PC Avid can't read XDCAM OP1a created on Apple
COW Forums : Sony XDCAM Optical Disc & Related
Lee Warner
on Sep 27, 2013 at 3:47:21 pm
We have the OP1a MXF format listed on our compatible codec submission doc. I ran into a spot today that was transcoded on an Apple (assuming Final Cut or Compressor) in that format but our PC Avid or Premiere Pro would not accept. Is there a trick to creating a cross compatible OP1a on a Apple computer?
Lee
Ian Cook
Re: PC Avid can't read XDCAM OP1a created on Apple
on Sep 27, 2013 at 4:48:49 pm
What application is creating the file? FCP 7.0.3 or X (with our Export plugin), Episode 6/7, Premiere CS6/CC and Avid Media Composer 7 should all create good files. There was a bug in Media Composer 6.5 that caused it to put some bad metadata into MXF op1a exports. This was fixed in 7.0.1.
What happens when you try to import/AMA the file?
Ian Cook
Sony Broadcast and Professional Services
Lee Warner
on Sep 27, 2013 at 5:46:07 pm
Ian,
I'm on PC Symphony 6.5.2 and I'm assuming the OP1a file came from FCP7.
Here's the error from Avid.
-------- Import error log start --------
Clip (internal): Kirk's_Winter15s-XXX-XXX
ERROR: ***Error = 'Exception: FATAL_ERROR, msg:DIDDescriptor: GetAAFProperties: XDCAMHD unsupported resolution, file:....srcmsmDIDDescriptor.c, line:2886'.
Here is the analysis I get from MediaInfo utility of the provided OP1a file.
Format : MPEG-4
Commercial name : XDCAM HD422
Format profile : QuickTime
Codec ID : qt
File size : 422 MiB
Duration : 34s 902ms
Overall bit rate : 102 Mbps
Encoded date : UTC 2013-09-26 22:52:51
Tagged date : UTC 2013-09-27 15:11:06
Writing library : Apple QuickTime
©TSC : 2997
©TSZ : 50
Format : MPEG Video
Format version : Version 2
Format profile : 4:2:2@High
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : M=3, N=15
Codec ID : xd5b
Bit rate : 100.0 Mbps
Maximum bit rate : 50.0 Mbps
Width : 1 888 pixels
Original width : 1 920 pixels
Height : 1 062 pixels
Original height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 59.940 fps
Original frame rate : 29.970 fps
Standard : Component
Color space : YUV
Chroma subsampling : 4:2:2
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.832
Time code of first frame : 00:00:00:00
Time code source : Group of pictures header
Stream size : 416 MiB (98%)
Language : English
Tagged date : UTC 2013-09-26 22:54:32
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Lee
SAMDOG Digital Post
Calgary, Alberta based Post Production Specialist & visual problem solver. Fluent in Avid, FCP7, Resolve, After Effects. Available for hire.
Calgary, Alberta YYC · tinyurl.com/6vgfa3f
Lee Warner
on Sep 27, 2013 at 6:26:56 pm
As a followup I did notice that the original file that Avid rejected because of unsupported resolution lists rez as
Would this be the cause of the hiccup?
Lee
SAMDOG Digital Post
Ian Cook
on Sep 27, 2013 at 7:06:23 pm
I'm pretty sure the issue is the video bit rate, which is wrong. Your MediaInfo capture shows a video bit rate of 100 Mbps. While certain devices and encoders (NanoFlash, Episode software etc) can create XDCAM files above the native data rate of 50 Mbps most applications and hardware devices require the file be within the XDCAM specification.
If you want to try a known-good FCP-exported XDCAM file I have a short clip in my Dropbox that was generated by FCP 703: https://www.dropbox.com/s/vo4cdxuvu2vaxws/fcp%20703%20render%20422%2050%205...
This is what the MediaInfo capture should look like:
Let me know...
Lee Warner
on Sep 27, 2013 at 7:36:26 pm
Ian,
My company firewall doesn't allow dropbox. Can you DM me and I will send you a ftp link to use?
Lee
Lee
SAMDOG Digital Post
Ian Cook
on Sep 27, 2013 at 7:41:04 pm
email me the link at ian dot cook at am dot sony dot com
Lee Warner
on Sep 27, 2013 at 7:46:21 pm
Link is on its way.
Lee
SAMDOG Digital Post
Ian Cook
on Sep 27, 2013 at 7:49:18 pm
