Captioned MXF to Optical Disc Error PDW-U1
COW Forums : Sony XDCAM Optical Disc & Related
Corey Frey
on Jun 5, 2013 at 9:06:35 pm
We are using MacCaption to write caption data to an MXF file, and we do so following the steps from CPC. Once we have a captioned file, I then try to paste it into the Clip folder using a PDW-U1 and receive an error message that it can not be written to the disc with error code -39. I can write non-captioned files fine.
I have set DATA ITEM OUT box to selected. Still same error.
Any ideas?
Ian Cook
Re: Captioned MXF to Optical Disc Error PDW-U1
on Jun 7, 2013 at 2:14:01 pm
You should call this in to support, we can have a look at the file and see if it's compliant. If you're certain that the same file loads properly without captions we can rule out the simple stuff such as file naming or format mismatch. 800 883 6817
