lock and load x not working in final cut express
COW Forums : CoreMelt Plug-ins
Gonzalo de la Torre
on Aug 7, 2010 at 9:38:08 pm
Lock and load frames does work, but when I use the filter of lock and load x, i get an 'application not found' and a big red screen on the timeline. ? Thanks for the help.
Roger Bolton
Re: lock and load x not working in final cut express
on Aug 8, 2010 at 12:17:11 am
Hi, yes thats correct, Lock & Load X only works in Final Cut Pro, so Final Cut Express users have to use the Lock & Load Frames version. This is due to limitations in Final Cut Express, but the end result of both plugins is the same stabilization.
CoreMelt V2 plugins
