Simple Tracker fails every time
COW Forums : CoreMelt Plug-ins
Scott Tuchman
on Aug 19, 2014 at 1:43:26 pm
Once again I find myself with this damn simple tracker not working. Every time I go to track text, I get an error "cannot be used with compound clips, please use it with contained videos separately."
It makes no sense since I am following your tutorial "Track lower thirds and text with Simple Tracker" at :57 it states to make a compound clip. So WTF is going on here???
Every time I use your product it is nothing short of a hassle and time waste. What am I doing wrong?
Version - V2
Products - TrackX
Host - Final Cut Pro X 10.1.2
Iain Anderson
Re: Simple Tracker fails every time
on Aug 19, 2014 at 1:51:31 pm
Sorry for any confusion. The clip that you track — that is, the clip you connect the Simple Tracker to — must be a regular clip, not a compound clip.
However, once you've performed the tracking, the clip you insert in the Simple Tracker's "Insert Layer" image well *can* be a compound clip, and it can often be convenient to use one.
shan wells
on Aug 29, 2017 at 8:56:06 pm
This is not a good answer. I am importing an .mov clip into FCPX, and the damn thing sees it as a compound. It's abundantly not.
