Can not connect Sony Cinalta F-350 to Windows Vista 64 bit machine
COW Forums : Sony XDCAM Optical Disc & Related
mark pigott
on Jul 23, 2013 at 5:45:25 pm
I have the folowing installed and it shows up in
device manager
Sony XDCAM PDW-350 IEEE 1394 SBP2 Device
The camera is set to FAM and the most recent
Sony Fam driver is installed (for Vista 64)
But no hard drive appears when i connect the
firewire from the camera to the computer.
Any ideas?
Ian Cook
Re: Can not connect Sony Cinalta F-350 to Windows Vista 64 bit machine
on Jul 23, 2013 at 6:22:52 pm
If the camera is set to FAM and you know you have the correct driver try disabling any antivirus software that is running. Also note that you need a disc in the machine in order to see a mounted drive in My Computer..
mark pigott
on Jul 23, 2013 at 8:38:46 pm
It is a Windows Vista 64 thing.
With the same FAM driver on a Windows 7 machine,
I got it mounted in about 5 minutes.
It's just more inconvenient to grab the footage across
the network as it is just 100baseT.
Thanks for your help.
Ian Cook
on Jul 23, 2013 at 8:40:35 pm
you should try going into Device Manager and rolling back to the legacy IEEE driver
Piotr Niemcewicz
on Aug 6, 2013 at 3:03:01 pm
i resolve similar problem using litte older version FAM drivers
F355 + W7(64-bit)
mark pigott
on Aug 6, 2013 at 3:34:53 pm
Could you tell me the version you used to work with Vista?
Piotr Niemcewicz
on Aug 7, 2013 at 8:44:26 pm
i don't use Vista
i work with Windows 7 Ultimate Edition - 64 bit
mark pigott
on Jun 10, 2015 at 5:42:00 pm
It was solved by switching to a Windows 7 machine with TB2.
Vista was the problem all the time!
