Track X toolbar.
COW Forums : CoreMelt Plug-ins
duncan shepherd
Track X toolbar.
on Jan 30, 2016 at 4:55:39 pm
When I switch between displays while setting up tracks, (thank you for developing such and amazing product BTW), my "1 TRACK 2 SURFACE 3 MASK" toolbar will go AWOL.
Is there a command to bring it back, because currently the only way I know to get it back is re-allpy the generator and start the whole tracking process from scratch.
Thanks guys.
Duncan
Shane Bhatla
Re: Track X toolbar.
on Feb 1, 2016 at 6:14:34 am
Hello Duncan,
The issue could be that you're not selecting the correct clip and the correct effect from the "Effect" inspector in FCPX. Unfortunately, it's a FCP X limitation. You'll have to select the clip that you're working on and then select the effect from the "Effect" inspector, and then the on screen controls should pop up.
However, if that is not the issue, please do feel free to send us an email to our tech support at support(at)coremelt(dot)com
Regards,
Shane
