Lock & Load error message
COW Forums : CoreMelt Plug-ins
peter tooke
on Feb 28, 2010 at 3:57:16 pm
Hi -
just downloaded the trial version and on first try with a Prores 422(LT) clip got the following error message:
"The effect "Lock & Load X" cannot be rendered in a sequence of this size with the current graphics card."
The sequence in question contains only the single, 15 second clip. The sequence settings are: Apple Prores (LT), 29.97, 1920X1080, quality 100%.
My computer is a Macbook Pro, 2.53 ghz with 4 GB RAM, running Mac OS X 10.6.2, FCP 7.0.1.
Graphics card is NVIDIA GeForce 9400M.... stock on the Macbok Pro late 2008 unibody model.
Tried a few times...
Roger Bolton
Re: Lock & Load error message
on Feb 28, 2010 at 10:55:17 pm
Hi Peter,
please try and quit Final Cut Pro, then go to your System Preferences -> Energy Saver control panel and make sure the graphics card is set to "higher performance".
You will have to log out, then start FCP again.
You will then be using the dedicated graphics card and should be able to render the effect at your resolution.
CoreMelt V2 plugins
Kevin Larochelle
on Jun 2, 2011 at 1:23:33 am
Thanks !!! Just save my life ! Maybe not my life but my week !
