Stabilze or Track deinterlaced footage
COW Forums : CoreMelt Plug-ins
Anna Possberg
on Jun 25, 2015 at 9:53:54 am
I am working with a progressive project in FCPX 10.1.4 using also interlaced footage. If I click deinterlace clip in the Inspector I notice that CoreMelt LockandLoad is not functioning anymore - meaning it has no tracking data or starts to act weird (the footage pulsates if the plugin activated). Do you have any solution how to use the plugin on deinterlaced material? The FCPX Stabilization is working with this type of footage.
Anna
Eberhard Ammelt
Re: Stabilze or Track deinterlaced footage
on Jun 25, 2015 at 2:36:58 pm
Hello,
Lock & Load does not work with FCP X's deinterlace feature. I suggest to export your deinterlaced video as progressive and then import this video and stabilize then - or vice versa.
Regards, Eberhard
Anna Possberg
on Jun 26, 2015 at 6:30:19 am
Hi Eberhard, thanks. Yes, that is what I was guessing, too. If I deselect the deinterlace box the plug in is working fine. Although I read some comments from the developers that it should work also on deinterlaced material.
Well, I will use than the FCPX stabilizer for deinterlaced material which is also fine and give up motion tracking for this project.
