TrackX unsatisfied results
COW Forums : CoreMelt Plug-ins
Furokai Wolkenstein
on Jul 2, 2015 at 5:44:44 pm
Hey all,
I've just bought that bundle SliceX & TrackX and was playing a little bit around for a few hours yet.
As the tracking results in TrackX - Track Flare are awesome I don't understand why the generator TrackX is having such a problems to track the same object which I have used in Track Flare.
The generator has extreme problems to recognise the shape and it's wobbeling around and losing track pretty soon.
I cannot nearly achieve the same results as you are showing in your showcase videos which is a bit disappointing!
I'm using a macbook pro retina 15" with recently updated 10.10.4 yosemite and fcpx.
Do you know about any issues?
thank you for reply.
Eberhard Ammelt
Re: TrackX unsatisfied results
on Jul 3, 2015 at 6:50:21 am
Hello,
both plugins use the same tracker but with different default settings. The flare plugins use the tracking model "Translate, Scale, Rotate" by default, while TrackX plugins use "Perspective".
This could explain the difference, please try to specify "Translate, Scale, Rotate" as track model for the TrackX plugins as well.
Regards, Eberhard
