbb68c 0 + 2696656524
305 ??? 0xa0bbb68c 0 + 2696656524
306 ??? 0xa0bbb68c 0 + 2696656524
307 ??? 0xa0bbb68c 0 + 2696656524
308 ??? 0xa0bbb68c 0 + 2696656524
309 ??? 0xa0bbb68c 0 + 2696656524
310 ??? 0xa0bbb68c 0 + 2696656524
311 ??? 0xa0bbb68c 0 + 2696656524
312 ??? 0xa0bbb68c 0 + 2696656524
313 ??? 0xa0bbb68c 0 + 2696656524
314 ??? 0xa0bbb68c 0 + 2696656524
315 ??? 0xa0bbb68c 0 + 2696656524
316 ??? 0xa0bbb68c 0 + 2696656524
317 ??? 0xa0bbb68c 0 + 2696656524
318 ??? 0xa0bbb68c 0 + 2696656524
319 ??? 0xa0bbb68c 0 + 2696656524
320 ??? 0xa0bbb68c 0 + 2696656524
321 ??? 0xa0bbb68c 0 + 2696656524
322 ??? 0xa0bbb68c 0 + 2696656524
323 ??? 0xa0bbb68c 0 + 2696656524
324 ??? 0xa0bbb68c 0 + 2696656524
325 ??? 0xa0bbb68c 0 + 2696656524
326 ??? 0xa0bbb68c 0 + 2696656524
327 ??? 0xa0bbb68c 0 + 2696656524
328 ??? 0xa0bbb68c 0 + 2696656524
329 ??? 0xa0bbb68c 0 + 2696656524
330 ??? 0xa0bbb68c 0 + 2696656524
331 ??? 0xa0bbb68c 0 + 2696656524
332 ??? 0xa0bbb68c 0 + 2696656524
333 ??? 0xa0bbb68c 0 + 2696656524
334 ??? 0xa0bbb68c 0 + 2696656524
335 ??? 0xa0bbb68c 0 + 2696656524
336 ??? 0xa0bbb68c 0 + 2696656524
337 ??? 0xa0bbb68c 0 + 2696656524
338 ??? 0xa0bbb68c 0 + 2696656524
339 ??? 0xa0bbb68c 0 + 2696656524
340 ??? 0xa0bbb68c 0 + 2696656524
341 ??? 0xa0bbb68c 0 + 2696656524
342 ??? 0xa0bbb68c 0 + 2696656524
343 ??? 0xa0bbb68c 0 + 2696656524
344 ??? 0xa0bbb68c 0 + 2696656524
345 ??? 0xa0bbb68c 0 + 2696656524
346 ??? 0xa0bbb68c 0 + 2696656524
347 ??? 0xa0bbb68c 0 + 2696656524
348 ??? 0xa0bbb68c 0 + 2696656524
349 ??? 0xa0bbb68c 0 + 2696656524
350 ??? 0xa0bbb68c 0 + 2696656524
351 ??? 0xa0bbb68c 0 + 2696656524
352 ??? 0xa0bbb68c 0 + 2696656524
353 ??? 0xa0bbb68c 0 + 2696656524
354 ??? 0xa0bbb68c 0 + 2696656524
355 ??? 0xa0bbb68c 0 + 2696656524
356 ??? 0xa0bbb68c 0 + 2696656524
357 ??? 0xa0bbb68c 0 + 2696656524
358 ??? 0xa0bbb68c 0 + 2696656524
359 ??? 0xa0bbb68c 0 + 2696656524
360 ??? 0xa0bbb68c 0 + 2696656524
361 ??? 0xa0bbb68c 0 + 2696656524
362 ??? 0xa0bbb68c 0 + 2696656524
363 ??? 0xa0bbb68c 0 + 2696656524
364 ??? 0xa0bbb68c 0 + 2696656524
365 ??? 0xa0bbb68c 0 + 2696656524
366 ??? 0xa0bbb68c 0 + 2696656524
367 ??? 0xa0bbb68c 0 + 2696656524
368 ??? 0xa0bbb68c 0 + 2696656524
369 ??? 0xa0bbb68c 0 + 2696656524
370 ??? 0xa0bbb68c 0 + 2696656524
371 ??? 0xa0bbb68c 0 + 2696656524
372 ??? 0xa0bbb68c 0 + 2696656524
373 ??? 0xa0bbb68c 0 + 2696656524
374 ??? 0xa0bbb68c 0 + 2696656524
375 ??? 0xa0bbb68c 0 + 2696656524
376 ??? 0xa0bbb68c 0 + 2696656524
377 ??? 0xa0bbb68c 0 + 2696656524
378 ??? 0xa0bbb68c 0 + 2696656524
379 ??? 0xa0bbb68c 0 + 2696656524
380 ??? 0xa0bbb68c 0 + 2696656524
381 ??? 0xa0bbb68c 0 + 2696656524
382 ??? 0xa0bbb68c 0 + 2696656524
383 ??? 0xa0bbb68c 0 + 2696656524
384 ??? 0xa0bbb68c 0 + 2696656524
385 ??? 0xa0bbb68c 0 + 2696656524
386 ??? 0xa0bbb68c 0 + 2696656524
387 ??? 0xa0bbb68c 0 + 2696656524
388 ??? 0xa0bbb68c 0 + 2696656524
389 ??? 0xa0bbb68c 0 + 2696656524
390 ??? 0xa0bbb68c 0 + 2696656524
391 ??? 0xa0bbb68c 0 + 2696656524
392 ??? 0xa0bbb68c 0 + 2696656524
393 ??? 0xa0bbb68c 0 + 2696656524
394 ??? 0xa0bbb68c 0 + 2696656524
395 ??? 0xa0bbb68c 0 + 2696656524
396 ??? 0xa0bbb68c 0 + 2696656524
397 ??? 0xa0bbb68c 0 + 2696656524
398 ??? 0xa0bbb68c 0 + 2696656524
399 ??? 0xa0bbb68c 0 + 2696656524
400 ??? 0xa0bbb68c 0 + 2696656524
401 ??? 0xa0bbb68c 0 + 2696656524
402 ??? 0xa0bbb68c 0 + 2696656524
403 ??? 0xa0bbb68c 0 + 2696656524
404 ??? 0xa0bbb68c 0 + 2696656524
405 ??? 0xa0bbb68c 0 + 2696656524
406 ??? 0xa0bbb68c 0 + 2696656524
407 ??? 0xa0bbb68c 0 + 2696656524
408 ??? 0xa0bbb68c 0 + 2696656524
409 ??? 0xa0bbb68c 0 + 2696656524
410 ??? 0xa0bbb68c 0 + 2696656524
411 ??? 0xa0bbb68c 0 + 2696656524
412 ??? 0xa0bbb68c 0 + 2696656524
413 ??? 0xa0bbb68c 0 + 2696656524
414 ??? 0xa0bbb68c 0 + 2696656524
415 ??? 0xa0bbb68c 0 + 2696656524
416 ??? 0xa0bbb68c 0 + 2696656524
417 ??? 0xa0bbb68c 0 + 2696656524
418 ??? 0xa0bbb68c 0 + 2696656524
419 ??? 0xa0bbb68c 0 + 2696656524
420 ??? 0xa0bbb68c 0 + 2696656524
421 ??? 0xa0bbb68c 0 + 2696656524
422 ??? 0xa0bbb68c 0 + 2696656524
423 ??? 0xa0bbb68c 0 + 2696656524
424 ??? 0xa0bbb68c 0 + 2696656524
425 ??? 0xa0bbb68c 0 + 2696656524
426 ??? 0xa0bbb68c 0 + 2696656524
427 ??? 0xa0bbb68c 0 + 2696656524
428 ??? 0xa0bbb68c 0 + 2696656524
429 ??? 0xa0bbb68c 0 + 2696656524
430 ??? 0xa0bbb68c 0 + 2696656524
431 ??? 0xa0bbb68c 0 + 2696656524
432 ??? 0xa0bbb68c 0 + 2696656524
433 ??? 0xa0bbb68c 0 + 2696656524
434 ??? 0xa0bbb68c 0 + 2696656524
435 ??? 0xa0bbb68c 0 + 2696656524
436 ??? 0xa0bbb68c 0 + 2696656524
437 ??? 0xa0bbb68c 0 + 2696656524
438 ??? 0xa0bbb68c 0 + 2696656524
439 ??? 0xa0bbb68c 0 + 2696656524
440 ??? 0xa0bbb68c 0 + 2696656524
441 ??? 0xa0bbb68c 0 + 2696656524
442 ??? 0xa0bbb68c 0 + 2696656524
443 ??? 0xa0bbb68c 0 + 2696656524
444 ??? 0xa0bbb68c 0 + 2696656524
445 ??? 0xa0bbb68c 0 + 2696656524
446 ??? 0xa0bbb68c 0 + 2696656524
447 ??? 0xa0bbb68c 0 + 2696656524
448 ??? 0xa0bbb68c 0 + 2696656524
449 ??? 0xa0bbb68c 0 + 2696656524
450 ??? 0xa0bbb68c 0 + 2696656524
451 ??? 0xa0bbb68c 0 + 2696656524
452 ??? 0xa0bbb68c 0 + 2696656524
453 ??? 0xa0bbb68c 0 + 2696656524
454 ??? 0xa0bbb68c 0 + 2696656524
455 ??? 0xa0bbb68c 0 + 2696656524
456 ??? 0xa0bbb68c 0 + 2696656524
457 ??? 0xa0bbb68c 0 + 2696656
Roger Bolton
on Apr 1, 2010 at 10:34:44 am
hi, that doesn't tell us which graphic card you have etc. Can you please send us the system profile to support at coremelt dot com ? Also can you please tell us which sequence setting you are using in final cut pro? eg size and codec settings?
System Profile:
In all cases we need a system profile in order to diagnose your problem. To generate a system profile go to "about this mac" from the Apple Menu then click the "More Info..." button. This will start the system profiler application. Then go to the "File" menu and select "save as" and save the complete system profile in "System Profiler 4.0 (XML)" format.
CoreMelt V2 plugins
Lawrence Gray
on Apr 1, 2010 at 11:00:05 am
Ah, I see it's cut off half the report.... All the system settings are at the bottom. Let's see if this gives you everything.
Thread 62:
3 com.apple.AppleHDVCodec 0x0dfde26c MPEG2CompressorComponentDispatch + 199756
4 ??? 0x00000002 0 + 2
Thread 63:
Thread 64:
Thread 65:
Thread 66:
Thread 67:
Thread 68:
Thread 69:
Thread 70:
Thread 71:
Thread 72:
Thread 73:
Thread 74:
Thread 75:
Thread 76:
Thread 77:
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0x00000000 ebx: 0x6fdae000 ecx: 0x710ca360 edx: 0x00000000
edi: 0x00000000 esi: 0x64740988 ebp: 0xbfff2708 esp: 0xbfff26d0
ss: 0x0000001f efl: 0x00010282 eip: 0x8f4a4592 cs: 0x00000017
ds: 0x0000001f es: 0x0000001f fs: 0x00000000 gs: 0x00000037
cr2: 0x00000000
Binary Images:
0x1000 - 0x86effc com.apple.FinalCutPro 7.0.2 (7.0.2) <798C4919-4F7E-CF10-D3A1-4E6F50C55590> /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
0xc2b000 - 0xc2eff7 +KGCore ??? (???) <205C3813-554F-83C4-5296-6B828E9FDBF4> /Applications/Final Cut Pro.app/Contents/Frameworks/KGCore.framework/Versions/A/KGCore
0xc36000 - 0xc36ff7 com.apple.iokit.dvcomponentglue 1.9.9 (1.9.9) <2BA05DB9-D847-CBC7-42D6-A9D96D7E1ED2> /System/Library/Frameworks/DVComponentGlue.framework/Versions/A/DVComponentGlue
0xc3a000 - 0xc49fff com.apple.AERegistration 1.2 (77) <74F5B9FE-53AC-977E-E761-C54D3BF6FD8B> /Applications/Final Cut Pro.app/Contents/Frameworks/AERegistration.framework/Versions/A/AERegistration
0xc5d000 - 0xc64fff com.apple.AEProfiling 1.2 (22) <1C4A8D43-1125-D71F-414C-78FE8EA39242> /Applications/Final Cut Pro.app/Contents/Frameworks/AEProfiling.framework/Versions/A/AEProfiling
0xc6e000 - 0xe22feb com.apple.prokit 5.1 (917) /System/Library/PrivateFrameworks/ProKit.framework/Versions/A/ProKit
0xee1000 - 0xf53fef com.apple.ProFX 1.2.3 (1.2.3) /Library/Application Support/ProApps/SharedA/Frameworks/ProFX.framework/Versions/A/ProFX
0xf75000 - 0xfd0ffb com.apple.proapps.MIO 1.0.4 (505) /Applications/Final Cut Pro.app/Contents/Frameworks/MIO.framework/Versions/A/MIO
0x100c000 - 0x1015ff7 com.apple.finalcutstudio.prometadatasupport 0.6 (1.0) /Library/Frameworks/ProMetadataSupport.framework/Versions/A/ProMetadataSupport
0x101d000 - 0x1057fff com.apple.CoreMediaIOServicesPrivate 30.0 (1001) <787F4EEC-A9D7-B287-D32A-6EEF8A9A4499> /System/Library/PrivateFrameworks/CoreMediaIOServicesPrivate.framework/Versions/A/CoreMediaIOServicesPrivate
0x1073000 - 0x109cff7 com.apple.CoreMediaPrivate 20.0 (20.0) <29A9848F-2C1C-BDE4-EADC-2A3C71C1DBC4> /System/Library/PrivateFrameworks/CoreMediaPrivate.framework/Versions/A/CoreMediaPrivate
0x10af000 - 0x10e2ff3 com.apple.FWAVCPrivate 30.46 (46) <1BAC4562-7515-4CE2-FECE-82D9774D2A24> /System/Library/PrivateFrameworks/FWAVCPrivate.framework/Versions/A/FWAVCPrivate
0x10f7000 - 0x1115fef com.apple.XSKey 1.0.0 (52) <71B94F53-15DB-9012-91F2-211F7C2CD790> /Library/Frameworks/XSKey.framework/Versions/A/XSKey
0x1124000 - 0x11d9fe7 libcrypto.0.9.7.dylib 0.9.7 (compatibility 0.9.7) <0B69B1F5-3440-B0BF-957F-E0ADD49F13CB> /usr/lib/libcrypto.0.9.7.dylib
0x12ad000 - 0x12adff0 +com.google.GearsEnabler ??? (1.0) /Library/InputManagers/GearsEnabler/GearsEnabler.bundle/Contents/MacOS/GearsEnabler
0x12e5000 - 0x12eaffb com.apple.AppleMPEG2Codec 1.0.1 (220) /Library/QuickTime/AppleMPEG2Codec.component/Contents/MacOS/AppleMPEG2Codec
0x3d59000 - 0x3d99ff7 com.apple.vmutils 4.2 (106) <834EA6B0-C91B-4CF1-ED3C-229C26459578> /System/Library/PrivateFrameworks/vmutils.framework/vmutils
0x3f95000 - 0x3f9dff7 com.apple.proapps.mrcheckpro 1.4 (385) <400C6D0F-2AC3-F06D-E20C-741BA3D9A558> /Applications/Final Cut Pro.app/Contents/Resources/MRCheckPro.bundle/Contents/MacOS/MRCheckPro
0x4a07000 - 0x4a0bff3 com.apple.FinalCutPro.Plugins.AudioGroupsExport 7.0.2 (7.0.2) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/AudioGroupsExport.bundle/Contents/MacOS/AudioGroupsExport
0x4a10000 - 0x4a11fff com.apple.FinalCutPro.Plugins.Text Window 7.0.2 (7.0.2) <002BDA0C-5BB5-C8F7-184A-7E41ADDCAB50> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Text Window.bundle/Contents/MacOS/Text Window
0x4a2a000 - 0x4a2ffff com.apple.FinalCutPro.Plugins.Cache Manager 7.0.2 (7.0.2) <55995573-0844-F029-DF7C-0121FF263603> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Cache Manager.bundle/Contents/MacOS/Cache Manager
0x4a34000 - 0x4a35ffb com.apple.FinalCutPro.Plugins.Vector Accelerator 7.0.2 (7.0.2) <35076643-AB9F-7D6A-7828-929E148C0784> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Vector Accelerator.bundle/Contents/MacOS/Vector Accelerator
0x4aa4000 - 0x4aa6ff7 libclparser.dylib ??? (???) <0585F11B-F4FD-05DC-C7CE-556B0539E003> /System/Library/Frameworks/OpenCL.framework/Libraries/libclparser.dylib
0x4aab000 - 0x4aafff7 libcldcpuengine.dylib 1.3.38 (compatibility 1.0.0) <60B4CED7-D47B-4CB4-B044-49493340302F> /System/Library/Frameworks/OpenCL.framework/Libraries/libcldcpuengine.dylib
0x87f5000 - 0x87f8ffc com.apple.FinalCutPro.Plugins.FinalTouchExport 7.0.2 (7.0.2) <57112D8A-CB19-2E55-07F2-97DB5A63C006> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FinalTouchExport.bundle/Contents/MacOS/FinalTouchExport
0x8be8000 - 0x8bf2ff9 com.apple.FinalCutPro.Plugins.CTHelper 7.0.2 (7.0.2) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/CTHelper.bundle/Contents/MacOS/CTHelper
0x8bf9000 - 0x8bf9ff7 libmx.A.dylib 315.0.0 (compatibility 1.0.0) <01401BF8-3FC7-19CF-ACCE-0F292BFD2F25> /usr/lib/libmx.A.dylib
0x8f29000 - 0x8f4cfe7 GLRendererFloat ??? (???) <65E1E174-28E0-3FA9-E391-504891B69818> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFloat
0x8f54000 - 0x8f5cff7 com.apple.QuartzComposer.QCMotionPatch 1.0 (726) <6D783F3E-91E0-3DDE-BDC7-B84E2DC593AB> /Library/Application Support/ProApps/SharedA/Plug-Ins/ProFX/QCMotionPatch.plugin/Contents/MacOS/QCMotionPatch
0x8f64000 - 0x8f65fff com.apple.FxHeliumImage 4.0.0 (1.0) <61516468-63B8-0FDE-822A-73985B6A462E> /Library/Application Support/ProApps/SharedA/Frameworks/FxHeliumImage.framework/Versions/A/FxHeliumImage
0x8f76000 - 0x8f77ff7 com.apple.Helium 3.0.2 (352) <74B9D860-0A0E-6000-063B-57B035CF9CF4> /Library/Application Support/ProApps/SharedA/Frameworks/Helium.framework/Versions/A/Helium
0x8f7e000 - 0x8f80fff com.apple.Helium.HCache 2.1.0 (352) /Library/Application Support/ProApps/SharedA/Frameworks/Helium.framework/Plug-ins/HCache.bundle/Contents/MacOS/HCache
0x8f85000 - 0x8fafff7 com.apple.FinalCutPro.Plugins.AfterEffects 7.0.2 (7.0.2) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/AfterEffects.bundle/Contents/MacOS/AfterEffects
0x8fb7000 - 0x8fceff3 com.apple.FinalCutPro.Plugins.AudioMixer 7.0.2 (7.0.2) <9CB9DCA9-5839-684B-7BEE-132F3DB0293B> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/AudioMixer.bundle/Contents/MacOS/AudioMixer
0x8fd9000 - 0x8ff3fff com.apple.FinalCutPro.CinemaTools 5.0 (5.0) <599FC934-E4ED-C2CE-148C-593639A68236> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Cinema Tools.bundle/Contents/MacOS/Cinema Tools
0xbefb000 - 0xc06efe7 GLEngine ??? (???) /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
0xc0a0000 - 0xc4a4fe7 libclh.dylib 3.1.1 C (3.1.1) /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/libclh.dylib
0xc4c8000 - 0xc514fff com.apple.audio.midi.CoreMIDI 1.7 (42) <670CB7F9-AA00-86F3-6623-E1335F7AEA83> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0xc539000 - 0xc563feb com.apple.proapps.ControlSurfaceSupport 2.0 (68) <77CD2C68-D73B-8799-3C36-3DD5BC93EE1D> /Applications/Final Cut Pro.app/Contents/Frameworks/ControlSurfaceSupport.framework/Versions/A/ControlSurfaceSupport
0xc584000 - 0xc65cff2 com.apple.FinalCutPro.Plugins.Browser 7.0.2 (7.0.2) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Browser.bundle/Contents/MacOS/Browser
0xc67a000 - 0xc6a0ff7 com.apple.FinalCutPro.Plugins.EditTape 7.0.2 (7.0.2) <093284C2-2C9F-3A02-6D5D-586CB3EBE67B> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/EditTape.bundle/Contents/MacOS/EditTape
0xc6af000 - 0xc70aff5 com.apple.FinalCutPro.Plugins.EDL Export 7.0.2 (7.0.2) <0F073990-E3D9-B163-2658-621B6E110AEC> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/EDL Export.bundle/Contents/MacOS/EDL Export
0xc71f000 - 0xc727fff com.apple.FinalCutPro.Plugins.Effect Builder 7.0.2 (7.0.2) <8DEE7DCB-619F-3DAD-F520-987F34385AF2> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Effect Builder.bundle/Contents/MacOS/Effect Builder
0xc72c000 - 0xc737ffe com.apple.FinalCutPro.Plugins.FCPExtPluginSupport 7.0.2 (7.0.2) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FCPExtPluginSupport.bundle/Contents/MacOS/FCPExtPluginSupport
0xc740000 - 0xc773ff7 com.apple.FinalCutPro.Plugins.FCS Engine 7.0.2 (7.0.2) <5FA30F26-46B3-F4B9-9215-838AD704FAA1> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FCS Engine.bundle/Contents/MacOS/FCS Engine
0xc77d000 - 0xc78eff7 com.apple.FinalCutPro.Plugins.FilterCustomEd 7.0.2 (7.0.2) <4E43B05A-3920-46E9-D60E-FE632543A1B4> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FilterCustomEd.bundle/Contents/MacOS/FilterCustomEd
0xc794000 - 0xc7a9ffb com.apple.FinalCutPro.Plugins.FilterViewer 7.0.2 (7.0.2) <126CD2BD-3638-9DF7-B234-DA3B5482A20A> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FilterViewer.bundle/Contents/MacOS/FilterViewer
0xc7af000 - 0xc7cdfea com.apple.FinalCutPro.Plugins.Flash 7.0.2 (7.0.2) <982413E7-AC78-6FDA-B157-A650FBE3B8EB> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Flash.bundle/Contents/MacOS/Flash
0xc7d9000 - 0xc7e6ffb com.apple.FinalCutPro.Plugins.GenViewer 7.0.2 (7.0.2) <236D3F92-F0B2-4A10-971E-C5337DB4C53C> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/GenViewer.bundle/Contents/MacOS/GenViewer
0xc7ec000 - 0xc7f0fff com.apple.FinalCutPro.Plugins.LayerFileReader 7.0.2 (7.0.2) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/LayerFileReader.bundle/Contents/MacOS/LayerFileReader
0xc7f5000 - 0xc841ff3 com.apple.FinalCutPro.Plugins.Media Manager 7.0.2 (7.0.2) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Media Manager.bundle/Contents/MacOS/Media Manager
0xc84b000 - 0xc85dff0 com.apple.FinalCutPro.Plugins.MolokiniSupport 7.0.2 (7.0.2) <54E6677D-B612-EF15-187D-31BF6C1EA1BE> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/MolokiniSupport.bundle/Contents/MacOS/MolokiniSupport
0xc86c000 - 0xc880fff com.apple.FinalCutPro.Frameworks.MolokiniTranslation 1.0 (1.0) /Applications/Final Cut Pro.app/Contents/Frameworks/MolokiniTranslation.framework/Versions/A/MolokiniTranslation
0xc88e000 - 0xc8c0ffb com.apple.FinalCutPro.Plugins.Motion Viewer 7.0.2 (7.0.2) <1929A255-6B40-50E7-8FE2-5635C0D44D0D> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Motion Viewer.bundle/Contents/MacOS/Motion Viewer
0xc8d1000 - 0xc8ecff3 com.apple.FinalCutPro.Plugins.Movie Analyzer 7.0.2 (7.0.2) <7FC31192-D13E-F784-4B4D-470C5738A3A9> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Movie Analyzer.bundle/Contents/MacOS/Movie Analyzer
0xc8fb000 - 0xc911ffb com.apple.FinalCutPro.Plugins.Movie Viewer 7.0.2 (7.0.2) <194FEDCD-1510-CA82-2A90-276EA01A84A9> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Movie Viewer.bundle/Contents/MacOS/Movie Viewer
0xc91d000 - 0xc921fff com.apple.FinalCutPro.Plugins.NuggetExport 7.0.2 (7.0.2) <84D509CE-011F-D2E2-AEA4-967FE9E58F37> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/NuggetExport.bundle/Contents/MacOS/NuggetExport
0xc926000 - 0xc9dffe7 com.apple.FinalCutPro.Plugins.OMF Audio Export 7.0.2 (7.0.2) <7F118A9C-6A78-79F1-F09B-495AEB916E8E> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/OMF Audio Export.bundle/Contents/MacOS/OMF Audio Export
0xc9f2000 - 0xc9faffb com.apple.FinalCutPro.Plugins.Perf Analyzer 7.0.2 (7.0.2) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Perf Analyzer.bundle/Contents/MacOS/Perf Analyzer
0xc9ff000 - 0xca14ffb com.apple.FinalCutPro.Plugins.ProAppsIntegration 7.0.2 (7.0.2) <0470D6B4-8C5B-BA0E-94B5-2D617ABFA460> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/ProAppsIntegration.bundle/Contents/MacOS/ProAppsIntegration
0xca24000 - 0xca31ff7 com.apple.FinalCutPro.Plugins.Pulldown Support 7.0.2 (7.0.2) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Pulldown Support.bundle/Contents/MacOS/Pulldown Support
0xca39000 - 0xca78fef com.apple.FinalCutPro.Plugins.QTM Reader 7.0.2 (7.0.2) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/QTM Reader.bundle/Contents/MacOS/QTM Reader
0xca85000 - 0xca8dff3 com.apple.FinalCutPro.Plugins.QuickView 7.0.2 (7.0.2) <262D811B-6573-71B8-705F-AC2A29551710> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/QuickView.bundle/Contents/MacOS/QuickView
0xca92000 - 0xcaa2ffe com.apple.FinalCutPro.Plugins.Relink Media 7.0.2 (7.0.2) <6881FEE3-C19A-DBB9-35AA-2BFE9D0DA1DE> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Relink Media.bundle/Contents/MacOS/Relink Media
0xcaa9000 - 0xcb42ff2 com.apple.FinalCutPro.Plugins.Timeline Editor 7.0.2 (7.0.2) <6C92776E-CBBD-E35B-9AF1-CA738B2B9E68> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Timeline Editor.bundle/Contents/MacOS/Timeline Editor
0xcb51000 - 0xcb62fff com.apple.FinalCutPro.Plugins.Transcoder 7.0.2 (7.0.2) <1A18CAFA-C20F-F774-58E4-622647A049F8> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Transcoder.bundle/Contents/MacOS/Transcoder
0xcb6c000 - 0xcb7efff com.apple.FinalCutPro.Plugins.Transition Viewer 7.0.2 (7.0.2) <6E801C26-38DE-B363-6D75-70FD7E7573E2> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Transition Viewer.bundle/Contents/MacOS/Transition Viewer
0xcb84000 - 0xcb99ff3 com.apple.FinalCutPro.Plugins.Trimming 7.0.2 (7.0.2) <8491270E-D885-A7D9-FEFB-4DDDC7F75EA4> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Trimming.bundle/Contents/MacOS/Trimming
0xcb9f000 - 0xcba5ffb com.apple.FinalCutPro.Plugins.VDUSupport 7.0.2 (7.0.2) <4743B15F-7731-E1E8-731A-5A04234EB7ED> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/VDUSupport.bundle/Contents/MacOS/VDUSupport
0xcbab000 - 0xcbbcfff com.apple.FinalCutPro.Plugins.VideoLog 7.0.2 (7.0.2) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/VideoLog.bundle/Contents/MacOS/VideoLog
0xcbc1000 - 0xcbd9ff7 com.apple.FinalCutPro.Plugins.VoiceOver 7.0.2 (7.0.2) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/VoiceOver.bundle/Contents/MacOS/VoiceOver
0xcbe0000 - 0xcc5dfe1 com.apple.FinalCutPro.Plugins.XML Support 7.0.2 (7.0.2) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/XML Support.bundle/Contents/MacOS/XML Support
0xd0a9000 - 0xd0bafe7 com.apple.FCP Uncompressed 422.component 1.6.1 (1.6.1) <62C290FB-2735-60C4-CE88-7ECB0DE6EDB3> /Library/QuickTime/FCP Uncompressed 422.component/Contents/MacOS/FCP Uncompressed 422
0xd0c1000 - 0xd0d0ff7 com.apple.QuartzComposer.FxPlugWrapper 1.2.3 (92) <3D2D2F90-9650-B74F-7A2A-71823C99B76F> /Library/Application Support/ProApps/SharedA/Plug-Ins/ProFX/FxPlugWrapper.plugin/Contents/MacOS/FxPlugWrapper
0xd0fb000 - 0xd0fbffc com.apple.qmaster.swamp 3.5.2 (3.5.2) /Library/Frameworks/Qmaster.framework/Versions/A/Qmaster
0xd314000 - 0xd316ff3 com.apple.LiveType.component 2.1.4 (2.1.4) /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType
0xd31c000 - 0xd380fe2 com.apple.LiveType.framework 2.1.4 (2.1.4) <7AABA687-4323-E5B9-BA04-8F61C217E6FD> /Library/Application Support/ProApps/SharedA/Frameworks/LiveType.framework/Versions/A/LiveType
0xd3a0000 - 0xd3e6ffb com.apple.motion.component 1.0 (726) /Library/QuickTime/Motion.component/Contents/MacOS/Motion
0xd3ec000 - 0xd3eeff7 Motion 726.0.0 (compatibility 1.0.0) <4377AE39-7E6B-D0E0-356E-6F3C92EBE405> /Library/Frameworks/Motion.framework/Versions/A/Motion
0xd3f4000 - 0xd3f8ff3 com.apple.SmoothCamFxPlug 1.0.1 (1.0.1) /Library/Application Support/ProApps/SharedA/Plug-Ins/FxPlug/SmoothCam.fxplug/Contents/MacOS/SmoothCam
0xd600000 - 0xd69dff8 com.apple.procore.framework 4.0.2 (757) /Library/Application Support/ProApps/SharedA/Frameworks/ProCore.framework/Versions/A/ProCore
0xd6dd000 - 0xd6f1fef com.apple.fcp.DVOutputUnit 1.3 (1.3) <156B59D8-9E55-13E7-B63E-78C8E85AB776> /Applications/Final Cut Pro.app/Contents/Resources/DVOutputUnit.bundle/Contents/MacOS/DVOutputUnit
0xda65000 - 0xdad2fe7 com.apple.AppleProResCodec 2.0 (224) /Library/QuickTime/AppleProResCodec.component/Contents/MacOS/AppleProResCodec
0xdb1f000 - 0xdf05fe3 QuickTimeH264.scalar ??? (???) <0ECC6914-A78A-B884-C27D-1B1C156A40DC> /System/Library/QuickTime/QuickTimeH264.component/Contents/Resources/QuickTimeH264.scalar
0xdf61000 - 0xdf98fe7 com.apple.DVCPROHDCodec 1.5 (237) <5BA42205-5AEE-73BB-A7DE-5417EF028D5B> /Library/QuickTime/DVCPROHDCodec.component/Contents/MacOS/DVCPROHDCodec
0xdfa8000 - 0xe057fe3 com.apple.AppleHDVCodec 1.5 (228) <8D2121A0-BA53-28A2-C9A5-3BED137701DA> /Library/QuickTime/AppleHDVCodec.component/Contents/MacOS/AppleHDVCodec
0xe07f000 - 0xe099ffb com.apple.AppleIntermediateCodec 1.3.1 (152) /Library/QuickTime/AppleIntermediateCodec.component/Contents/MacOS/AppleIntermediateCodec
0xe09f000 - 0xe0b2fe3 com.apple.IMXCodec 1.4 (155) /Library/QuickTime/IMXCodec.component/Contents/MacOS/IMXCodec
0xe0c4000 - 0xe0ddfe7 com.apple.applepixletvideo 1.2.19 (1.2d19) <4A68731C-8071-6CF5-012C-40F00CD1333A> /System/Library/QuickTime/ApplePixletVideo.component/Contents/MacOS/ApplePixletVideo
0xe0e2000 - 0xe11efe3 com.apple.QuickTimeFireWireDV.component 7.6.6 (1729) /System/Library/QuickTime/QuickTimeFireWireDV.component/Contents/MacOS/QuickTimeFireWireDV
0xe1a2000 - 0xe1c6ff7 com.apple.AppleAVCIntraCodec 1.0 (16) <8A1A4CEE-1610-EECE-74DA-D2AF42825E6D> /Library/QuickTime/AppleAVCIntraCodec.component/Contents/MacOS/AppleAVCIntraCodec
0xe1d1000 - 0xe1d5ff3 com.apple.audio.AudioIPCPlugIn 1.1.2 (1.1.2) /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/Contents/MacOS/AudioIPCPlugIn
0xe1da000 - 0xe1e0ffb com.apple.audio.AppleHDAHALPlugIn 1.8.4 (1.8.4fc3) <89AF8F46-15E4-2066-BDDB-05E92C1368D4> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0xe1e5000 - 0xe1f0ff0 com.apple.fcp.TundraOutputUnit 1.3.1 (1.3.1) <1CCDD5F7-17C6-9849-6079-55511B4F8407> /Applications/Final Cut Pro.app/Contents/Resources/TundraOutputUnit.bundle/Contents/MacOS/TundraOutputUnit
0xe1f9000 - 0xe204ff7 com.apple.DVCPROHDVideoOutput 1.3.2 (1.3.2) <8D8A75CC-6204-1187-04CC-B3323E76DCF9> /Library/QuickTime/DVCPROHDVideoOutput.component/Contents/MacOS/DVCPROHDVideoOutput
0xe20c000 - 0xe218fff com.apple.FinalCutPro.iChatTheaterPreview 1.0 (195) /Library/QuickTime/iChatTheaterPreview.component/Contents/MacOS/iChatTheaterPreview
0xe292000 - 0xe2cafff com.apple.motion.MotionBundle 4.0.2 (726) <28643F46-A8E1-8E3E-09D2-815C4FB2A210> /Library/Application Support/ProApps/Bundles/Motion.bundle/Contents/MacOS/Motion
0xe2de000 - 0xe2eafff com.apple.PluginManager 1.7.3 (34) <13CD3A05-A00C-4FA7-AD61-2A706A67E390> /Library/Frameworks/PluginManager.framework/Versions/B/PluginManager
0xe325000 - 0xe32fff7 com.apple.IOFWDVComponents 1.9.9 (1.9.9) <5B4E7BD7-EF5A-2F5C-DF8E-3D4A7B59F779> /System/Library/Components/IOFWDVComponents.component/Contents/MacOS/IOFWDVComponents
0xe349000 - 0xe34bff7 +com.sony.bprl.fcpimportplugin 2.7.0 (387) /Library/Application Support/Final Cut Pro System Support/Plugins/SonyImportPlugin.bundle/Contents/MacOS/SonyImportPlugin
0xe3f4000 - 0xe3f9ffb com.apple.fxmetaplug.ImageUnit 1.2.2 (1.2.2) <874EE8A7-B644-32C8-D8E2-1E4EA379C31B> /Library/Application Support/ProApps/Internal Plug-Ins/FxMetaPlug/ImageUnit.fxmetaplug/Contents/MacOS/ImageUnit
0xe659000 - 0xe679ff7 +com.pixlock.fx.Lock & Load 1.0.5 b21 (1.0.5 b21) <138F1694-4953-BB70-2A7A-22D0DA9EEAAE> /Library/Plug-Ins/FxPlug/Lock & Load.fxplug/Contents/MacOS/Lock & Load
0xe68e000 - 0xe6b7fff +com.redgiantsoftware.MagicBulletMojo.MBMojo 1.5 (1.5) <22FB5B65-52C0-B1CB-C541-E79B74AB82A1> /Library/Plug-Ins/FxPlug/MBMojo.fxplug/Contents/MacOS/MBMojo
0xe6c7000 - 0xe6dcffb +com.dvdxdv.VeescopeKey 1.0 (1.1.2) /Library/Plug-Ins/FxPlug/VeescopeKey.fxplug/Contents/MacOS/VeescopeKey
0xe707000 - 0xe805ff7 com.apple.soundtrackpro.integration 3.0 (3.0) /Library/Application Support/ProApps/Bundles/Soundtrack Pro Integration.bundle/Contents/MacOS/Soundtrack Pro Integration
0xe836000 - 0xe847ff7 com.apple.fxplugframework 1.2.3 (1.2.3) <033FEA79-E666-D319-5BD5-25A9A4331190> /Library/Frameworks/FxPlug.framework/Versions/A/FxPlug
0xe85a000 - 0xe8aaffb +com.noiseindustries.FxFactory.FxPlug 2.0.5 (2.0.5) <634B56BD-D768-DAB2-58C4-007FAAA6AAEA> /Library/Plug-Ins/FxPlug/FxFactory.fxplug/Contents/MacOS/FxFactory
0xea00000 - 0xea22fe7 +com.pixlock.fx.LocknLoadx 1.0.2 b30 (1.0.2 b30) /Library/Plug-Ins/FxPlug/Lock & Load X.fxplug/Contents/MacOS/Lock & Load X
0xeb38000 - 0xeb8dfe2 com.apple.DVCPROHDAudio 1.3.2 (1.3.2) <2E0A9883-4EA5-706F-78F6-4C1F105A4D30> /Library/Audio/Plug-Ins/HAL/DVCPROHDAudio.plugin/Contents/MacOS/DVCPROHDAudio
0xebac000 - 0xec11fe0 com.apple.DVCPROHDMuxer 1.3.2 (1.3.2) <483DD62C-46C4-36AA-6A1C-2DEA6F062863> /Library/QuickTime/DVCPROHDMuxer.component/Contents/MacOS/DVCPROHDMuxer
0xec2b000 - 0xec6cfe3 com.apple.audio.SoundManager.Components 3.9.4 (3.9.4) /System/Library/Components/SoundManagerComponents.component/Contents/MacOS/SoundManagerComponents
0xed08000 - 0xed12ff7 com.apple.compressor.MediaServerAPI 3.5.2 (3.5.2) <71053936-4934-706A-D074-714BA3076E57> /Library/Frameworks/MediaServerAPI.framework/Versions/A/MediaServerAPI
0xed1f000 - 0xed25fff com.apple.compressor.FilterUI 3.5.2 (3.5.2) <7F759913-59CD-8BF3-332C-A9B42FF57A32> /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/FilterUI.framework/Versions/A/FilterUI
0xed30000 - 0xed7633b +libguide.dylib 4.0.0 (compatibility 4.0.0) /usr/local/lib/libguide.dylib
0xed98000 - 0xedaefe7 +com.redgiantsoftware.quicklooksfx 1.2 (1.2) <3E2176BD-71B1-BC6C-9FCA-20DFB5F86852> /Library/Plug-Ins/FxPlug/MB QuickLooks/QuickLooks.fxplug/Contents/MacOS/QuickLooks
0xedb9000 - 0xedbefe7 com.apple.H264Encoder 1.0 (21) <00A8356F-B31C-612D-2BCB-51BD5702DBBB> /Library/Application Support/ProApps/SharedA/Frameworks/H264Encoder.framework/Versions/A/H264Encoder
0xedc9000 - 0xf4fefdf +com.borisfx.TextScrambler ??? (2.1) /Library/Application Support/Final Cut Pro System Support/Plugins/Text Scrambler.bundle/Contents/MacOS/Text Scrambler
0xffc9000 - 0xffd4fff com.apple.compressor.StompUtil 3.5.2 (3.5.2) /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/StompUtil.framework/Versions/A/StompUtil
0xffe3000 - 0xffeefff com.apple.qmaster.SwampUtil 3.5.2 (3.5.2) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampUtil.framework/Versions/A/SwampUtil
0x10000000 - 0x10060fef com.apple.proapps.AudioMixEngine 2.0 (68) <18BDF42D-BECE-D5D9-9D20-C81B867EF1B3> /Applications/Final Cut Pro.app/Contents/Frameworks/AudioMixEngine.framework/Versions/A/AudioMixEngine
0x30091000 - 0x307c3fc7 +com.borisfx.Title3D ??? (2.1) /Library/Application Support/Final Cut Pro System Support/Plugins/Title 3D.bundle/Contents/MacOS/Title 3D
0x31401000 - 0x31553fec com.apple.Helium.HeliumRender 2.0.2 (352) <0B979438-6DD0-B8B0-FE89-BDF33ABD8A46> /Library/Application Support/ProApps/SharedA/Frameworks/Helium.framework/Versions/A/Frameworks/HeliumRender.framework/Versions/A/HeliumRender
0x315cc000 - 0x315e5fff com.apple.promath.framework 4.0.2 (726) /Library/Application Support/ProApps/SharedA/Frameworks/Motion/ProMath.framework/Versions/A/ProMath
0x315f8000 - 0x315faffd +net.kineme.StructureTools 0.1 (20080606) <91F0A736-0AB0-A444-EED9-E5792A36783B> /Library/Graphics/Quartz Composer Patches/StructureTools.plugin/Contents/MacOS/StructureTools
0x31700000 - 0x31e30fef +com.borisfx.TitleCrawl ??? (2.1) /Library/Application Support/Final Cut Pro System Support/Plugins/Title Crawl.bundle/Contents/MacOS/Title Crawl
0x3286d000 - 0x32fa3ff7 +com.borisfx.VectorShape ??? (2.1) /Library/Application Support/Final Cut Pro System Support/Plugins/Vector Shape.bundle/Contents/MacOS/Vector Shape
0x33d00000 - 0x33dbdfe2 com.apple.DesktopVideoOut 1.2.7 (1.2.7) <7959538F-2A96-F2BB-EEC3-0718A326C152> /Library/QuickTime/DesktopVideoOut.component/Contents/MacOS/DesktopVideoOut
0x33e1c000 - 0x33e25fff com.apple.qmaster.SwampService 3.5.2 (3.5.2) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampService.framework/Versions/A/SwampService
0x33e35000 - 0x33e99ff3 +com.redgiantsoftware.MBLooksRenderLib 1.2 (1.2) <728C832E-405A-081C-0303-F7A30ED617CF> /Library/Frameworks/LS3Renderer.framework/Versions/A/LS3Renderer
0x33eae000 - 0x33eb0ff7 com.apple.podcastproducer.ImageDiffer 1.2.1 (168) <1EC547D8-6086-0C78-5959-4968D58A6E58> /System/Library/Graphics/Quartz Composer Patches/ImageDifferPatch.plugin/Contents/MacOS/ImageDifferPatch
0x33eb5000 - 0x33f08ff7 +com.pixlock.VTwinFx.FxPlug ??? (2.2.9 (100)) <3FA25228-6AFB-128C-080B-D1F74D97BD83> /Library/Plug-Ins/FxPlug/VTwinFx.fxplug/Contents/MacOS/VTwinFx
0x33f34000 - 0x33f4bfe7 libedit.2.dylib 2.11.0 (compatibility 2.0.0) <45688CB7-9BE4-5D1B-C209-A414EE98C5D2> /usr/lib/libedit.2.dylib
0x33f58000 - 0x33f69fff com.apple.RetimingMath 4.0.2 (726) /Library/Application Support/ProApps/SharedA/Frameworks/Motion/RetimingMath.framework/Versions/A/RetimingMath
0x33f7e000 - 0x33fb4ffa com.apple.proinspector.framework 4.0.2 (761) /Library/Application Support/ProApps/SharedA/Frameworks/ProInspector.framework/Versions/A/ProInspector
0x34cc0000 - 0x34ccbfff com.apple.qmaster.ClusterManager 3.5.2 (3.5.2) <5FA0462F-BDCB-BB2A-67CB-DD89197AD15B> /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/ClusterManager.framework/Versions/A/ClusterManager
0x34cdb000 - 0x34cedfff com.apple.motion.Text 4.0.2 (726) <247FAC75-E788-006A-BCD0-F8429C8F6EB0> /Library/Application Support/ProApps/SharedA/Plug-Ins/Motion/Text.ozp/Contents/MacOS/Text
0x35500000 - 0x3576afe2 com.apple.motion.filters 4.0.2 (601) <72DA6C52-A9AC-A136-D7C8-F6B918A17FE9> /Library/Application Support/ProApps/SharedA/Plug-Ins/FxPlug/Filters.bundle/Contents/MacOS/Filters
0x35880000 - 0x358cbff4 com.apple.Bloodhound 4.0.2 (726) <0BF18F9B-B0AA-8F62-0751-D9B34FDEE73E> /Library/Application Support/ProApps/SharedA/Frameworks/Motion/Bloodhound.framework/Versions/A/Bloodhound
0x35d00000 - 0x35e88ff8 +com.pixlock.cvl ??? (1.0.0) <1EF7FD63-D43F-4436-AE19-0E8B913E30D0> /Library/Frameworks/PixlockCVL.framework/Versions/A/PixlockCVL
0x35f8c000 - 0x35f96fff com.apple.qmaster.Status 3.5.2 (3.5.2) <1EA9EE4B-93FB-EA7D-2846-6F40D8EB22DD> /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/Status.framework/Versions/A/Status
0x38f22000 - 0x38f5aff7 com.apple.CompressorKit 3.5.2 (3.5.2) /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/CompressorKit.framework/CompressorKit
0x38f89000 - 0x38fbdfff com.apple.qmaster.SwampCore 3.5.2 (3.5.2) <286B7D2B-4288-A901-1CE3-65377016AC01> /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampCore.framework/Versions/A/SwampCore
0x3a700000 - 0x3a7a2fef com.apple.compressor.StompUI 3.5.2 (3.5.2) <59A7622A-CFE6-1FCE-5C7B-FBBCC30FCF82> /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/StompUI.framework/Versions/A/StompUI
0x3bf00000 - 0x3bf74ff8 com.apple.qmaster.do 3.5.2 (3.5.2) <9F1CC322-6D59-3D48-01E0-EEA16736056A> /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/DistributedObjects.framework/Versions/A/DistributedObjects
0x3bfdd000 - 0x3bfe8fff com.apple.qmaster.RequestProcessing 3.5.2 (3.5.2) <393DFB50-99CA-4D42-61E3-6423FD9BA7D7> /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/RequestProcessing.framework/Versions/A/RequestProcessing
0x3d400000 - 0x3dce1fe2 com.apple.ozone.framework 4.0.2 (726) /Library/Application Support/ProApps/SharedA/Frameworks/Motion/Ozone.framework/Ozone
0x3e183000 - 0x3e256fff org.python.python 2.5.4 (2.5) <15DC38FC-A6D1-9181-0D92-B32EEF868F1D> /System/Library/Frameworks/Python.framework/Versions/2.5/Python
0x3e296000 - 0x3e3feff2 com.apple.ProMedia 4.0.2 (726) /Library/Application Support/ProApps/SharedA/Frameworks/Motion/ProMedia.framework/Versions/A/ProMedia
0x3e46f000 - 0x3e4d9ff2 com.apple.ProGraphics 4.0.2 (726) /Library/Application Support/ProApps/SharedA/Frameworks/Motion/ProGraphics.framework/Versions/A/ProGraphics
0x3e5f6000 - 0x3e77afe2 com.apple.Lithium 4.0.2 (726) <1954EA13-F844-EB3D-6C39-75CB8AE092A4> /Library/Application Support/ProApps/SharedA/Frameworks/Lithium.framework/Versions/A/Lithium
0x3e801000 - 0x3e8cfff3 com.apple.prochannel.framework 4.0.2 (763) <721D6E76-2081-097D-4C2E-22C6162B8DDB> /Library/Application Support/ProApps/SharedA/Frameworks/ProChannel.framework/Versions/A/ProChannel
0x3e96e000 - 0x3ed22ff2 com.apple.motion.TextFramework 4.0.2 (726) /Library/Application Support/ProApps/SharedA/Frameworks/Motion/TextFramework.framework/TextFramework
0x3eddf000 - 0x3ef76ff8 com.apple.motion.Behaviors 4.0.2 (726) <0254E263-46BA-CF0C-0105-7D8497418973> /Library/Application Support/ProApps/SharedA/Plug-Ins/Motion/Behaviors.ozp/Contents/MacOS/Behaviors
0x3f015000 - 0x3f1b2ff8 com.apple.motion.Particles 4.0.2 (726) /Library/Application Support/ProApps/SharedA/Plug-Ins/Motion/Particles.ozp/Contents/MacOS/Particles
0x3f20e000 - 0x3f221ffb com.apple.qmaster.ServiceControl 3.5.2 (3.5.2) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/ServiceControl.framework/Versions/A/ServiceControl
0x3f23a000 - 0x3f2a7ff7 com.apple.qmaster.ContentControl 3.5.2 (3.5.2) <82329CD2-09C7-3B4B-B1E7-514EB6525E08> /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/ContentControl.framework/Versions/A/ContentControl
0x3f2ef000 - 0x3f2f4ff1 com.apple.finalcutpro.dvcprohdfrcplugin 1.2.0 (16) /Applications/Final Cut Pro.app/Contents/PlugIns/DVCPROHD Frame Rate Converter.bundle/Contents/MacOS/DVCPROHD Frame Rate Converter
0x3f700000 - 0x3f72aff7 com.apple.qmaster.SwampUI 3.5.2 (3.5.2) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampUI.framework/Versions/A/SwampUI
0x3f74f000 - 0x3f75afff com.apple.qmaster.SwampExecutor 3.5.2 (3.5.2) <7F6F9C04-9EF1-B3B3-A232-51D0EAB1AD18> /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampExecutor.framework/Versions/A/SwampExecutor
0x3f76e000 - 0x3f77afff com.apple.dsppublishing 1.0.1 (119) <76A93F83-68F3-E8CA-7E68-10422709AC9D> /Library/Frameworks/DSPPublishing.framework/Versions/A/DSPPublishing
0x3f78b000 - 0x3f7c3fff com.apple.compressor.ImageProcessing 3.5.2 (3.5.2) /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/ImageProcessing.framework/Versions/A/ImageProcessing
0x3f7ec000 - 0x3f7f8fe7 libexslt.0.dylib 9.13.0 (compatibility 9.0.0) <43856244-CC36-9DE9-3D60-D4F4D6F2825C> /usr/lib/libexslt.0.dylib
0x40e00000 - 0x40f5aff7 com.apple.AECore 3.5.2 (3.5.2) /Library/Frameworks/AECore.framework/Versions/A/AECore
0x42800000 - 0x428e9fe3 com.apple.compressor.StompTypes 3.5.2 (3.5.2) /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/StompTypes.framework/Versions/A/StompTypes
0x42972000 - 0x42a3bfe3 com.apple.qmaster.SwampTypes 3.5.2 (3.5.2) <28B2F40B-1E8D-EBB8-BCE9-26B368FED5BA> /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampTypes.framework/Versions/A/SwampTypes
0x42ac9000 - 0x42b8efff com.apple.qmaster.JobControl 3.5.2 (3.5.2) <48F2A5C6-9EA8-9CDC-E815-D6AD9183DBE2> /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/JobControl.framework/Versions/A/JobControl
0x42c17000 - 0x42db7ffb com.apple.compressor.transcoding 3.5.2 (3.5.2) <99C06A1D-B654-5425-BA07-76139F122D5D> /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/Transcoding.framework/Versions/A/Transcoding
0x42ede000 - 0x42f07fe3 com.apple.audio.CoreAudioKit 1.6.1 (1.6.1) <7FFBD485-5251-776A-CC44-4470DD84112B> /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudioKit
0x431e9000 - 0x431f6ffb com.apple.AppleScriptObjC 1.0.2 (???) /System/Library/Frameworks/AppleScriptObjC.framework/Versions/A/AppleScriptObjC
0x52304000 - 0x52465ff3 com.apple.AutomatorFramework 1.2.1 (247) /System/Library/Frameworks/Automator.framework/Versions/A/Automator
0x5250f000 - 0x5254bff7 com.apple.OSAKit 1.2.1 (76) <6F598EE9-9973-5983-2A71-56FF1AB0081B> /System/Library/Frameworks/OSAKit.framework/Versions/A/OSAKit
0x5256f000 - 0x525b5ff7 com.apple.AppleScriptKit 1.5.1 (81) <76F7012F-2169-1021-26B5-DDDA990B8926> /System/Library/Frameworks/AppleScriptKit.framework/Versions/A/AppleScriptKit
0x5261f000 - 0x52631feb +com.sony.bprl.fcpexportplugin 2.7.0 (387) /Library/Application Support/Final Cut Pro System Support/Plugins/SonyExportPlugin.bundle/Contents/MacOS/SonyExportPlugin
0x533eb000 - 0x534e8fe2 com.apple.Helium.HOpticalFlowAnalyzer 2.0.1 (352) <2606EF32-AD39-FFCB-CD55-80CC11A4813E> /Library/Application Support/ProApps/SharedA/Frameworks/Helium.framework/Plug-ins/HOpticalFlowAnalyzer.bundle/Contents/MacOS/HOpticalFlowAnalyzer
0x5492c000 - 0x54a3cfef com.apple.Helium.HSmoothMotionRender 1.0.3 (352) <3CA22733-B5A7-6B47-04DB-1864C73A27ED> /Library/Application Support/ProApps/SharedA/Frameworks/Helium.framework/Plug-ins/HSmoothMotionRender.bundle/Contents/MacOS/HSmoothMotionRender
0x54a58000 - 0x54b71ff2 com.apple.Helium.HDominantMotionTracker 2.0.1 (352) /Library/Application Support/ProApps/SharedA/Frameworks/Helium.framework/Plug-ins/HDominantMotionTracker.bundle/Contents/MacOS/HDominantMotionTracker
0x55fa0000 - 0x55fb4fff +com.noiseindustries.Units ??? (1.1.6) <7FA44DC6-A6E8-A5D1-4844-9DD30698C8DA> /Library/Graphics/Image Units/Noise Industries Units.plugin/Contents/MacOS/Noise Industries Units
0x55fc1000 - 0x55fe5ff7 com.apple.QuartzComposer.ExtraPatches 3.1 (156.13) <5D026B4A-3718-7D93-F4BD-3D86043DA8E6> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/Resources/ExtraPatches.plugin/Contents/MacOS/ExtraPatches
0x59650000 - 0x59678feb com.apple.audio.OpenAL 1.3 (1.3) <17F53393-0AA6-5FC6-6544-7EFAFB7F13AD> /System/Library/Frameworks/OpenAL.framework/Versions/A/OpenAL
0x59686000 - 0x5968cff7 +net.kineme.AudioTools 0.8 (20090713) <28616160-C9EC-E46A-3FF8-D5E173296F50> /Library/Graphics/Quartz Composer Patches/AudioTools.plugin/Contents/MacOS/AudioTools
0x59693000 - 0x59699ff7 +net.kineme.FileTools 0.5 (20100318.0416r7203) /Library/Graphics/Quartz Composer Patches/FileTools.plugin/Contents/MacOS/FileTools
0x596a3000 - 0x596c5ff7 +net.kineme.GLTools_NoAlphaBlend 1.6 (20100310.1619r7174) /Library/Graphics/Quartz Composer Patches/GLTools_NoAlphaBlend.plugin/Contents/MacOS/GLTools
0x5a1b8000 - 0x5a232fe3 com.apple.AppleVAH264HW.component 2.0 (1.0) <0FC65A8D-3E68-BC03-284B-EFACF6915686> /System/Library/QuickTime/AppleVAH264HW.component/Contents/MacOS/AppleVAH264HW
0x5a62d000 - 0x5a6d4ffb com.apple.GeForceVADriver 1.6.10 (6.1.0) <2D845B2C-51D9-4044-11A9-B2701691F8F8> /System/Library/Extensions/GeForceVADriver.bundle/Contents/MacOS/GeForceVADriver
0x5a703000 - 0x5a780fe7 com.apple.AppleVADriver 4.8.11 (4.8.11) <2CA2C6E4-70DF-3FC4-688E-59FC03A7BF84> /System/Library/Extensions/AppleVADriver.bundle/Contents/MacOS/AppleVADriver
0x70000000 - 0x700caffb com.apple.audio.units.Components 1.6.1 (1.6.1) /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
0x8f12c000 - 0x8f7b4fff com.apple.GeForceGLDriver 1.6.10 (6.1.0) /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/GeForceGLDriver
0x8fe00000 - 0x8fe4162b dyld 132.1 (???) <211AF0DD-42D9-79C8-BB6A-1F4BEEF4B4AB> /usr/lib/dyld
0x90003000 - 0x90008ff7 com.apple.AOSNotification 1.1.0 (123.3) <0386E48C-4095-1D2A-629A-83B7711550F3> /System/Library/PrivateFrameworks/AOSNotification.framework/Versions/A/AOSNotification
0x902ff000 - 0x903e3ff7 com.apple.WebKit 6531.22 (6531.22.7) <87C81D6F-77B1-C517-93E6-5DEF214326A7> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x903e4000 - 0x90408ff7 libJPEG.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x90474000 - 0x90478ff7 libGFXShared.dylib ??? (???) <286F466C-2856-B579-B87F-4E9A35C80263> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x90479000 - 0x9047bff7 libRadiance.dylib ??? (???) <9358E1EF-F802-B76E-8E23-2D0695787CFB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x9047c000 - 0x90480ff7 libGIF.dylib ??? (???) <03880BA1-7A86-0F2B-617A-C66B1D05DD70> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x90481000 - 0x904a1fe7 libresolv.9.dylib 40.0.0 (compatibility 1.0.0) <03019DD7-993D-AC88-6636-179F92F315C4> /usr/lib/libresolv.9.dylib
0x904a2000 - 0x904a9ff7 com.apple.agl 3.0.12 (AGL-3.0.12) <6BF89127-C18C-27A9-F94A-981836A822FE> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x904aa000 - 0x904b7fe7 libbz2.1.0.dylib 1.0.5 (compatibility 1.0.0) <6008C8AC-8DB1-B38B-52A9-9133533B0DA2> /usr/lib/libbz2.1.0.dylib
0x904b8000 - 0x904bbff7 libCGXType.A.dylib 543.33.0 (compatibility 64.0.0) <69BE578C-A364-A150-35E3-53EE00F56F05> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
0x904bc000 - 0x904c9ff7 com.apple.AppleFSCompression 24.0.1 (1.0) <62870D1B-4A67-B744-5930-8257E16D9247> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x904d7000 - 0x9051bfe7 com.apple.Metadata 10.6.3 (507.8) <53BB360A-1813-170D-827F-C1863EF15537> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x9051c000 - 0x90534ff7 com.apple.CFOpenDirectory 10.6 (10.6) <1537FB4F-C112-5D12-1E5D-3B1002A4038F> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x90576000 - 0x90580ffb com.apple.speech.recognition.framework 3.11.1 (3.11.1) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x90581000 - 0x90591ff7 libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) /usr/lib/libsasl2.2.dylib
0x90592000 - 0x905d5ff7 libGLU.dylib ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x905d6000 - 0x906e2ff7 libGLProgrammability.dylib ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x906e3000 - 0x907befe7 com.apple.DesktopServices 1.5.5 (1.5.5) /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x907f4000 - 0x90844ff7 com.apple.Symbolication 1.1 (67) /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x90845000 - 0x90bacff7 com.apple.QuartzCore 1.6.1 (227.18) <8A65F233-4C77-BA7C-5DDA-2423F5C1B7A1> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x90bad000 - 0x90c45fe7 edu.mit.Kerberos 6.5.9 (6.5.9) <73EC847F-FF44-D542-2AD5-97F6C8D48F0B> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x90c46000 - 0x90c63fe7 com.apple.DotMacSyncManager 2.0.2 (446.8) /System/Library/PrivateFrameworks/DotMacSyncManager.framework/Versions/A/DotMacSyncManager
0x90c64000 - 0x90d92fe7 com.apple.CoreData 102.1 (251) /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x90d93000 - 0x90d93ff7 com.apple.quartzframework 1.5 (1.5) /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x90d94000 - 0x90dd5ff7 libRIP.A.dylib 543.33.0 (compatibility 64.0.0) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x90dd6000 - 0x90dddff7 com.apple.iChat.IMUtils 5.0.2 (745) /System/Library/Frameworks/IMCore.framework/Frameworks/IMUtils.framework/Versions/A/IMUtils
0x90dde000 - 0x90de5ff3 com.apple.print.framework.Print 6.1 (237.1) <97AB70B6-C653-212F-CFD3-E3816D0F5C22> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x90dfa000 - 0x90e0fff7 com.apple.iChat.InstantMessage 5.0.2 (745) /System/Library/Frameworks/InstantMessage.framework/Versions/A/InstantMessage
0x90e10000 - 0x90ebeff3 com.apple.ink.framework 1.3.3 (107) <57B54F6F-CE35-D546-C7EC-DBC5FDC79938> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x90ebf000 - 0x90efffe7 com.apple.IMCore 5.0.2 (745) <4BFDB3FF-19A2-163A-4C80-58DD47F5EC89> /System/Library/Frameworks/IMCore.framework/Versions/A/IMCore
0x91061000 - 0x910e3ffb SecurityFoundation 36840.0.0 (compatibility 1.0.0) <29C27E0E-B2B3-BF6B-B1F8-5783B8B01535> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x910e4000 - 0x91176fe3 com.apple.print.framework.PrintCore 6.2 (312.5) <7729B4D7-D661-D669-FA7E-510F93F685A6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x91177000 - 0x913a2ff3 com.apple.QuartzComposer 4.1 (156.13) /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
0x913a3000 - 0x91523feb com.apple.MediaToolbox 0.484.5 (484.5) <6996E5E1-18B6-C734-8335-FE43670C1F9C> /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x91524000 - 0x9156dfe7 libTIFF.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x9156e000 - 0x915a1ff7 libncurses.5.4.dylib 5.4.0 (compatibility 5.4.0) <4014E921-F04E-09BB-4CDA-1527B1C850AB> /usr/lib/libncurses.5.4.dylib
0x915a2000 - 0x91673fe3 ColorSyncDeprecated.dylib 4.6.0 (compatibility 1.0.0) <0A608513-31AD-D533-8386-10245FD62057> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ColorSync.framework/Versions/A/Resources/ColorSyncDeprecated.dylib
0x91674000 - 0x916c4ff7 com.apple.framework.familycontrols 2.0.1 (2010) <50E74916-19A5-F2FC-AB57-76F2C8DDF0A7> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
0x916c5000 - 0x917a0ff7 com.apple.DiscRecording 5.0.3 (5030.4.2) /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x917a1000 - 0x91923fe7 libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <96A45E03-2B29-83EB-0FC6-2C932E398722> /usr/lib/libicucore.A.dylib
0x91924000 - 0x91ae0ff3 com.apple.ImageIO.framework 3.0.2 (3.0.1) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x91ae1000 - 0x91affff7 com.apple.CoreVideo 1.6.1 (45.4) /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x91b00000 - 0x91b31ff7 libGLImage.dylib ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x91b32000 - 0x91ba0ff7 com.apple.QuickLookUIFramework 2.2 (327.4) <5B6A066B-B867-D3A3-BDEE-3D68FA5385B4> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
0x91ba1000 - 0x91bb6fff com.apple.ImageCapture 6.0 (6.0) <3F31833A-38A9-444E-02B7-17619CA6F2A0> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x91bb7000 - 0x91bb9fe7 com.apple.ExceptionHandling 1.5 (10) <21F37A49-E63B-121E-D406-1BBC94BEC762> /System/Library/Frameworks/ExceptionHandling.framework/Versions/A/ExceptionHandling
0x91bba000 - 0x91bd6fe3 com.apple.openscripting 1.3.1 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x91bd7000 - 0x91bf6fe3 libexpat.1.dylib 7.2.0 (compatibility 7.0.0) <82E6F83F-9667-2E39-1D9D-4A49C642527D> /usr/lib/libexpat.1.dylib
0x91bf7000 - 0x91f17feb com.apple.CoreServices.CarbonCore 861.6 (861.6) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x91f20000 - 0x9270f537 com.apple.CoreGraphics 1.543.33 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x92710000 - 0x92749fe7 com.apple.bom 10.0 (164) /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
0x9274a000 - 0x927a2fe7 com.apple.datadetectorscore 2.0 (80.7) /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x9284d000 - 0x9284dffb libffi.dylib ??? (???) <58985323-6EC6-9AD2-B9F0-8787C0B2791C> /usr/lib/libffi.dylib
0x9284e000 - 0x93081fe7 com.apple.WebCore 6531.22 (6531.22.7) <952A0D34-63F5-F7F7-D6E5-D0AD78002F89> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
0x93082000 - 0x93088fff com.apple.CommonPanels 1.2.4 (91) <2438AF5D-067B-B9FD-1248-2C9987F360BA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x93089000 - 0x9309bff7 com.apple.MultitouchSupport.framework 204.12.1 (204.12.1) <6BB58E90-21FA-C491-F0E4-54B69CCDBBC0> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x93316000 - 0x93356ff3 com.apple.securityinterface 4.0.1 (37214) /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
0x93357000 - 0x93360ff7 com.apple.DiskArbitration 2.3 (2.3) /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x93361000 - 0x933b2ff7 com.apple.HIServices 1.8.0 (???) <10C85B88-C6AF-91DB-2546-34661BA35AC5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x9344c000 - 0x93909ffb com.apple.VideoToolbox 0.484.5 (484.5) /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x9390a000 - 0x9391bff7 com.apple.LangAnalysis 1.6.6 (1.6.6) <7A3862F7-3730-8F6E-A5DE-8E2CCEA979EF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x9391c000 - 0x93959ff7 com.apple.SystemConfiguration 1.10.2 (1.10.2) <830FED9E-3E24-004C-35D5-2C1273F79734> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x9395a000 - 0x9395dfe7 libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <1622A54F-1A98-2CBE-B6A4-2122981A500E> /usr/lib/system/libmathCommon.A.dylib
0x9395e000 - 0x939a2ff3 com.apple.coreui 2 (114) <29F8F1A4-1C96-6A0F-4CC2-9B85CF83209F> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x939a3000 - 0x939f0feb com.apple.DirectoryService.PasswordServerFramework 6.0 (6.0) /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
0x939f1000 - 0x939fffe7 libz.1.dylib 1.2.3 (compatibility 1.0.0) <82B2C254-6F8D-7BEA-4C18-038E90CAE19B> /usr/lib/libz.1.dylib
0x93a00000 - 0x93a2aff7 com.apple.framework.Admin 4.1 (4.1) <8B647D47-2F09-2873-757A-3122BA994783> /System/Library/PrivateFrameworks/Admin.framework/Versions/A/Admin
0x93a2b000 - 0x93b1fff7 libiconv.2.dylib 7.0.0 (compatibility 7.0.0) <9EC28185-D26F-533F-90C4-FBAA13A15947> /usr/lib/libiconv.2.dylib
0x93b20000 - 0x93d02fff com.apple.imageKit 2.0.3 (1.0) <56AE34CD-4406-8AA2-DDBF-DBF902BD0E0A> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
0x93d03000 - 0x94c54fe7 com.apple.QuickTimeComponents.component 7.6.6 (1729) /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
0x94c55000 - 0x94d97fe3 com.apple.QTKit 7.6.6 (1729) <1EC021FB-AB8F-F8BF-0434-78C0A7B78EB2> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x94d98000 - 0x94d99ff7 com.apple.audio.units.AudioUnit 1.6.3 (1.6.3) <959DFFAE-A06B-7FF6-B713-B2076893EBBD> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x94da2000 - 0x94da4ff7 com.apple.QuickTimeH264.component 7.6.6 (1729) /System/Library/QuickTime/QuickTimeH264.component/Contents/MacOS/QuickTimeH264
0x94da5000 - 0x94e09ffb com.apple.htmlrendering 72 (1.1.4) <4D451A35-FAB6-1288-71F6-F24A4B6E2371> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x94e0a000 - 0x94e0aff7 com.apple.ApplicationServices 38 (38) <8012B504-3D83-BFBB-DA65-065E061CFE03> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x94e15000 - 0x94e53ff7 com.apple.CoreMedia 0.484.5 (484.5) <35725D22-4549-5568-8E8C-62E0AD0E90F7> /System/Library/PrivateFrameworks/CoreMedia.framework/Versions/A/CoreMedia
0x94e54000 - 0x950c4ffb com.apple.Foundation 6.6.2 (751.21) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x950c5000 - 0x950c5ff7 com.apple.Carbon 150 (152) <608A04AB-F35D-D2EB-6629-16B88FB32074> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x950c6000 - 0x950d2ff7 libkxld.dylib ??? (???) <13F26BB6-C2F7-9D74-933E-09AD8B509ECD> /usr/lib/system/libkxld.dylib
0x950d3000 - 0x95106ff7 com.apple.AE 496.4 (496.4) <7F34EC47-8429-3077-8158-54F5EA908C66> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x95107000 - 0x95119ff7 com.apple.syncservices.syncservicesui 5.2 (578.3) /System/Library/PrivateFrameworks/SyncServicesUI.framework/Versions/A/SyncServicesUI
0x9511a000 - 0x9512effb com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <57DD5458-4F24-DA7D-0927-C3321A65D743> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x9512f000 - 0x95167fe7 libcurl.4.dylib 6.1.0 (compatibility 6.0.0) <9029FA55-4F07-28B9-C1B4-06AD70D8DC8A> /usr/lib/libcurl.4.dylib
0x95168000 - 0x951c3ff7 com.apple.framework.IOKit 2.0 (???) <69E4FE93-376C-565E-650F-04FAD213AA24> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x951c4000 - 0x95369feb libSystem.B.dylib 125.0.1 (compatibility 1.0.0) <06A5336A-A6F6-4E62-F55F-4909A64631C2> /usr/lib/libSystem.B.dylib
0x953b2000 - 0x953e6ff7 libssl.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <5FEC74CA-1D3C-B6E3-E046-3970095C44BC> /usr/lib/libssl.0.9.8.dylib
0x953e7000 - 0x953e7ff7 com.apple.CoreServices 44 (44) /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x953e8000 - 0x95cc7ff7 com.apple.AppKit 6.6.5 (1038.29) /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x95cc8000 - 0x95cc8ff7 com.apple.Accelerate 1.6 (Accelerate 1.6) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x95cc9000 - 0x95da6ff7 com.apple.vImage 4.0 (4.0) <64597E4B-F144-DBB3-F428-0EC3D9A1219E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x95da7000 - 0x960cbfef com.apple.HIToolbox 1.6.2 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x960ce000 - 0x960d1ff7 libCoreVMClient.dylib ??? (???) <98CB96B1-85FE-25AF-AB19-ED061912FC3E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x960d2000 - 0x960dcfe7 com.apple.audio.SoundManager 3.9.3 (3.9.3) <5F494955-7290-2D91-DA94-44B590191771> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x960dd000 - 0x960e7ff7 com.apple.bsd.ServiceManagement 1.0 (1.0) /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x960e8000 - 0x9634aff3 com.apple.security 6.1.1 (37594) <1AC07F75-7E27-9662-21DA-B05DFF047B26> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x9634b000 - 0x9634fff7 IOSurface ??? (???) <4B825ADA-8DBE-6BA2-1AB3-307D2C3AFCA8> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x96350000 - 0x9635bff7 libGL.dylib ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x9635c000 - 0x96386ff7 com.apple.shortcut 1.1 (1.1) /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
0x96387000 - 0x9639fff3 com.apple.ScriptingBridge 1.1.2 (???) <01EEBDAB-C818-C2F4-576C-E916448F5D06> /System/Library/Frameworks/ScriptingBridge.framework/Versions/A/ScriptingBridge
0x963a0000 - 0x964b6ff7 com.apple.PubSub 1.0.4 (65.12.1) <1B79C698-A2A1-6B74-A137-67516ABE088E> /System/Library/Frameworks/PubSub.framework/Versions/A/PubSub
0x964b7000 - 0x965e3fff com.apple.audio.toolbox.AudioToolbox 1.6.3 (1.6.3) /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x9660b000 - 0x966c4fe7 libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <16CEF8E8-8C9A-94CD-EF5D-05477844C005> /usr/lib/libsqlite3.dylib
0x966c5000 - 0x966f6ff3 libTrueTypeScaler.dylib ??? (???) <4C189FCA-A210-7255-8F70-38DF9D19F877> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x966fc000 - 0x9676aff7 com.apple.ISSupport 1.9.3 (51) <9BB37FBA-E379-8D12-11C6-B9C5C9683D27> /System/Library/PrivateFrameworks/ISSupport.framework/Versions/A/ISSupport
0x9676b000 - 0x967b1ffb com.apple.CoreMediaIOServices 130.0 (1035) <397101F4-BA80-C8C2-F816-E2FBE5E15D4F> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Versions/A/CoreMediaIOServices
0x967b2000 - 0x96862ff3 com.apple.ColorSync 4.6.3 (4.6.3) <68B6A1B9-86CF-0C5A-7D63-56ED4BB2EB5B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x96863000 - 0x968d6fff com.apple.iLifeMediaBrowser 2.1.5 (368) <30261504-7533-5424-DD15-32739DED6FB0> /System/Library/PrivateFrameworks/iLifeMediaBrowser.framework/Versions/A/iLifeMediaBrowser
0x968d7000 - 0x968d8ff7 com.apple.MonitorPanelFramework 1.3.0 (1.3.0) <0EC4EEFF-477E-908E-6F21-ED2C973846A4> /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/MonitorPanel
0x968f2000 - 0x96d08ff7 libBLAS.dylib 219.0.0 (compatibility 1.0.0) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x96d09000 - 0x96e0fff3 com.apple.DiskImagesFramework 10.6.3 (283) <25E58865-CC3A-8707-1C4C-F86ED1514A09> /System/Library/Pri
Lawrence Gray
Re: Snow Leopard Updated Info
on Apr 1, 2010 at 11:09:29 am
All way too long to fit here... anyway here's the last bits with details of the system... don't know if that's any use but I'll send stuff of to support later on.
Model: MacPro3,1, BootROM MP31.006C.B05, 8 processors, Quad-Core Intel Xeon, 2.8 GHz, 8 GB, SMC 1.25f4
Graphics: NVIDIA Quadro FX 5600, NVIDIA Quadro FX 5600, PCIe, 1536 MB
Memory Module: global_name
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x88), Broadcom BCM43xx 1.0 (5.10.91.27)
Bluetooth: Version 2.3.1f4, 2 service, 19 devices, 1 incoming serial ports
Network Service: AirPort, AirPort, en2
PCI Card: Apple RAID Card, sppci_raid, Slot-4
PCI Card: NVIDIA Quadro FX 5600, Display, Slot-1
PCI Card: pcibdbd,a11a, sppci_video, Slot-2
Parallel ATA Device: OPTIARC DVD RW AD-7170A
USB Device: Hub, 0x05ac (Apple Inc.), 0x912f, 0xfd300000
USB Device: Hub, 0x0424 (SMSC), 0x2503, 0xfd330000
USB Device: KEYBOARD, 0x4320, 0x0302, 0xfd333000
USB Device: My Book, 0x1058 (Western Digital Technologies, Inc.), 0x1100, 0xfd310000
USB Device: Apple Cinema HD Display, 0x05ac (Apple Inc.), 0x9221, 0xfd320000
USB Device: USB Receiver, 0x046d (Logitech Inc.), 0xc52b, 0x1d100000
USB Device: Bluetooth USB Host Controller, 0x05ac (Apple Inc.), 0x8206, 0x5d200000
FireWire Device: built-in_hub, Up to 800 Mb/sec
FireWire Device: 4big Quadra, LaCie, Up to 800 Mb/sec
FireWire Device: unknown_device, Unknown
Lawrence Gray
Lawrence Gray
on Apr 15, 2010 at 11:04:25 am
Any news on this? The plug ins still crash my Final Cut. Any way of uninstalling them?
Lawrence Gray
Eberhard Ammelt
on Apr 15, 2010 at 12:12:31 pm
Hello,
sorry for not getting back to you earlier.
The crash occurs in the GeForce driver. Do you have two FX 5600 installed?
Could you try to remove one?
Regards, Eberhard
Lawrence Gray
on Apr 15, 2010 at 4:12:41 pm
I've only got the one.
Chipset Model: NVIDIA Quadro FX 5600
Type: GPU
Bus: PCIe
Slot: Slot-1
PCIe Lane Width: x16
VRAM (Total): 1536 MB
Vendor: NVIDIA (0x10de)
Device ID: 0x019d
Revision ID: 0x00a2
ROM Revision: 3221
Lawrence Gray
Eberhard Ammelt
on Apr 16, 2010 at 9:06:41 am
Ok, the crash log suggested there might be two.
As the crash occurs in the GeForce driver, could you try to replace the FX 5600 for a test?
Eberhard
Lawrence Gray
on Apr 17, 2010 at 5:57:59 am
Is there a way of doing a test without having to buy another graphics?
Lawrence Gray
Eberhard Ammelt
on Apr 17, 2010 at 1:34:23 pm
If you have no other graphics card for a test, I'd suggest a clean install on another volume.
If that doesn't help, you might also try a clean install with 10.5.8.
Eberhard
Lawrence Gray
on Apr 18, 2010 at 3:52:23 am
I guess that's a possibility... I've got a spare hard-drive that I could slip in and install an operating system on. I'm deep into a project at the moment and struggling with crashes while I finish it. Don't want to disrupt too many things by shutting down for two days as it installs everything with the potential for screwing up a whole bunch of settings!
Lawrence Gray
