exporting to XDCAM bypassing FCP
COW Forums : Sony XDCAM Optical Disc & Related
Marcos Horacio
on Nov 7, 2013 at 11:42:34 pm
Hi everyone,
My computer (MacPro) has some serious issues and I can't use it. I was able to move the XDCAM drive (PDW-U2) to another station, copy the MXF files I was able to create but there's no FCP 7 running on it.
The question is: can I use Sony's content browser to export to a XDCAM disk, bypassing my NLE altogether? How do I do it?
Thanks a lot!
Mac Pro
3.33Hhz 6-Core Intel
12GB RAM
10.8.1
FCP Studio 2
AE / PS / AI CS6
Ian Cook
Re: exporting to XDCAM bypassing FCP
on Nov 8, 2013 at 12:20:50 am
If all you need to do is move XDCAM .mxf files to it just install the driver and use Browser to drag and drop to the U2
http://www.sonycreativesoftware.com/xdcamdrive
Marcos Horacio
on Nov 8, 2013 at 12:40:21 am
Thanks for the response, Ian. But for some reason, although I can see the the mxf file on the desktop, it doesn't show on the tree view of my content browser. I see the folder where it is but I can't see the file. Therefore, I can't drag and drop it.
Any suggestion?
Mac Pro
12GB RAM
10.8.1
FCP Studio 2
AE / PS / AI CS6
Ian Cook
on Nov 8, 2013 at 12:48:16 am
Browser will only see a standalone XDCAM file if it is part of a disc image with all the correct directories. You can easily create this structure OR you can drag and drop the file directly to the Clip folder using Finder. If it's a legal XDCAM file and matches the frame rate/frame frequency of existing clips on the disc, this will work.
To create a disc image:
1. create a new folder on your system
2. highlight this folder in one of Content Browser's Explorer/Navigation windows
3. File-->Import-->navigate to the .mxf file
This will embed the .mxf file in a proper disc image so you can see it within CB.
In the event you just want to play/QC the file you can also drop it onto CB's preview monitor window and it will play.
Marcos Horacio
on Nov 8, 2013 at 2:05:16 am
Thanks again, Ian. I just tried doing it with 2 different files and I got this message: PDW U2 SN: XXXXXX CANCELLATION OR ERROR MIGHT HAVE OCCURRED WHEN WRITING....
Ouch! Any other advice?
Thanks again!
Mac Pro
12GB RAM
10.8.1
FCP Studio 2
AE / PS / AI CS6
Ian Cook
on Nov 8, 2013 at 3:33:36 pm
You have the latest driver installed and are copying to the CLIP folder? (NOT the CLPR folder)
John Barata
on Jun 12, 2014 at 12:29:31 am
How did this work out for you? I am in the same boat but with a U1. I send my show out to get closed captioned and then I get a mxf file back to me that I need to put on a disc and send to the broadcaster. I don't want to go through FCP or Avid because I'm afraid to mess up the CC. I think this is the best way to do it but I haven't seen much info on the web on how to properly create an xdcam disc without going through a NLE.
