Premiere pro CC ruining every last frame of my video,Please someone guide me through this problem
COW Forums : Art of the Edit
Ali Khawaja
on Mar 23, 2016 at 1:56:42 pm
I'm editing a wedding video in primere pro CC,I am working with nested sequences,now as I finished editing I rendered the master sequence on the following settings
x.264
HDV 720p 25fps
Lumteri colors=warm mid tones
but in rendered video,every clip who were have a "dip to black" transition now has a strange colorized last frame(see the example picture).Pls help
<a href='https://images.creativecow.net/292043/problem.jpg'><img src='https://i1.creativecow.net/u/292043/problem.jpg' border='0' /></a>
Mark Suszko
Re: Premiere pro CC ruining every last frame of my video,Please someone guide me through this problem
on Mar 23, 2016 at 4:37:52 pm
Not a Premiere expert, but it sounds like the fade may be causing problems with the color plug-in's blending mode, maybe. Just a guess. Can you try adding a slug of black on a track above the transition point, and instead of having the transition happen on the main track, add a dissolve to the black slug instead? That might get you past the deadline so you can go back later and figure out abetter fix...
