How to stabilize clips longer than 30 mins with Lock & Load?
COW Forums : CoreMelt Plug-ins
David Bayles
on Mar 31, 2014 at 3:16:54 pm
I cut the clip in the middle, making two clips each less than 30 mins, then dropped the "Stabilize Only" plugin on the first clip and clicked "Track Motion", but when I drop the plugin onto the second part of the clip, the on-screen display doesn't show up.
Please help!
Eberhard Ammelt
Re: How to stabilize clips longer than 30 mins with Lock & Load?
on Mar 31, 2014 at 5:28:10 pm
Lock & Load should behave in the same way on the 2nd part as on the 1st part.
Did you select the 2nd clip part and the Lock & Load instance, and did you move the playhead over the 2nd part?
If the onscreen controls still don't appear, can you please check the system log for error messages?
Regards, Eberhard
David Bayles
on Apr 1, 2014 at 3:24:43 pm
Thanks! I didn't have playhead over the clip. Working great now!
