De-Interlacing Issues
COW Forums : Art of the Edit
Ryan Jarmon
on Jul 12, 2010 at 3:32:54 am
Hi there!
I am having some difficulty de-interlacing my video and am not sure what steps I need to or need not take. Here's what I am doing.
I have editing the movie in Avid Media Composer, and have de-interlaced through timewarp - fluid motion. From there I export it into Sorenson Media. I place the default 16x9 dvd large filter on it, and compress away. After that I import the compressed video into TMPGEnc. I make sure it is in 16x9, 720x480 res. I tell it that the source is progressive, because it technically is at this point, correct? Then I create the dvd files and burn!
However, when I watch the dvd, it is interlaced and I see horizontal lines like crazy whenever there is big movement.
What am I doing wrong... or what can i do instead?
grinner hester
Re: De-Interlacing Issues
on Jul 14, 2010 at 7:04:43 pm
It's an Avid thang. You have to mix the entire show down before exporting a reference to sorenson.
This bug was created whent hey killed the meridien line and they just havn't seen a reason to mend it.
© 2018 All Rights Reserved
