What production monitor do you use for HD?
COW Forums : Art of the Edit
on Oct 6, 2006 at 5:01:01 pm
I hope this isn't too off topic for this forum, but I wasn't sure exactly where it fit. I'm putting together a new editing system and I need a new production monitor. Since I do some color correction, I think CRT is the best choice for an accurate picture. I'm going to be doing a lot more 16:9 HD with this system so I obviously want a monitor with that can display that. The JVC DT-V1710CG with the IF-C01COMG Component/RGB card was recommended to me. That monitor seems nice, and it's auto sensing which is good since I still do SD 4:3 stuff too. My only problem is that the monitor is a 4:3 box.
My first problem with that is that it's a 17" monitor, so the letterboxed 16:9 will be a bit on the small side. I'm used to cutting SD on my current monitor which has a 20" 4:3 monitor.
My second problem is spending over $2K on a 4:3 monitor when 4:3 will eventually be phased out. Granted, that won't be too soon, but it seems smarter for the long run to buy a native 16:9 monitor.
What are your thoughts? What are you using? Keep in mind, this monitor is only for me at the editing desk. The clients have their own monitor.
Shane Ross
Re: What production monitor do you use for HD?
on Oct 7, 2006 at 5:42:09 am
I am using a Sony PVM-14L5 Multiformat monitor with HD SDI input card (optional). Total of $3100. BUT...they no longer sell them new.
4:3 and 16:9. HD and SD. Great monitor.
Littlefrog Post
Pixel Monkey
on Oct 11, 2006 at 1:44:54 pm
Avoid Frontniche and Vutrix at ALL COSTS!
Also, make sure if you go the Plasma or LCD route that it de-embeds the audio through the HDSDI. We didn't check that, and all our audio is 2-frames off unless we feed it through the monitor separately via analog RCA cables! (?>!!@>$#@$@!)
`(=)`/...Pixel Monkey
A picture says 1000 words. Editors give them meaning.
© 2018 All Rights Reserved
