Inserted layer not showing
COW Forums : CoreMelt Plug-ins
Adam Schoales
on Jul 31, 2015 at 3:14:18 pm
Hi all,
Having a rather strange bug using the latest version in FCP X 10.2.1
I'm try to track a replacement screen onto a device, and the track seemingly goes fine. I switch over to the "surface" tab and the placeholder shows up just fine. But when I add something to the insert layer drop zone it doesn't actually show up.
So far only one track in my FCP X timeline has worked. The other two have this bug.
Any idea what is causing it, or what I might be doing wrong? I'm not using proxies or anything like that.
Any help would be greatly appreciated.
Eberhard Ammelt
Re: Inserted layer not showing
on Jul 31, 2015 at 5:10:28 pm
Hello,
do you have the latest version of TrackX installed? We have released a major update with a fix for related issues a few weeks ago.
When you add a video to the insert layer parameter, does the video show up in the parameter but not at all in the placeholder (not even a still image)?
Does your insert video have a timecode offset?
Can you please check the system log for related error messages? You can find the system log when you open the Console application and choose "All Messages" from the list. Then look for messages from FCP X when you insert a video. Please send these messages.
Eberhard
