SliceX / Colorista III does not work correctly
COW Forums : CoreMelt Plug-ins
Peter Kesten
on Jan 14, 2016 at 1:03:50 pm
Hello!
I am using SliceX for some time and more recently also Red Giant's Colorista III. Each plugin itself works fine, but if I try to use "Colorista III with Shape Mask" in the C2 SliceX Extras Folder, I can't use the keyed in Colorista III. If I press the "Edit" button in the "Key" section of the plugin's inspector-panel, all three windows ("Result", "Source", "Matte") show just black, I am not able to select any color to be keyed. If I use the standard Colorista III plugin on the same clip, it works fine. FCPX, Colorista III and SliceX are uptodate, OS is Yosemite 10.10.5. Any ideas?
Best Regards, Peter
Eberhard Ammelt
Re: SliceX / Colorista III does not work correctly
on Jan 14, 2016 at 5:45:17 pm
Hello,
this seems to be caused by the Motion template. I've sent you an email with a fixed Motion template.
Eberhard
Eberhard Ammelt
on Jan 15, 2016 at 12:07:59 pm
Sorry, it doesn't work correctly with the Colorista III keyer, but there's another workaround:
Duplicate your clip and put it on top of the original clip, then add Colorista III to the top clip, and then add Shape Mask Layer (C2 SliceX). Now the keyer should work correctly.
Eberhard
