TrackX Crashing FCPX
COW Forums : CoreMelt Plug-ins
Adrian Lopez
on May 12, 2016 at 10:50:11 pm
When I drag TrackX simple tracker onto a clip, it tells me it doesn't work on compound clips. Okay fine. I double-click the compound clip on the timeline to get access to the original clip.
However, when I attempt to drag TrackX Simple tracker from the Generator window, FCPX immediately beachballs. It happens consistently - I've tried five different times. Each time I have to force-quit FCPX.
This only happens when I'm INSIDE the compound clip. Out on the main timeline, I can drag and drop the TrackX generator fine.
Whats happening?
Eberhard Ammelt
Re: TrackX Crashing FCPX
on May 17, 2016 at 7:42:44 am
Hello,
not sure if this an FCP X or TrackX issue. When this happens please leave FCP X in this locked state, and launch activity monitor (utility applications folder), select FCP X in the process list, and choose "Sample Process" from the drop down menu of the the 3rd button from left.
Please send the collected sample data to me: eberhard (at) coremelt.com
Eberhard
