Coremelt Luminous RGB Trails glitches! :(
COW Forums : CoreMelt Plug-ins
Lola Mala
on Jun 24, 2014 at 1:17:09 pm
Hi -
I'm getting VERY frustrated with this plugin. The Coremelt Luminous RGB Trails produces glitches whenever I render it out, can anyone tell me why this is?
I'm on a Macbook Pro 2.66ghz/1tb/8GB, using Final Cur Pro 10.0.8
(See screenshot attached for typical glitching)
Eberhard Ammelt
Re: Coremelt Luminous RGB Trails glitches! :(
on Jun 24, 2014 at 4:11:45 pm
Hello,
can you please check the system log for possible error messages from FCP X?
You can see the system log when you open the Console application and choose "All Messages".
What is the primary GPU of your MacBook Pro? If present, can you please try the secondary one as well?
Please also try to restart the computer, does it work now? The problem might have appeared after setting the computer asleep.
Regards, Eberhard
Lola Mala
on Jun 24, 2014 at 4:15:39 pm
"Graphics NVIDIA GeForce 320M 256 MB"
NVIDIA GeForce 320M:
Chipset Model: NVIDIA GeForce 320M
Type: GPU
Bus: PCI
VRAM (Total): 256 MB
Vendor: NVIDIA (0x10de)
Device ID: 0x08a0
Revision ID: 0x00a2
ROM Revision: 3533
I have this problem all the time with this filter. Never happens with other filters such as Crumplepop, etc...
Eberhard Ammelt
on Jun 24, 2014 at 9:57:51 pm
Can you please check the system log for error messages?
Eberhard
Lola Mala
on Jun 25, 2014 at 12:03:38 pm
Hi -
Hope this helps, I'm not sure what to look for ...? :
Eberhard Ammelt
on Jun 25, 2014 at 1:41:09 pm
The system log is text based. You can see it when you open the Console application and choose "All Messages". Then look for messages from Final Cut Pro while the glitches appear. Please send these messages to me: eberhard (at) coremelt.com
Eberhard
