Text Size in Simple Tracker
COW Forums : CoreMelt Plug-ins
Kent Wiley
on Feb 15, 2016 at 11:40:09 pm
Hi folks,
After following one of Iain's tutorials
https://vimeo.com/83013338
I've added and tracked text successfully, but the text in the compound clips comes in at a reduced size. When I look at the clip in the browser, no scaling effect has been added. Nor is this the case when I look at the generator or video tabs in the Inspector pane. Any thoughts?
Kent Wiley
Roger Bolton
Re: Text Size in Simple Tracker
on Feb 16, 2016 at 9:11:51 am
Hi, you use the scaling offset parameters in the trackx plugin to scale the inserted image to the size you want.
Kent Wiley
on Feb 16, 2016 at 6:34:25 pm
Thanks Roger! Not sure why I didn't check that. Indeed they had been reduced to .6.
But why would it do that without any intervention from me? I never explicitly specified a smaller size when placing the text originally.
Kent
