FCPX and MXF to optical drive
COW Forums : Sony XDCAM Optical Disc & Related
Slobodan Kosanovic
on Jan 26, 2015 at 8:51:49 pm
Ive just seen this thread where Ian explains what is needed and how to export mxf files from FCPX to optical XDCAM drive.
I have done as instructed but with both PDW-U1 and PDW-D1 im unable to export from FCPX. FCPX states that sharing is complete but no files are written to disc. If i try "Import" option from content browser message states "Failed to import the clip".
On the same machine i have successfully exported to XDCAM optical disc via FCP7 and XDCAM transfer utility.
Machine is MacPro 6.1 (little black barrel) PDW-U1 is USB based and PDW-D1 firewire based so we are using Thunderbolt to Firewire adapter but nevertheless the result is the same.
Ive got FAM drivers properly installed and im repeating from FCP7 on same machine everything is fine.
Is there any solution to this issue?
Slobodan Kosanovic
Re: FCPX and MXF to optical drive
on Jan 29, 2015 at 5:43:48 pm
i have tried with PDW-U1, PDW-U2, PDW-D1 and PDW-1500 on 5 different macs with same results.
Please if anyone has seen similar behavior report here.
Thanks in advance!
© 2018 All Rights Reserved
