Batch edit clip names
COW Forums : Sony XDCAM Optical Disc & Related
Michael Sanders
on Jun 19, 2014 at 7:16:59 pm
Hi All.
Have got 14 discs here and the planning wasn't done properly.
Instead of manually going through and renaming each clip is there a way to batch edit all the clips?
Michael Sanders
London Based DP/Editor
Ian Cook
Re: Batch edit clip names
on Jun 19, 2014 at 8:43:34 pm
regrettably, no, we can batch in title metadata but not the actual file names. you can, however, use a bulk file renaming utility and manually rename just the .mxfs in /CLIP. as long as Free Naming is enabled on the device this will work and the XMLs and Proxies will be automatically updated.
