PMW-100 Audio issues
COW Forums : Sony XDCAM Optical Disc & Related
Dre Mark
on Apr 28, 2017 at 1:53:27 pm
Hey everyone. I started a new job and they have the PWM-100 XDcam. Not sure how long they've had it or how it's been cared for/used in the past. After rummaging through boxes of equipment, finally found the battery & charger, found an external shotgun mic for it and was testing it out.
When I monitor the audio with headphones, everything is fine. I can hear audio, mic works. However when I play it back on my computer from the SD card, no audio has been recorded.
I've tried both an external mic and the internal mics -- same result. Yes, I have all the settings for internal/external, audio levels, etc. correct. No, it's not set on interval or frame recording which would cause audio to not be recorded.
Any ideas? We need it for a press conference Monday.
© 2018 All Rights Reserved
