Track X Simple Tracker Not Working in FCPX with Stabilization Turned On
COW Forums : CoreMelt Plug-ins
Chris Messineo
on May 16, 2015 at 12:42:58 am
I'm trying to use the Simple Tracker on some footage that I need to stabilize. The FCPX Stabilizer works great for my needs, but when I try to then track that stabilized footage it just errors out. Is there a way to make this work?
Roger Bolton
Re: Track X Simple Tracker Not Working in FCPX with Stabilization Turned On
on May 16, 2015 at 11:12:10 am
You can't use TrackX on stabilised footage. You need to render the stabilised clip out and bring it back in as a quicktime. Or you can use Lock and Load, that works together with TrackX. And sorry we are not able to make TrackX work with the built in stabiliser, its a limitation of FCP X.
Freelance: Flame - Smoke - Resolve - Nuke - VFX Supervision
Owner / Director: CoreMelt Plugins
Chris Messineo
on May 16, 2015 at 12:35:53 pm
Thanks for the quick response.
Chris Messineo
Off Stage Films
