jump cut? fast cut? whats the name and how to proper make it
COW Forums : Art of the Edit
Louis Aragón
on Nov 19, 2014 at 2:07:07 pm
hello im in a rush, deadline is in one week, so i still have to film , cut and edit..
what is the name of that? those fast scenes. i know is just several clips together with a short duration but ... what i've tried doesn't look good.
any recommendation , tips about this.
sincerely thanks.
Louis.
Mark Suszko
Re: jump cut? fast cut? whats the name and how to proper make it
on Nov 19, 2014 at 4:21:49 pm
Smash Cut.
Richard Herd
on Nov 19, 2014 at 7:30:35 pm
Hip Hop Montage
Hip hop montage[edit]
A hip hop montage is a subset of fast cutting used in film to portray a complex action through a rapid series of simple actions in fast motion, accompanied by sound effects. The technique was first given its name by Darren Aronofsky, who used the technique in his films Pi and Requiem for a Dream to portray drug use.[1] The technique is derived from the hip hop culture of the 1990s and jump cuts first pioneered in the French new wave.
http://en.wikipedia.org/wiki/Fast_cutting
Mark Suszko
on Nov 19, 2014 at 10:13:33 pm
The montage is made up of smash cuts: jarring abrupt transitions between apparently unrelated images.
Bill Davis
on Nov 28, 2014 at 7:09:00 pm
Louis,
Just to help with the terminology - a Jump Cut is what happens when a shot is interrupted and you need to cut a part out of a continuous take. The best example is someone at a podium speaking. If they suddenly cough mid sentence - you need to cut out the cough - and when you do that, since the position of the speaker is going to be different before and after the edit, the picture will JUMP rather than play cleanly.
Generally, jump cuts call attention to an edit and take the audience out of the scene flow. However, audiences have become somewhat accustomed to seeing jump cuts and if the story continues to make sense, it can be acceptable as a cutting style if the material supports that.
Hope that helps.
Know someone who teaches video editing in elementary school, high school or college? Tell them to check out http://www.StartEditingNow.com - video editing curriculum complete with licensed practice content.
