U2s not accepting Xdcam discs
COW Forums : Sony XDCAM Optical Disc & Related
steve knattress
on Jun 12, 2015 at 7:56:47 am
Is anyone else having problems with xdcam discs taking disc accessing it then ejecting it after about 5-10 seconds.
This has only just started happening. 2different cameras 2u2s both with latest firmware and software on PC
The cameras are using new pre formatted sony and Fuji discs.
The Fuji seem worse often needing tens of insertions before they will stick. Sony not as bad but still sometimes need several goes.
This does not happen to all disks (both 23 and 50 gb recording HD 1080i50. 50mb per sec)
This is getting very tedious and Is really slowing editing down
Thanks Steve
Ian Cook
Re: U2s not accepting Xdcam discs
on Jun 16, 2015 at 11:38:08 pm
what driver and firmware are you running? can you check in the utility and make sure they are current and matched? http://www.sonycreativesoftware.com/xdcamdrive . You can also check the Utility's error log for mechanical and other errors.
