Batch Editing 1200 files to add intro and outro, any solution?
COW Forums : Art of the Edit
Cristian Ruffini
on Apr 26, 2017 at 9:28:26 am
Hi there creativeCow !
I need to find a solution to be able to batch add the same intro and outro to 1200 videos. As easy as it sounds, add the Intro at the beginning of each clip and the outro at the end.
Is there any software that does so? any solution built in Final Cut X, Premiere, AE ?
Thanks in advance,
Best
Cristian
Mark Suszko
Re: Batch Editing 1200 files to add intro and outro, any solution?
on Apr 27, 2017 at 2:41:43 pm
Set up a template in Motion... Import to FCPX. Create a template project that already has the intro and outro in it, then add the clips to the template?
