New Lock and Load Problem
COW Forums : CoreMelt Plug-ins
Matti Lieskala
on Feb 9, 2010 at 11:34:31 am
Hi i'am having problem whit new lock and load. Did use lock and load frames to one clip and in FCP hdv sequence it seems to be working perfectly, but after i did send it to compressor and did make it .mpeg2 version for DVD it shows that clip that i used lock and load is broken. In that clip it shows
like every other frame is black.I was shocked to notice this after i was double checking DVD. Checked in FCP after that there it shows like it should.
Just wondering what might cause this.
Thx
-Matti-
Eberhard Ammelt
Re: New Lock and Load Problem
on Feb 9, 2010 at 5:27:37 pm
Hello, can you tell if your hdv clip is progressive or interlaced. Do you see any related messages in the log file when exporting?
Matti Lieskala
on Feb 11, 2010 at 10:46:18 am
Clip is interlaced.
Eberhard Ammelt
on Feb 12, 2010 at 5:31:30 pm
Hm, I tried what you did but can't reproduce the problem with Compressor preset: "HD MPEG-2; 18,0 MBit/s". Could you send us your exact FCP sequence settings and the Compressor preset you've used? Thanks.
Matti Lieskala
on Feb 16, 2010 at 8:24:58 am
Fcp:
Frame size: 1440x1080
Vid rate: 25fps
compressor: HDV 1080i50
Compressor:
Custom Video:
Type Mpeg-2: video elementary stream
Video encoder: Format: M2V
Width Height: 720x576
-Matti-
Eberhard Ammelt
on Feb 16, 2010 at 6:55:41 pm
I didn't find this exact Compressor setting with PAL size. Can you please check the log file for any error messages?
