Mixing Sony FS-7 with X-70 footage
COW Forums : Sony XDCAM Optical Disc & Related
Lucas Chambers
on Feb 10, 2016 at 4:59:17 pm
I know, it's an affront to the FS7 quality, but alas I have to use four cameras and my budget just won't allow 4 FS7s. I'm a bit new to PPs, LUTS and the whole shebang, so I've been struggling to find the best setup to obtain compatible footage using the FS7, X-70, EX3 and a Canon 7D. So far I've figured that my best bet would be to shoot CineEI with the FS7 (S-Log3) and Technicolor Cinestyle with the 7D. These will allow adapting to the other cams in post, right? Or wrong? And then the BIG question: what's my best bet on the EX3 and X70? Which picture profile or gamma should I use to have as flat an image as possible? Or should I go for Rec709 in both those two and then grade the Canon and FS7 footage to those? Thanks a lot for the input. I'll learn tons from this, I'm sure.
