Westward Ho! Tech Questions for Mike Sullivan
COW Forums : Art of the Edit
Les Stuck
on Oct 20, 2008 at 4:53:53 pm
Hey Mike,
I really enjoyed your article in the July/August Cowzine.
Would you mind giving us a few more technical details?
You wrote that the multiple DVDs are played back with frame-accurate sync.
What hardware is used for that?
Second question. You wrote that the lighting cues are accurately sync'd to
the DVD playback. How was that done?
Sorry about the Sox :(
Les
http://www.stuckfootage.com
Mike Sullivan
Re: Westward Ho! Tech Questions for Mike Sullivan
on Oct 21, 2008 at 4:31:24 pm
Hi Les,
I'm glad you liked the article. For the theater in Wyoming we used a Dave Jones Synchronizer to get the DVD's to play at the same time. We don't really do much DVD's anymore, however. Nowadays we use Alcorn-McBride BinLoop players to play Mpeg-2 files off of flashcards or a centralized server depending on the type of file (SD or Hd, etc.) The lighting cues are written as an Excel spreadsheet. The Creative Director usesthe timecode of the film to decide which lights will be active and for how long. A programmer takes that document and uses Cue Server to trigger each light, its fade ups and downs, as well as its intensity. Does that make sense?
Les Stuck
on Oct 21, 2008 at 7:53:27 pm
Thanks for the info. Yes, both the Dave Jones unit and the Adam-McBride unit
look like real problem solvers for this type of work.
> The Creative Director uses the timecode of the film to decide which lights will be active and for how
Not quite. I'm used to sending MIDI to a lighting board to advance cues.
So what is the master sync? Do you run both the Adam-McBride and the Cue Server
off one NTSC sync generator? Or is there a master SMPTE generator?
Or does the Adam-McBride output SMPTE that the Cue Server slaves to?
Is the Cue Server hardware or software? Does it combine SMPTE and the Cue List (what
format?) to send DMX to the lighting board? I can't seem to find Cue Server with Google.
Sorry to be so clueless, but I find this technique quite interesting, and I like to understand
the different ways people have resolved these issues.
Thanks for your time!
Les
