no video signal blue
COW Forums : TV & Movie Appreciation
Andrew Wilson
on Aug 26, 2010 at 2:06:13 am
This seems like the best forum on Creative Cow that I'm going to find for my question.
I am wondering why monitors + projectors show the color blue when there is no video signal. When was this decided? Who decided? How did the decision become implemented?
In short, why is the no video signal screen blue?
Sincerely,
Andrew
Mark Suszko
Re: no video signal blue
on Aug 26, 2010 at 8:19:10 pm
Short answer is I don't know.
Also, the broadcast forum or forums where engineers hang out would seem the more logical place to ask this, but I digress.
If you want to hear my guess as to why blue:
It is one of the three primary video colors, so it is easy for a video generator to, um, generate. And if your choices are red, green, or blue, plus black (often confused with "no signal") or full white (very bright and disturbing) blue is the least visually objectionable of those colors to choose.
Static is what you used to get in the abscence of a signal, and people found that very jarring, especially when coupled with noise on the audio circuit. Those were functions of analog signal flow, and TV's, VCR's DVD players, etc today are nearly all digital inside, so no static noise to generate.
If the TV sent just black, you may think the TV is off, so you want to send a color that shows the screen is getting *something* and that it is in color, versus B&W. That information alone can tell an experienced technician some important things about the set's status
Mike Cohen
on Aug 30, 2010 at 4:26:31 pm
Mark hit all the right points. The early video game systems hooked up via an A-B switch attached to the antenna receptacle on an old analog tv. It was common to see snow on one channel and black on the other. Same went for the early VCR's.
Blue is much easier to work with.
Mike Cohe
Mark Suszko
on Aug 30, 2010 at 4:51:53 pm
Maybe I should take my guessing skills to Vegas? Naw, My guess is, I'll lose:-P
