Ejecting XDCAM HD Discs Crashes Mac
COW Forums : Sony XDCAM Optical Disc & Related
Andy Moore
on May 12, 2014 at 1:54:16 pm
Ejecting XDCAM HD Optical Discs from my mac randomly crashes the computer.
I've tried ejecting from XDCAM Transfer, Finder, and directly from PDW-F30 XDCAM Deck and they all cause Mac to crash on about every 8th Disc. This has also happened to colleague when ejecting from Camera PDW-F330. I've upgraded to the latest firmware and can only assume it is a Mavericks issue (I know, I shouldn't be on Mavericks but I am). Any ideas?
Specs:
Mac Pro Mid 2012
Mavericks 10.9.2
64 GB RAM
2x2.4 GHz 6-core
FCP 7
Plenty of hard drive space on OS and RAID
XDCAM Transfer 2.13.0
Andy Moore
Videographer/Editor
Sony PDW-F330L
Final Cut Pro 7
Ian Cook
Re: Ejecting XDCAM HD Discs Crashes Mac
on May 12, 2014 at 2:40:58 pm
Are you running the latest FAM driver and V2 of the deck software?
http://www.sonycreativesoftware.com/ilinkfamdriver
Andy Moore
on May 12, 2014 at 3:11:03 pm
Ian,
Thanks for the quick reply. Yes, I'm using V2 of the Deck Software and FAM Driver V2_3_2
Andy Moore
Videographer/Editor
Sony PDW-F330L
Final Cut Pro 7
Ian Cook
on May 12, 2014 at 3:12:50 pm
Are you getting kernel panics? The latest FAM is qualified for Mavericks and we have not seen any major issues. Can you uninstall/reinstall the FAM driver?
Andy Moore
on May 12, 2014 at 3:50:06 pm
Ian, I uninstalled and reinstalled the FAM Driver. I then popped in and out a few discs and it happened again! My screens go black and then a few seconds later, the computer restarts stating: "Your computer restarted because of a problem." I've run Disk Utility and everything checks out okay.
Andy Moore
Videographer/Editor
Sony PDW-F330L
Final Cut Pro 7
Ian Cook
on May 12, 2014 at 3:53:00 pm
Open Console and take a look at the crash thread in your system log. There may be some clues there. I cannot make the same behavior occur on my Mavericks partition here.
Andy Moore
on May 12, 2014 at 4:15:52 pm
Ian, I've never looked at Console before and don't understand what it all means. Below is the last minute of data before the crash.
5/12/14 11:42:04.000 AM kernel[0]: com_sony_protocol_prodisc : Prodisc Injected. GUID = 800460201220586
5/12/14 11:42:04.000 AM kernel[0]: com_sony_protocol_prodisc : list buffer size = 37888
5/12/14 11:42:04.469 AM /System/Library/Filesystems/pdudf.fs/Contents/Resources/../../pdudf.util[372]: pdudf.util: ERROR: 346
5/12/14 11:42:04.479 AM /System/Library/Filesystems/pdudfr.fs/Contents/Resources/../../pdudf.util[373]: pdudf.util: ERROR: 346
5/12/14 11:42:04.570 AM com.apple.kextd[12]: kext com.sony.filesystem.prodisc_fs 203021012 is in exception list, allowing to load
5/12/14 11:42:04.000 AM kernel[0]: KEXT loaded
5/12/14 11:42:04.000 AM kernel[0]: pdfs_init 40400
5/12/14 11:42:04.000 AM kernel[0]: pdfs_init 3ffff
5/12/14 11:42:04.000 AM kernel[0]: pdfs_mount
5/12/14 11:42:04.000 AM kernel[0]: /dev/disk2
5/12/14 11:42:04.000 AM kernel[0]: Seek Alignment = 512
5/12/14 11:42:05.000 AM kernel[0]: pdfs_readdir: busy1
5/12/14 11:42:05.360 AM fseventsd[70]: Logging disabled completely for device:1: /Volumes/XDCAM800460201220586
5/12/14 11:42:05.503 AM mds[59]: (Normal) Volume: volume:0x7fd80a000000 ********** Bootstrapped Creating a default store:1 SpotLoc:(null) SpotVerLoc:(null) occlude:0 /Volumes/XDCAM800460201220586
5/12/14 11:42:05.000 AM kernel[0]: pdfs_hashrem : /General/.xdcamWriteTestFile.tmp
5/12/14 11:42:06.000 AM kernel[0]: pdfs_hashrem : /General/.xdcamWriteTestFile.tmp
5/12/14 11:42:09.000 AM kernel[0]: disk2: unsupported function.
5/12/14 11:42:09.000 AM kernel[0]: pdfs_hashrem : /Clip/C0003M01.XML
5/12/14 11:42:09.000 AM kernel[0]: pdfs_hashrem : /Clip/C0002M01.XML
5/12/14 11:42:09.000 AM kernel[0]: pdfs_hashrem : /Clip/C0001M01.XML
5/12/14 11:42:09.000 AM kernel[0]: pdfs_hashrem : /Clip/C0003.MXF
5/12/14 11:42:09.000 AM kernel[0]: pdfs_hashrem : /Clip/C0002.MXF
5/12/14 11:42:09.000 AM kernel[0]: pdfs_hashrem : /Clip/C0001.MXF
5/12/14 11:42:09.000 AM kernel[0]: pdfs_hashrem : /MEDIAPRO.XML
5/12/14 11:42:09.000 AM kernel[0]: pdfs_hashrem : /DISCMETA.XML
5/12/14 11:42:09.000 AM kernel[0]: pdfs_hashrem : /General
5/12/14 11:42:09.000 AM kernel[0]: pdfs_hashrem : /Edit
5/12/14 11:42:09.000 AM kernel[0]: pdfs_hashrem : /.fseventsd/no_log
5/12/14 11:42:09.000 AM kernel[0]: pdfs_unmount 0
5/12/14 11:42:09.000 AM kernel[0]: pdfs_unmount--
5/12/14 11:42:09.000 AM kernel[0]: com_sony_protocol_prodisc: FAMReleaseEventHandler
5/12/14 11:42:10.100 AM XDCAM Transfer[329]: Waited for device to actually unmount in NSWorkspaceDidUnmountNotification handler
5/12/14 11:42:10.000 AM kernel[0]: FAMStorage : ejectMedia
5/12/14 11:42:10.000 AM kernel[0]: doEjectMedia
5/12/14 11:42:10.000 AM kernel[0]: com_sony_protocol_prodisc : Eject done
5/12/14 11:42:10.000 AM kernel[0]: com_sony_protocol_prodisc : Prodisc Ejected.
5/12/14 11:42:40.000 AM kernel[0]: com_sony_protocol_prodisc : Prodisc Injected. GUID = 800460201220586
5/12/14 11:42:40.000 AM kernel[0]: com_sony_protocol_prodisc : list buffer size = 37888
5/12/14 11:42:40.146 AM /System/Library/Filesystems/pdudf.fs/Contents/Resources/../../pdudf.util[398]: pdudf.util: ERROR: 346
5/12/14 11:42:40.151 AM /System/Library/Filesystems/pdudfr.fs/Contents/Resources/../../pdudf.util[399]: pdudf.util: ERROR: 346
5/12/14 11:42:40.000 AM kernel[0]: pdfs_mount
5/12/14 11:42:40.000 AM kernel[0]: /dev/disk2
5/12/14 11:42:40.000 AM kernel[0]: Seek Alignment = 512
5/12/14 11:42:40.697 AM fseventsd[70]: Logging disabled completely for device:1: /Volumes/XDCAM800460201220586
5/12/14 11:42:40.785 AM mds[59]: (Normal) Volume: volume:0x7fd80c82be00 ********** Bootstrapped Creating a default store:1 SpotLoc:(null) SpotVerLoc:(null) occlude:0 /Volumes/XDCAM800460201220586
5/12/14 11:43:40.000 AM bootlog[0]: BOOT_TIME 1399909420 0
Ian Cook
on May 12, 2014 at 4:21:36 pm
Are you seeing this with multiple discs? Do you see any difference if XDCAM Transfer is not running and accessing files? I.e. boot, load/eject discs multiple times, do you still get the kernel panic?
Andy Moore
on May 12, 2014 at 4:31:12 pm
Ian, Yes this is happening with multiple discs. It also happens without XDCAM Transfer open and just ejecting from Finder. It's like playing Russian Roulette-it can happen with any disc, at anytime, no matter how I eject it or what else is open or closed.
Ian Cook
on May 12, 2014 at 4:34:03 pm
Do you have another Firewire XDCAM device? Would like to be able to rule out the deck if possible.
Andy Moore
on May 12, 2014 at 4:53:50 pm
Ian, Yes it's also happening when going directly from the Camera PDWF330L. I am going to borrow a PDW-U1 Drive and see if there are any issues with that. It connects via USB while the other 2 devices connect via Firewire...I wonder if that makes any difference. I'll test that this afternoon and will write back with my results. Thanks again.
Ian Cook
on May 12, 2014 at 4:56:40 pm
ok, that is good info. i am very curious to see if it happens with the drive since there is no FAM driver in that scenario. make sure you are running drive software version 5.
Andy Moore
on May 13, 2014 at 3:36:41 pm
Ian, I've loaded and ejected about 75 discs using the PDW-U1 without a single shutdown. Yeah!!! Unfortunately, I have to give the drive back, as I was only borrowing it. It would appear to me that the problem is the FAM driver interacting with Mavericks. I never had this issue before Mavericks and now it has happened on one Mac Pro and two Mac Book Pros. And it has happened both with a deck and a camera as the source. All devices have the latest software and firmware. Any other thoughts?
Ian Cook
on May 13, 2014 at 3:46:46 pm
I haven't been able to reproduce this. Will take a closer look at it here. Feel free to email me so we can document this and keep in touch. Ian dot Cook at am dot sony dot com.
Noble Robinette
on Dec 15, 2014 at 8:06:22 pm
Hi, did you all ever come to a conclusion over what was causing this? I'm having the exact same issue. We have the most up-to-date fam driver and it crashes roughly every 8 or 9 tapes. It definitely isn't consistent and it never crashes with the U1. Just thought I'd check. Thanks!
