putting color into my black and white footage
COW Forums : Art of the Edit
tink14
on Oct 24, 2005 at 2:32:31 pm
what I'd like to do is take footage that's in black and white and put color over it, but have the color be animated. Maybe have someone's coat be red and have the red bounce a little. Can this be done?
marcus adburgham
Re: putting color into my black and white footage
on Oct 24, 2005 at 3:12:55 pm
Yes it can! You need compositing software like Combustion or After Effects to treat the footage using a technique called "rotoscoping" - which means keyframing a selection over the area that needs color and then adding an effect to that selection which will tint the B&W footage.
Victoria Ellis
on Oct 24, 2005 at 10:34:12 pm
yes - this is really fun, especially for long bits of footage...(!)
AVID_CHUMP
on Oct 25, 2005 at 1:05:32 pm
If you have animate in an AVID, then you can achieve this without using after effects or combustion.
It is however a painstaking process to say the least !
Mark Suszko
on Oct 25, 2005 at 4:30:49 pm
Depends on the footage, you say it's black and white... if there are enough distinct shades of gray in the footage, I would try to use luminance Keying to isolate the one element that needs colorizing. Once you have that matted, you could colorize it directly or put a copy of the matte on another track and then effect it further, keeping all track in synch. This has the appeal of not needeing ANY keyframing or tedious roto work.
It may or may not work in your case, depends completely on the quality and consistency of the footage.
