Video doesn't start at range selection in Layer
COW Forums : CoreMelt Plug-ins
Ian Magarzo
on Apr 20, 2016 at 1:14:51 am
The case is that i'm using the track layer to insert a video, but I would like to insert it inside a range defined by me previously, like is showed on video tutorials.
I'm not sure if I'm doing something wrong but apparently these selections don't take effect and video starts at his beginning. Here an image of the issue:
Any idea? And thanks for your time :)
Eberhard Ammelt
Re: Video doesn't start at range selection in Layer
on Apr 20, 2016 at 10:23:36 am
Hello, you can put the clip you want to insert into a new compound clip, adjust in/out, and insert the compound clip into TrackX.
Eberhard
