Cancelling out a slight echo?
COW Forums : Art of the Edit
noddydog
on Jun 1, 2006 at 10:09:55 pm
I recently recorded a voice over for a project unfortunately it has a very slight echo on it (acoustics of the room weren't great). I am using Premiere Pro 1.5 Can anyone tell me if there is a way to cancel out/remove this echo? I wondered if it is possible with the 'delay' controls found in the 'reverb' audio tool, i.e. reverse the effect of creating an echo via a delay in the opposite direction (or does that just create more echoes?).
We also have Adobe Audition 1.5 if that also has any tools that may be useful.
Thanks.
noddydog
Re: Cancelling out a slight echo?
on Jun 2, 2006 at 9:55:46 pm
Thanks, I appreciate it. It will be a hassle, but I'll get it rerecorded. At least I know for next time.
mark harvey
on Jun 5, 2006 at 5:54:13 pm
If you take the clip into Audition, you should be able to see the echo clearly in the waveform.....remove it between words by either just cutting, or try using the noise removal tool.....
Mark
