Animation gets jagged on DVD?
COW Forums : Art of the Edit
Joshua Carlon
on Jul 20, 2009 at 8:27:03 pm
Hi everyone --
I've got an animation project that I could use some assistance on. It's assembled in FCP on a 640 x 480 timeline. The clips are 640x480 exported from AE but there were two different codecs used for export -- some were done with Animation codec and some at Uncompressed 8 bit. Because of the 640 square, I'm dropping the assembled sequence into a 720 NTSC sequence for a Compressor export. Looks great until I make a DVD (in DVDSP). When I watch the DVD on a regular tv, I'm seeing jagged edges on many of the dark lines -- anyone know what's causing this? Is this a field dominance thing? A square vs rectangular pixel thing?
thanks for any help!
J
Shane Ross
Re: Animation gets jagged on DVD?
on Jul 21, 2009 at 4:40:34 pm
720 NTSC sequence? What are the sequence settings? DV? If they are then you are really compressing your footage.
Shane
grinner hester
on Jul 28, 2009 at 2:51:04 am
anytime you scale something larger than it's original; source, you will get some aliasing. Add tot hat the compression froma DVD and ya get what you are seeing.
Render at full rez and keep it as clean as ya can till ya burn at the highest kbs you can. That's really all you can do.
