SliceX and Transform: I am very confused.
COW Forums : CoreMelt Plug-ins
Emmanuel Tenenbaum
on Sep 12, 2014 at 7:59:10 pm
Several times those last months I've been using SliceX and experienced an issue that I found extremely annoying, see image below:
The actual mask is not aligned with the mask I designed! Today I have finally understood the cause (or at least I think): it seems to happen on clips where I have modified the Transform parameters (scale, rotation etc.)
How to make sure SliceX "follows" the transformation of the clip instead of showing the result shown on the picture ?
Thank you!!
Emmanuel Tenenbaum
http://emmanueltenenbaum.com
Eberhard Ammelt
Re: SliceX and Transform: I am very confused.
on Sep 13, 2014 at 9:20:27 am
Hello,
I can see this problem appears when applying a rotation or different scale values for both directions. At the moment I suggest to avoid these kind of transformations.
I'll check on monday if we can fix this problem on our end.
Regards, Eberhard
Emmanuel Tenenbaum
on Sep 13, 2014 at 2:33:57 pm
Thank you Eberhard for your answer.
I hope you can fix it, because Transform is a parameter that people use very commonly, I'm pretty sure a lot of people must have run into that problem.
As a work around do you advise to use a compound clip ?
Thank you!
Emmanuel Tenenbaum
http://studiotenenbaum.com
Eberhard Ammelt
on Sep 15, 2014 at 12:34:40 pm
There is no easy workaround for this issue, and a compound clip doesn't help here.
For now I suggest to apply SliceX and adjust the shape without transforming the clip. After you've completed adjusting SliceX you can apply the needed transform to the clip.
Regards, Eberhard
Emmanuel Tenenbaum
on Sep 15, 2014 at 5:51:01 pm
Thank you Eberhard, I've done what you said and it works.
I really hope you can come up with a fix.
All the best!
Emmanuel
Emmanuel Tenenbaum
Emmanuel Tenenbaum
on Feb 1, 2015 at 12:47:44 am
Hi Eberhard
Did you by any chance make progress on this topic ?
Emmanuel Tenenbaum
Eberhard Ammelt
on Feb 2, 2015 at 8:51:41 am
Hello Emmanuel,
there's no news on this topic, and we're not yet working on this.
Regards, Eberhard
