Animated text playback jerky
COW Forums : CoreMelt Plug-ins
Andrew Curran
on May 5, 2015 at 12:50:15 pm
Hi
I am using TrackX and FCPx 10.2 to add tracked titles to an edit. The titles are created in Motion 5.2 with simple animated moving shapes and text which build from the start. When I track an object in FCPx using the simple tracker and add the titles everything is fine with the titles perfectly following the object. However, where there are animations at the start of each title, they are very jerky on playback and final export where they build in or fade in. I have tried creating the titles as 'Final Cut Titles' in Motion and also as Motion Projects which are exported as quicktime movies with alpha channels but neither works.
I hope this makes sense! I can upload a video to demonstrate if needed.
Any suggestions?
Drew.
Andrew Curran
Re: Animated text playback jerky
on May 5, 2015 at 12:58:55 pm
Here is a link to a video that explains what I mean:
https://vimeo.com/126914774
Password pixol
thanks
Drew
Eberhard Ammelt
on May 5, 2015 at 2:14:06 pm
Hello,
there's a problem with FCP X 10.2 which may cause this behavior. Our lastest release of TrackX contains a workaround for this. Do have the latest version installed?
Regards, Eberhard
Andrew Curran
on May 5, 2015 at 2:19:21 pm
Thanks Eberhard
I'm not sure if what version I have. I downloaded an update last week but I will check for new updates now.
Drew
EDIT: The latest update has fixed this for me.
