Lock & Load crashes regularly under FCPX
COW Forums : CoreMelt Plug-ins
William Benton
on May 15, 2016 at 3:59:23 am
Howdy, I'm seeing Lock & Load crash every time I try and share a particular 4K FCPX project with it enabled. (I've successfully used Lock & Load on other projects in other resolutions.)
I've attached the relevant parts of the crash report below. Has anyone else seen this problem? Is there a workaround?
Process: Final Cut Pro [93947]
Path: /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
Identifier: Final Cut Pro
Version: 10.2.3 (276640)
App Item ID: 424389933
App External ID: 815823966
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: Final Cut Pro [93947]
User ID: 501
Date/Time: 2016-05-13 20:42:26.404 -0500
OS Version: Mac OS X 10.11.4 (15E65)
System Integrity Protection: enabled
Crashed Thread: 11 com.apple.helium.rq.gpu-ru0.vs0
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: EXC_I386_GPFLT
Exception Note: EXC_CORPSE_NOTIFY
Global Trace Buffer (reverse chronological seconds):
404.712374 AppleJPEG 0x00007fff90bfda11 [0x7fc8c2b3fe00] Releasing session
405.290866 AppleJPEG 0x00007fff90bfda11 [0x7fc8a45e1a00] Releasing session
405.300151 AppleJPEG 0x00007fff90bfda11 [0x7fc8a5e13800] Releasing session
405.300151 AppleJPEG 0x00007fff90bfda11 [0x7fc8c2703200] Releasing session
405.301473 AppleJPEG 0x00007fff90bfda11 [0x7fc8c696c600] Releasing session
405.306044 AppleJPEG 0x00007fff90bfda11 [0x7fc8a782dc00] Releasing session
405.306265 AppleJPEG 0x00007fff90bfda11 [0x7fc8a57f1600] Releasing session
405.306265 AppleJPEG 0x00007fff90bfda11 [0x7fc8a72fba00] Releasing session
414.945951 AppleJPEG 0x00007fff90bfda11 [0x7fc8c6d2ae00] Releasing session
414.945951 AppleJPEG 0x00007fff90bfda11 [0x7fc8a4f5dc00] Releasing session
414.952881 AppleJPEG 0x00007fff90bfda11 [0x7fc8a4d4ea00] Releasing session
414.957538 AppleJPEG 0x00007fff90bfda11 [0x7fc8a5578600] Releasing session
Thread 11 Crashed:: com.apple.helium.rq.gpu-ru0.vs0
0 GLEngine 0x00007fff883151d7 gleLookupHashObject + 51
1 GLEngine 0x00007fff884059a9 gleBindBufferObject + 52
2 GLEngine 0x00007fff88340035 glBindBuffer_Exec + 127
3 com.apple.CoreImage 0x00007fff90008945 CI::GLContext::restoreParentState() + 167
4 com.apple.CoreImage 0x00007fff9000b4e5 CI::GLContext::render_root_node(CI::ProgramNode*, CGRect const&, void () block_pointer) + 1315
5 com.apple.CoreImage 0x00007fff8febf319 CI::Context::recursive_render(CI::Node*, CGRect const&, CI::Node*) + 833
6 com.apple.CoreImage 0x00007fff8fed6e31 ___ZN2CIL13_image_renderEPKcPNS_7ContextEPNS_5ImageE6CGRectP12CGColorSpaceNS_11PixelFormatEmRK7CGPointRKNS_12swizzle_infoE_block_invoke + 22
7 com.apple.CoreImage 0x00007fff8fed1513 CI::tile_node_graph(CI::Context*, char const*, CI::Node*, CGRect, void (CI::Node*, CGRect) block_pointer) + 2776
8 com.apple.CoreImage 0x00007fff8fed16ad CI::tile_node_graph(CI::Context*, char const*, CI::Node*, CGRect, void (CI::Node*, CGRect) block_pointer) + 3186
9 com.apple.CoreImage 0x00007fff8fecdc55 CI::_image_render(char const*, CI::Context*, CI::Image*, CGRect, CGColorSpace*, CI::PixelFormat, unsigned long, CGPoint const&, CI::swizzle_info const&) + 898
10 com.apple.CoreImage 0x00007fff8fecd8ba CI::image_render_to_display(CI::Context*, CI::Image*, CGRect, CGColorSpace*, CI::PixelFormat) + 185
11 com.apple.CoreImage 0x00007fff8feb3946 -[CIContext drawImage:inRect:fromRect:] + 1371
12 com.pixlock.fcpx.LocknLoad.fxplug 0x0000000114a9a3dd -[ComPixlockFxStabilizerFCPX_RendererItem renderOutput:withInput:parameters:] + 3122
13 com.pixlock.fcpx.LocknLoad.fxplug 0x0000000114a98ff9 -[ComPixlockFxStabilizerFCPX_Renderer renderOutput:withInput:withRenderInfo:] + 140
14 com.pixlock.fcpx.LocknLoad.fxplug 0x0000000114a8cb6b -[ComPixlockFxStabilizerFCPX_LocknLoadEffect renderOutput:withInput:withInfo:] + 3047
15 com.apple.ozone.framework 0x000000011246cd9e OZFxPlug_CallRender(void*, objc_object*, OZProcessControl const*, FxImage*, FxImage*, FxRenderInfo, OZRenderParams const&) + 174
16 com.apple.ozone.framework 0x0000000112296624 OZFxFilter::render(PCPtr const&, bool, OZFxFilter::FilterBounds const&, OZRenderParams const&, LiAgent*, void*, void*, void*, void*, std::tr1::shared_ptr*, PGFramebuffer*, ProGL::GL*) + 548
17 com.apple.ozone.framework 0x0000000112298431 OZFxFilter::getHelium(LiAgent&, PCPtr, CMTime, OZRenderParams&) + 5697
18 com.apple.ozone.framework 0x000000011249d304 OZLiHeFilter::getHelium(LiAgent&) + 196
19 com.apple.Lithium 0x0000000113b744eb LiAgent::getHelium(LiImageSource*) + 4199
20 com.apple.Lithium 0x0000000113bd2a84 LiPolygonInstance::makeNode(LiClipSet const&) + 3318
21 com.apple.Lithium 0x0000000113be7d6a LiRenderInstance::collectGeode(LiGeode*, LiCollectState&) + 676
22 com.apple.Lithium 0x0000000113be7985 LiRenderInstance::collect3D(LiSceneObject*, LiCollectState&) + 1765
23 com.apple.Lithium 0x0000000113be877a LiRenderInstance::collectGroup(LiGroup*, LiCollectState&, LiCollectState&) + 1724
24 com.apple.Lithium 0x0000000113be79a5 LiRenderInstance::collect3D(LiSceneObject*, LiCollectState&) + 1797
25 com.apple.Lithium 0x0000000113be877a LiRenderInstance::collectGroup(LiGroup*, LiCollectState&, LiCollectState&) + 1724
26 com.apple.Lithium 0x0000000113be79a5 LiRenderInstance::collect3D(LiSceneObject*, LiCollectState&) + 1797
27 com.apple.Lithium 0x0000000113be6f5f LiRenderInstance::collect() + 1601
28 com.apple.Lithium 0x0000000113be62e7 LiRenderInstance::buildHeliumGraph(LiAgent&) + 511
29 com.apple.Lithium 0x0000000113be5edf LiRenderInstance::getHelium(LiAgent&) + 443
30 com.apple.Lithium 0x0000000113be1ba5 LiRenderer::getHelium(LiAgent&) + 51
31 com.apple.Lithium 0x0000000113b744eb LiAgent::getHelium(LiImageSource*) + 4199
32 com.apple.ozone.framework 0x00000001123f080c OZCrop::getHelium(LiAgent&) + 540
33 com.apple.Lithium 0x0000000113b744eb LiAgent::getHelium(LiImageSource*) + 4199
34 com.apple.ozone.framework 0x000000011222ff25 GLRenderer::getSceneHeNodeFromLiWorld(OZScene*, OZSceneSettings const&, OZRenderParams&, PCPtr, HGRenderer*, double, double, long*) + 2677
35 com.apple.ozone.framework 0x000000011222f07c GLRenderer::getFrameNodeForSingleTime(OZScene*, OZRenderParams&, HGRenderer*, double, double, long*) + 1740
36 com.apple.ozone.framework 0x000000011222dc7b GLRenderer::getFrameNodeIncludingFields(OZScene*, OZRenderParams&, HGRenderer*, long*) + 875
37 com.apple.ozone.framework 0x000000011222b4f0 GLRenderer::getFrameNode(OZScene*, OZRenderParams&, HGRenderer*, long*) + 208
38 com.apple.ozone.framework 0x00000001122e39bf OZXGetRenderGraph(OZScene*, OZRenderParams, FFSVContext*, GLRenderer&, bool, HGRenderer*) + 767
39 com.apple.Motion.effect 0x0000000111cc1466 -[FFMotionEffect newNodeAtTime:duration:withInputStream:context:downstreamPT:outputPT:outputData:roi:graphBuildInfo:] + 6301
40 com.apple.Motion.effect 0x0000000111cc1e1e -[FFMotionEffect newImageAtTime:duration:withInputStream:context:downstreamPT:channelOffset:roi:graphBuildInfo:] + 242
41 com.apple.Flexo 0x0000000106468f92 __100-[FFStreamVideoEffect newImageAtTimeIgnoringCache:duration:context:downstreamPT:roi:graphBuildInfo:]_block_invoke + 866
42 com.apple.Flexo 0x0000000106468af4 -[FFStreamVideoEffect newImageAtTimeIgnoringCache:duration:context:downstreamPT:roi:graphBuildInfo:] + 868
43 com.apple.Flexo 0x000000010647a1c7 -[FFStreamVideo newImageAtTime:duration:context:downstreamPT:roi:graphBuildInfo:] + 679
44 com.apple.Flexo 0x0000000106b3d073 -[FFAnchoredObjectSegmentedVideoStream newImageAtTimeIgnoringCache:duration:context:downstreamPT:roi:graphBuildInfo:] + 419
45 com.apple.Flexo 0x000000010647a1c7 -[FFStreamVideo newImageAtTime:duration:context:downstreamPT:roi:graphBuildInfo:] + 679
46 com.apple.Flexo 0x0000000106def4d6 -[FFMCSwitcherVideoStream newImageAtTimeIgnoringCache:duration:context:downstreamPT:roi:graphBuildInfo:] + 374
47 com.apple.Flexo 0x000000010647a1c7 -[FFStreamVideo newImageAtTime:duration:context:downstreamPT:roi:graphBuildInfo:] + 679
48 com.apple.Flexo 0x0000000106468992 -[FFStreamVideoEffect newImageAtTimeIgnoringCache:duration:context:downstreamPT:roi:graphBuildInfo:] + 514
49 com.apple.Flexo 0x000000010647a1c7 -[FFStreamVideo newImageAtTime:duration:context:downstreamPT:roi:graphBuildInfo:] + 679
50 com.apple.Flexo 0x0000000106b3d073 -[FFAnchoredObjectSegmentedVideoStream newImageAtTimeIgnoringCache:duration:context:downstreamPT:roi:graphBuildInfo:] + 419
51 com.apple.Flexo 0x000000010647a1c7 -[FFStreamVideo newImageAtTime:duration:context:downstreamPT:roi:graphBuildInfo:] + 679
52 com.apple.Flexo 0x0000000106def4d6 -[FFMCSwitcherVideoStream newImageAtTimeIgnoringCache:duration:context:downstreamPT:roi:graphBuildInfo:] + 374
53 com.apple.Flexo 0x000000010647a1c7 -[FFStreamVideo newImageAtTime:duration:context:downstreamPT:roi:graphBuildInfo:] + 679
54 com.apple.Flexo 0x0000000106868272 -[FFPlayerScheduledData customHGRenderQueueJobCallback:theJob:] + 3298
55 com.apple.Flexo 0x00000001063f4d6a -[FFHGAsyncCustomJob _runCallback:] + 170
56 com.apple.Flexo 0x00000001063f52a3 customJobNotifyFunc(HGRenderJob*) + 179
57 com.apple.Helium.HeliumRender 0x000000010a08dd3e HGRenderJob::CallNotifyFunc() + 46
58 com.apple.Helium.HeliumRender 0x0000000109fcc335 HGRenderExecUnit::RunLoop() + 805
59 com.apple.Helium.HeliumRender 0x0000000109fcbffe StartRenderExecUnitFunc(void*) + 14
60 libsystem_pthread.dylib 0x00007fff82df099d _pthread_body + 131
61 libsystem_pthread.dylib 0x00007fff82df091a _pthread_start + 168
62 libsystem_pthread.dylib 0x00007fff82dee351 thread_start + 13
Eberhard Ammelt
Re: Lock & Load crashes regularly under FCPX
on May 17, 2016 at 7:36:18 am
Hello,
can you please check the system log and search for messages from FCP X right before this crash occurs?
You can find the system log when you open the Console application (utility applications folder) and choose "All Messages" from the list.
Please send those messages to me: eberhard (at) coremelt.com
Eberhard
