TrackX completely useless after updating
COW Forums : CoreMelt Plug-ins
Travis Marshall
on Sep 2, 2015 at 3:55:38 pm
I finished a yearlong edit last month and, as was prudent, waited until delivering and archiving before updating my edit system (OS to 10.10.5 and FCP X to 10.2.1). I also updated SliceX and TrackX to 2.9.5.
I'm working on an edit now and TrackX is completely bonkers. It either won't track at all (I click the T-> button and 0% quickly flashes before nothing happens), or if I try and track in reverse the percentage goes up, but the playhead jumps automatically to the head of the clip being tracked and I watch my shape go completely bonkers over a static frame.
I've uninstalled and reinstalled SliceX and TrackX but no joy.
Project is 4K pro res 23.98, although I'm editing in a 1080p frame. I tried turning Spatial Conform off just in case that was the culprit, but it doesn't change a thing.
I'm worried about my older projects that I may have to go back into by client request and whether TrackX is going to be borked on those as well.
Help!
Eberhard Ammelt
Re: TrackX completely useless after updating
on Sep 2, 2015 at 4:20:48 pm
Hello, can you please try the following:
Click on track forward while you press the Option key. This will write some diagnostic information to the system log. You can find the log messages when you open the Console application and choose "All Messages". Please try the same with tracking back and send the log messages to me: eberhard (at) coremelt.com
Eberhard
Travis Marshall
on Sep 3, 2015 at 2:44:25 pm
Hi Eberhard,
When I track in either direction it gives the following error:
9/3/15 10:42:01.710 AM Final Cut Pro[4189]: [CL_INVALID_OPERATION] : OpenCL Error : GCL context may not be released: Invalid operation
Eberhard Ammelt
on Sep 3, 2015 at 3:47:59 pm
Hello Travis,
this error message is not related. I was wrong, you need to press both Shift and Option keys when you hit the track button in order to print diagnostic information to the system log.
Alternatively, it would be even better if you could provide your clip (via dropbox etc.) so I could check it myself.
Eberhard
Travis Marshall
on Sep 3, 2015 at 5:13:23 pm
Here's the console message:
9/3/15 1:12:00.567 PM Final Cut Pro[4189]: media: 902663762, 24000, 6493487, 24000, clipped: 72517645200, 1920000, 9049041, 1920000, track: 304544240, 1920000, 9049041, 1920000
9/3/15 1:12:00.592 PM Final Cut Pro[4189]:
| displayName Track Text | id (null) | anchorPair [3603.600000 - 37769.606875] | PToLOffset -34166.006875 | lane 2 | cRangeInGS [3650.188208 - 3654.901250] | cRange [3603.600000 - 3608.313042] | audioCRange [3603.600000 - 3608.313042]LtoPOffset 34166.006875 LtoGOffset 46.588208 conforms:YES
hasVideo: 1
isStill: 0
isMultiAngleClip: 0
isCompoundClip: 0
displayBounds = "{{0, 0}, {3840, 2160}}";
driftCompensation = 0;
fieldOrder = 0;
motionHeuristic = 0;
movieFileURL = "file:///Volumes/Promise%20Pegasus/Final%20Cut%20X/0002_ATK_Holiday%20How%20To%20Videos_2015-08-27_Travis/Library/ATK_Holiday%20How%20To%20Videos_2015.fcpbundle/How%20to:%20Know%20When%20Your%20Pie%20is%20Done/Original%20Media/DRIVE01_S001_S001_T056.mov";
trackBackward = 0;
trackModel = 1;
trackQuality = 2;
trackRange = {
duration = {
epoch = 0;
flags = 1;
timescale = 1920000;
value = 9049041;
start = {
epoch = 0;
flags = 1;
value = 304544240;
trackRefFrame = {
epoch = 0;
flags = 1;
timescale = 24000;
value = 3806803;
Mac Pro 3 GHz 8-Core Intel Xeon E5, 32 GB Ram, AMD FireProD700
OSX 10.10.5, FCP 10.2.1
Eberhard Ammelt
on Sep 3, 2015 at 8:03:05 pm
Thanks, the log doesn't reveal the cause of the problem. Can you please provide your original video?
Does it work if you optimize the video?
Eberhard
Travis Marshall
on Oct 15, 2015 at 1:53:54 pm
Here is a different project than the one I originally wrote about, but the same problems are occurring.
Trying to use the grey sign as a tracking source for text to stay pinned to a point in the road as the camera tracks backwards.
https://dl.dropboxusercontent.com/u/13933958/Drone%20RD%20Track.mov
