Track Layer: showing part of clip other than at the beginning?
COW Forums : CoreMelt Plug-ins
Brian Thomas
on Jun 22, 2014 at 8:22:25 pm
When I 'Insert Layer" it seems only to want to take the beginning of the clip. I'm probably missing something obvious but how does one indicate that the "Surface" should start at some point other than at the beginning? I've been clicking on a clip and trying to set up a range within the clip but I always end up at the beginning.
For the moment I've been doing a "Share" from the clip involved which starts at the point I want to have in the "Surface" but that is a little bit clumsy. Is it possible to indicate an alternative starting point..?
Thanks for any help.
FCPX and PPro 6. iMac 24 + MBP 17". Near Geneva, Switzerland
Brian Thomas
Re: Track Layer: showing part of clip other than at the beginning?
on Jun 23, 2014 at 9:13:29 am
In case it's relevant, I'm using the absolute latest version of everything.
Eberhard Ammelt
on Jun 23, 2014 at 9:32:48 am
Hello,
you can specify another start time in the following way:
Open the clip you want to insert in the timeline.
Change the in time of the clip to the time where you want it to start.
Then make a compound clip from it.
Finally, in TrackX assign the new compound clip.
Regards, Eberhard
Brian Thomas
on Jun 23, 2014 at 9:51:39 am
Many thanks Eberhard - I didn't think of making a compound clip for that. Works great now!
