PDW U1 firmware
COW Forums : Sony XDCAM Optical Disc & Related
Karel Hurych
PDW U1 firmware
on Feb 27, 2013 at 7:28:17 pm
Hi, I cannot update firmware - button "start" is greyed, any ideas please! I am Mac user.
Karel
Ian Cook
Re: PDW U1 firmware
on Feb 27, 2013 at 8:47:36 pm
If it's greyed out that usually means the firmware is current and that no update is necessary. If you tell me your current firmware and driver version (from the Utility) I can confirm..
Karel Hurych
Re: PDW U1 firmware
on Feb 27, 2013 at 11:53:16 pm
Hi, thx for answer, my Driver Version is 4.0.1 and fv.v.is 2.450 and my XDCam monitor tells me, I can do firmware update.
Karel Hurych
Re: PDW U1 firmware
on Feb 28, 2013 at 3:47:51 pm
Any ideas please?
Karel
Ian Cook
Re: PDW U1 firmware
on Mar 1, 2013 at 1:04:32 am
so, the button is greyed out or available? if it's raised/available, you should apply the update.
Karel Hurych
Re: PDW U1 firmware
on Mar 1, 2013 at 6:04:05 am
Start buton is greyed out
Karel Hurych
Re: PDW U1 firmware
on Mar 2, 2013 at 11:29:39 am
Mac OS 10.7.5, 2x3GHz Dual-Core Intel Xeon, 5GB RAM.
PDW-U1, Driver version 4.01, Current firmware 2.450, Updated version is 2.540, but button start for update is greyed out. What can I do, any suggestions, please!!!!
Karel
Karel Hurych
Re: PDW U1 firmware
on Mar 2, 2013 at 11:50:24 am
http://www.macedit.biz/ScreenShot
Ian Cook
Re: PDW U1 firmware
on Mar 4, 2013 at 8:51:24 pm
Try re-downloading and re-installing the driver and utility. The firmware is included and the bundled .bin files may have gotten damaged.
Kjell Peterson
Re: PDW U1 firmware
on Apr 25, 2013 at 5:01:05 pm
I have the exact same issue. Have you found a solution yet?
Peter Ruhrmann
Re: PDW U1 firmware
on Jul 1, 2013 at 10:24:15 am
I found the solution:
1. Open Terminal
2. type: sudo /Applications/XDCAM\ Drive/XDCAM\ Drive\ Utility.app/Contents/MacOS/XDCAM\ Drive\ Utility
3. enter your password
Now the XDCAM Drive utility starts with superuser-permissions. You will get some output in the terminal window which you can ignore. The 'Start' button is now available.
This only works if the user-account you are working under MacOS is an admin-user.
Have fun
Peter
