Drivex does not work. Media is missing
COW Forums : CoreMelt Plug-ins
Michael Mansell
on Apr 20, 2016 at 5:52:16 pm
I just installed the everything bundle by coremelt. However, the driveX plug-ins are not working. It shows the red screen when you hover over one of the options as if it is missing media. How do I resolve this?
Eberhard Ammelt
Re: Drivex does not work. Media is missing
on Apr 21, 2016 at 10:34:13 am
Hello, this happens when the media in your timeline is missing, and it's not specifically a DriveX issue. Please reconnect your media or select some other clip in your timeline, and then hover over one of the DriveX effects.
Eberhard
Michael Mansell
on Apr 21, 2016 at 3:56:47 pm
No, not MY media. The plugin's media is missing. I cannot use the the driveX plugin at all. When I hover my cursor over the the thumbnails in the text generator it gives the red media missing image. THIS. Is for sure a driveX issue.
Eberhard Ammelt
on Apr 21, 2016 at 7:40:58 pm
Please try to apply the DriveX effect to your clip in the timeline. Does it work now?
If not, please try to install the "Everything" bundle again. If it still doesn't work, which FCP X and OS versions do you have? Also please check the system log for error messages from FCP X.
You can find the system log when you open the Console application and choose „All Messages“ from the list.
Eberhard
Michael Mansell
on Apr 21, 2016 at 8:05:33 pm
I've already tried that. It doesn't work. I've already tried re-installing it and even installed it on my laptop, too. Same issue.
Eberhard Ammelt
on Apr 22, 2016 at 8:32:15 am
Does this happen only with DriveX effects?
Then please check the system log for error messages from FCP X.
Eberhard
Michael Mansell
on Apr 22, 2016 at 6:03:28 pm
The rest work fine. Just DriveX
Michael Mansell
on Apr 22, 2016 at 6:08:32 pm
4/22/16 11:06:25.913 AM Final Cut Pro[4380]: CGContextConvertRectToDeviceSpace: invalid context 0x0. If you want to see the backtrace, please set CG_CONTEXT_SHOW_BACKTRACE environmental variable.
https://www.dropbox.com/s/i7zcujh5ppqj65x/Screenshot%202016-04-22%2011.06.3...
https://www.dropbox.com/s/dtkbkmwe8cqp38d/Screenshot%202016-04-22%2011.07.5...
Roger Bolton
on Apr 22, 2016 at 6:10:19 pm
It sounds like you have an older version of FCP X. DriveX requires FCP X 10.2 or later. Are you still using 10.1?
