c2 image flow fx problems wont put images in order
COW Forums : CoreMelt Plug-ins
michael arevalo
on Aug 18, 2010 at 4:48:02 pm
Hi when I load a folder using card flow or any other of the photo montage generators it won't put them in the order I have them in the folder. I am trying to put a folder of pictures in chronological order and I have listed them as 1, 2, 3, 4 so it would go in the order I wish. For some reason when I load the folder it randomly puts them in a different order is there any way to fix this. I have tried using image wells but the render time is an hour for 8 images. Any tips would be greatly appreciated thanks.
Iain Anderson
Re: c2 image flow fx problems wont put images in order
on Aug 18, 2010 at 10:12:54 pm
Images given to an Image Generator are working, in order, for me (I tried Carousel and Circle Around). Please check under the "Randomize" section to see if you've chosen "Random" from the "Image Order" drop-down menu. It should be "Sequential".
